Go Back   TDIClub Forums > VW TDI Discussion Areas > TDI Fuel Economy
TDI Fuel Economy Discussions about increasing the fuel economy of your TDI engine. Non TDI related postings will be moved or removed.
Old January 6th, 2012, 03:41   #1
smitty711
Fuel Economy: 39-41mpg commuter Sac to SF 3-4 days a week
Default mileage increase
I have a 2004 Jetta TDI with the BEW engine. I commute from Sacramento-SF 3 times a week. 91 miles RT. I have 140,000 miles on it. I usually avg 38-40 mpg . Over the last few months i have noticed i have been avg 41-43 mpg. All that has been done is new tires all the way around. I find it hard to believe a new set of rubbers would increase the mileage that much. Any idea?
smitty711 is offline   Reply With Quote
Old January 6th, 2012, 03:58   #2
Joe_Meehan
Joe_Meehan's Avatar
Fuel Economy: mid-upper 40's city upper 50's - low 60's Highway
The tyres could have done it. The old ones may have had more drag than the replacements as well as they may have had low air pressure. I might also suggest the possibility of a different diesel formula "cetane" etc.
Joe Meehan
2002 NB Silver Ohio BAA HUM
Joe_Meehan is offline   Reply With Quote
Old January 6th, 2012, 04:35   #3
alloutdoorsboy
TDI(s): 2000 jetta
begs the question, Which tires??
alloutdoorsboy is offline   Reply With Quote
Old January 6th, 2012, 10:45   #4
Joe_Meehan
Joe_Meehan's Avatar
That is a rather large jump, but it is possible. Just remember that life is a lot of trade-offs. The tyre with the best mileage, my have a shorter than average life and the net cost could actually be higher.
Joe Meehan
Old January 6th, 2012, 14:59   #5
smitty711
They were the cheap tires. Falken sincera
Old January 6th, 2012, 15:21   #6
psd1
Fuel Economy: See Fuelly link
Same size?
psd1 is offline   Reply With Quote
Old January 6th, 2012, 15:44   #7
smitty711
Yup same size tire. Oh and I did change to BP diesel
Old January 6th, 2012, 16:31   #8
alloutdoorsboy
TDI(s): 2000 jetta
right and the BP is 47 cetane as opposed to the 40 you were using before, theres your milage increase.
Old January 6th, 2012, 17:20   #9
smitty711
Wow really. Ok thanks guys
Old January 6th, 2012, 17:21   #10
AndyBees
AndyBees's Avatar
I've noticed that different sets of tires give different mile results on the Odometer. Some will "under register" and some will "over register" miles in a given distance (GPS and milepost verified). I adjust my spreadsheet formula accordingly. It's typically no more than 1 to 1.5% plus/minus. Occassionally I have had a set that would be dead-on!
'84 Vanagon '02 ALH TDI engine Malone Stage 1 tune. CAT, SS 2" exhaust, E-vac system, DMF with upgrade pilot shaft, 4.57 R&P, fan assisted IC. (32 to 35+ MPGs consistently)
AndyBees is online now   Reply With Quote
Old January 9th, 2012, 19:22   #11
williamgd2
williamgd2's Avatar
TDI(s): 2010 Jetta
Fuel Economy: 50 mpg at 65mph with no a/c
I think its the fuel change,I have found good fuel= good millage.
williamgd2 is offline   Reply With Quote
Spoilers increase mileage? onlyn8v TDI Fuel Economy 42 February 22nd, 2011 15:24
Mileage Increase Vwee Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc) 17 May 30th, 2006 15:57
want to increase mileage? gboss TDI Fuel Economy 6 May 25th, 2004 18:39
How to increase mileage? Brock_from_WI TDI Fuel Economy 5 October 12th, 2002 19:36
mileage increase Roy Basch VW MKIV-A4 TDIs (VE and PD) 1 October 31st, 2000 06:57
Page generated in 0.13762 seconds with 10 queries
[Output: 98.27 Kb. compressed to 82.79 Kb. by saving 15.48 Kb. (15.75%)]
