Old January 4th, 2012, 11:44   #1
flyboybob
Default emission systems warranty?
how long is the warranty on emission systems components for these cars (2012 passat tdi family)? what components are covered?
i heard someone at the dealership mention a warranty period of 8 years/80K miles for emission system components. wondering if that's true and what's covered.
flyboybob is offline   Reply With Quote
Old January 4th, 2012, 12:01   #2
MyAvocation
MyAvocation's Avatar
I would lay that task on your sales associate and through email, if possible. That way you have something other than a phone conversation to refer back to. You can also do the same with VW Customer Care via this address: vwcustomercare@vw.com
"Never trust Internet quotes." - John F. Kennedy
MyAvocation is offline   Reply With Quote
Old January 4th, 2012, 13:30   #3
Roshermoore
Smile Federal Emission Warranties
Look in the Booklets that were provided to you. In addition to the regular Owner's Manual there is a separate "USA Warranty and Maintenance" booklet. In there you will find more than you ever wanted to know about these warranties. Since you live in Oregon it even gets more confusing since you are also covered by California's emission requirements.
In very general terms, there are two types of these warranties. Some components are covered for 2 years and 24K miles and others are covered for 8 years and 80K miles. No need trying to list what's covered here since they are found in your warranty booklets.
09 Jetta Sportwagen, Blue Graphite Metallic, DSG, Sunroof, Rubber mats, Zeta Products body color side moldings, Body color door edge guards, VW front and rear Splash Guards, Clear rear bumper protector, 8" "Stubby" antenna. Build Date 11/08
Roshermoore is offline   Reply With Quote
Old January 4th, 2012, 16:43   #4
TomB
Fuel Economy: 34 mpg on first tank
8 yr/80 000 is the federal requirement. California is different and the specific components covered are listed on the warranty with the car.
2007 Jeep Grand Cherokee 3.0L MB Diesel
2012 Passat TDI SEL Premium Opera Red/Titan Black
2015 Audi A3 TDI Prestige S-line Lotus Gray Metallic/Black Leather
TomB is offline   Reply With Quote
Old January 4th, 2012, 16:54   #5
monstersinc1
http://www.arb.ca.gov/msprog/warranty.pdf
http://www.epa.gov/oms/consumer/warr95fs.txt
monstersinc1 is offline   Reply With Quote
Old February 4th, 2012, 12:45   #6
pogo
Fuel Economy: Golf 48 Passat 43
Looks like 2 years, 24K miles covers fuel tank, fuel system, injections system including injection pump, exhaust system including turbo and cat, EGR, intake system, ignition system, etc.
8 years, 80k miles only covers, catalytic converter, particulate filter, ECM and OBD. In NJ you're not required to take an emissions test until the 5th year, so basically only thos last few items are covered.
Engine and powertrain are 5 year 60K miles, but don't appear to cover fuel or injection systems. Not sure.
'02 Golf TDI 5spd 230K mi
pogo is offline   Reply With Quote
Old February 4th, 2012, 15:58   #7
MyAvocation
Strange EGR not listed, as emissions is its sole purpose. May want to double-check that.
Old February 4th, 2012, 18:04   #8
pogo
Looks like the same coverage for the past couple of years, at least:
For 8 Years or 80,000 miles
If the vehicle has been in use for more than 24 months or 24,000 miles, but less than 8 years or
80,000 miles, whichever occurs first, your Volkswagen dealer will repair or replace free of charge the
following major emission control components only:
 Catalytic Converter and Diesel Particulate Filter
 Engine Electronic Control Module
 On Board Diagnostic Device
Old September 24th, 2012, 18:12   #9
maxedtdi
maxedtdi's Avatar
fuel injectors, fuel injection units and fuel altitude compensator sensor, bars or rails for EFI or TBI systems, mixture settings on sealed fuel mixture control solenoid, diaphragm or other systems, fuel metering components that achieve closed/other feedback control sensors/loop operation switches and valves
seems like a very comprehensive list.
maxedtdi is offline   Reply With Quote
Old September 25th, 2012, 11:16   #10
740GLE
According to the EPA website, EGR systems good for only 2yr 24K.
which is great because if the EGR system goes TU at 36K, and hoses your DPF or SCR, VW doesn't have to warranty any of it, because you didn't maintaine the car to design spec.
(now the chances of a dealer sticking it to you that way is pretty slim but the feds are in agreement, you need to maintain your car per design spec for warranty out to 80K, same thing as if asking VW to replace your engine at 50K becuse you hadn't checked or changed the oil since 30K)
Old September 25th, 2012, 12:04   #11
Lightflyer1
Lightflyer1's Avatar
How so? Free maintenance by dealer till 36k so they have maintained it the whole time. How would they be able to say you didn't maintain it properly without implicating themselves?
2015 Beetle TDI.
Old September 26th, 2012, 09:56   #12
740GLE
Because it's outside the warranty period, and isn't covered by the 60K powertrain warranty. If it fails at 35K, then it'd be VW's bill to pick up.
But with, all the P0401 codes the CJAA engines have been getting and VW dealers tossing EGR filters, and new DPF to attempt to fix seems like they are being kind an expanding what the the EPA is holding them too.
Old August 6th, 2015, 18:00   #13
bluengreen
Question 2012 Passat TDI Emissions 8/80 warranty
2012 Passat TDI was Cert used VW dealer sold and has 4K to go before 1st oil change on my watch. It throws a check engine light. VW Service codes it as an ECM issue. Car has <30K total miles & has additional extended warranty. Web info & this site all peg this as a covered Fed 8/80 Emssions warranty issue. VW locally and Natl says the ECM is covered, but they also now maintain that this failure is not warrantied.
If the Web Resources all concur, VW concurred and this is a Fed mandate -how could they deny coverage?
I appealed on that basis and await the promised 24 hour reply turnaround. If not covered it's a $500 part and $250 labor job that allegedly is not a Platinum Warranty covered item either
How are different outcomes possible or reasonable if the part is Emissions mandated per the Fed 8yr/80K mi requirements? What would then make the ECM Warranty replaceable under any circumstances?
I will post further after the appeal verdict is in.
2009 Laser Blue Jetta TDI
(Gestated after 9 Mos.
A Bouncing Rudy Diesel!)
bluengreen is offline   Reply With Quote
Old August 6th, 2015, 22:08   #14
Lightflyer1
Sometimes you have to keep pushing the issue to get satisfaction. Educate yourself and keep pushing. They like to say no and have you just go away if possible. Don't be a quitter.
2015 Beetle TDI.
Definitive Answer on DPF 'Emission' Warranty? Canadia TDI 101 2 September 25th, 2009 19:05
Biodies-ill, VW's warranty, and the Diesel Injection Systems Official stance on it. Audi5000TDI Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc) 24 February 1st, 2006 22:22
Vehicle Emission Standards Around the Globe (and California emission limits wrt TDIs) tjl TDI (Diesel) Emissions 9 February 5th, 2003 16:24
Warranty 101 - The Magnuson-Moss Warranty Act Turbo Steve General VW Discussion 3 December 5th, 2000 09:03
kw-systems j88k TDI Power Enhancements 0 September 12th, 2000 21:49
Page generated in 0.14996 seconds with 10 queries
[Output: 121.54 Kb. compressed to 101.58 Kb. by saving 19.96 Kb. (16.42%)]
