VW MKIV-A4 TDIs (VE and PD) This is a general discussion about A4/MkIV Jetta (99.5-~2005), Golf(99.5-2006), and New Beetle(98-2006). Both VE and PD engines are covered here. |
September 25th, 2002, 22:19
#1
Flickering lights, clicking from dash?
My car has started acting funny lately. For about 5 minuites after starting it the lights will flicker and there is a clicking noise from under the dash. Revving the engine up helps solve he problem, but when the rpms drop back down to the idle range it starts back up again. Like I said after driving for a few minuites the problem goes away.
Could this be a bad relay? I don't think it is the infamous 109 because I have had that problem and the symptoms are different this time. Any Ideas?
September 25th, 2002, 22:31
#2
Good Ol' Boy TDIClub Enthusiast
Fuel Economy: see signature
Re: Flickering lights, clicking from dash?
does it do this at idle?
It sounds to me like the normal operation of the afterglow function. Below 2500 rpms, the glowplugs will function to aid in combustion. If you rev the engine above 2500 rpms, the relay clicks off (hence the clicking sound), and the glowplugs shut off. Since the glowplugs draw so much current, the headlights may go bright/dim when relay clicks on/off. Avoid engines speeds above 2500 rpms until the engine warms up to operating temperature.
September 26th, 2002, 08:23
#3
The thing is that it doesn't just click off and back on when the rpms drop back to idle. When I am sitting at a red light or something the dash lights and headlights lights are flickering really bad. People in other cars start looking at me funny. and the noise from the dash is going "click-click...click-click...click-click" Whatever relay controls the afterglow must be malfunctioning, anybody know which relay it is?
September 26th, 2002, 08:25
#4
Okay, your updated description does not sound like the afterglow function. You probably have a faulty relay that needs to be replaced.
I believe the glowplug relay in pre-2002 cars is relay #180. I also think this has been replaced by an under-hood relay in the newer cars. Again, i'm not 100% sure about this.
If you have a Vag-Com, you can view one of the measuring blocks, i'm not sure which one it is off the top of my head, and view glowplug status in binary format (1=on, 0=off). If the binary values are changing while your relay is clicking, then your problem is in the glowplug relay. If the binary values stay the same while the relay is clicking, then the problem is not in your glowplug relay.
Hope this helps.
[ September 26, 2002, 10:48: Message edited by: VeeDubTDI ]
September 26th, 2002, 08:45
#5
What was described is also consistant with low voltage. The statement that reving the engine supports this as the alternator will be able to put out more power. But the fact that there was no statement that the engine was not cranking over easily is puzzleing.
There could be a bad relay or ''ignition'' switch with burnt contacts.
Perhaps the battery electrolyte levels should be looked at.
September 26th, 2002, 09:10
#6
The glow plugs warm up fine and the engine cranks like a champ so I don't think there is a problem with the battery. The clicking is what points me towards a relay or bad connection of some sort.
I know the sound of the afterglow "click" when the rpms drop, I have had the car for over a year. The thing is that this is the same sound and happens at the same time, but over the past 2 or 3 days it has just seemed to go haywire.
September 26th, 2002, 10:15
#7
I believe the glowplug relay in pre-2002 cars is relay #108, but i'm not 100% sure. I also think this has been replaced by an under-hood relay in the newer cars.
<font size="2" face="Verdana, Helvetica, sans-serif">Lawson,
It's 180 and yes it's a control module in the OEM plenum.
Probably a relay. Remove the front trim covers and metal plate at your knees so it looks like this...
Then, you can listen and diagnose the clicking relay.
September 26th, 2002, 10:49
#8
Thanks for the correction Lito, i've updated my previous post. [img]images/icons/smile.gif[/img]
September 26th, 2002, 10:58
#9
Yeah, I know how to get to the relays, I have replaced #109 on another TDI, I will check out relay #180 and see if it is the source of my problems. Thanks for the help.
September 26th, 2002, 13:40
#10
Relay 180 is $100.00 from Impex. Find another TDI'er to do a test.
L
January 14th, 2003, 13:37
#11
boradsl,
Did replacing relay 180 fix the problem?
(I have the exact same problem as you describe)
