Old January 7th, 2012, 14:49   #1
Carl George
Default p0102 code
I am having trouble and maybe someone can get me heading down the right road. Fixing a a4 for a friend he went to the dealer they said it was MAF and gave him some crazy number to change it. I order one from metal man parts $95 vs $500 from dealer, manifold gasket kit and vacuum hosing and pcv plastic hose that had a crack in it. the intake was all carbon and tar build up. put it back together still had a engine code light I didn't have a scanner with me went to pepboys and they scanned p0102 MAF low input. The light went out then it wasn't even cleared. Drove around, fast, slow no light 50 miles. Changed the oil was going to take it back to him fixed, the light came on? went back and had it scanned P0102 MAF low air input and P0672 #2 cylinder glow plug. Checked plugs, hose can't see why the code again..... Thanks Carl
Carl George is offline   Reply With Quote
P0102 Error code, cant get rid of it! detroitdieselpower TDI 101 3 September 27th, 2013 13:19
P0102 Error code, cant get rid of it! detroitdieselpower OBD Scanners 3 October 7th, 2011 11:32
P0402/p0401/p0102 -_- karter5 TDI 101 1 December 14th, 2010 12:58
P0102 and P0299 codes thebaz67 VW B5 Passat TDIs 3 April 3rd, 2009 08:10
p0101 and p0102 codes andeez VW MKIV-A4 TDIs (VE and PD) 0 December 12th, 2006 16:47
Page generated in 0.10320 seconds with 10 queries
[Output: 46.83 Kb. compressed to 43.97 Kb. by saving 2.86 Kb. (6.10%)]
