Old September 23rd, 2015, 17:03   #61
Sebster
TDI(s): Passat b5.5
Fuel Economy: Much as you feel in...
Originally Posted by gabrielT View Post
What kind of bur you using mate?
Can you do picture please?
Sebster is offline   Reply With Quote
Old December 11th, 2017, 14:57   #62
corsabala
Someone can upload the images again? Thank you
corsabala is offline   Reply With Quote
Old December 11th, 2017, 18:28   #63
[486]
TDI(s): 02 golf ALH
Google "aluminum cut bur"
I really like the SH ("flame") shape for port work, but an SD ("ball") shape comes in handy for areas that you can't see straight on, using the back side of the curve by the shank.
For size, I usually get the #5 ones.
[486] is offline   Reply With Quote
Old December 11th, 2017, 19:46   #64
BigTurboAlh
Fuel Economy: 35
https://ibb.co/czgySw
Only pic I can find of my current head. room for a good bit of improvement.
BigTurboAlh is offline   Reply With Quote
Old December 15th, 2017, 03:54   #65
Jukums
Default Head porting pictures
Audi 80 B4 1.9TDI Power figures: unknown
0-402 best time 13.3sec trap speed 179km/h
Engine: Building at the moment.
http://www.tdr.lv/audi-80-b4-jukums/
Jukums is offline   Reply With Quote
Old December 15th, 2017, 21:28   #66
Mongler98
Not sure if it was posted in this thread but the only true way to make sure you do the best job possible is to do a water volume test. Block off the valve seats with the valve and the seal then add water with an acrylic top on it and measure the water. All ports must be the exact same. For a mild high end power like 250-300 hp I’m sure it’s not a deal breaker but it’s the right way to do it. I have never seen anyone do that to a TDI head though, at least not posted here. I did this when I ported my head. I found that they were all with in 1.5cc but #2 was 4cc more than all the others so I had to work them to all be the same within .5cc, that was good enough for me. After reading this thread I realize I could take MUCH MUCH MORE out of the ports. After all I just cleaned them up, a made them a tiny bit better than before but only took enough off to gasket match and blend that in.
Old December 16th, 2017, 00:08   #67
Macradiators.com
Macradiators.com's Avatar
TDI(s): 2.0 CR 360hp
Best way is to do it is CNC , cant beat that.
On the 2.0 CR cnc is no possible due tu the long intake runners i've been told when i inquired for my head.
CP3 Upgrade
100-200 Acceleration
Macradiators.com is offline   Reply With Quote
Old December 16th, 2017, 10:03   #68
nicklockard
Torque Dorque
nicklockard's Avatar
Fuel Economy: No data yet.
What bit or burr would you use to cut hard steel? Recommendation link, please.
nicklockard is offline   Reply With Quote
Old December 16th, 2017, 13:26   #69
[486]
TDI(s): 02 golf ALH
normal tooth carbide burr, throttle back for lower RPMs to keep the heat down,
or if you're trying to cut carbide, use a green (silicon carbide abrasive) mounted point (vitrified abrasive wheel)
Old December 21st, 2017, 20:25   #70
Franko6
This is as good a place as any to make an announcement. Last weekend, we took possession of a dedicated CNC machine which includes a custom-made jig and digitized porting For the most commonly ported cylinder heads: The ALH and AHU versions. The whole porting process now takes about 3-4 hours and is done with little intervention. We will have the machine set and running before the Year's end. 2018 will be the beginning of several CNC projects; porting is just the first.
Major benefits of CNC porting is repeatability and time reduction of the process. However, personally, I like the fact my hands don't go numb as I watch as a machine does what used to be done by hand. Porting is large bottleneck in the processing of a complete engine, which we have now, overcome.
We are rearranging the shop and closing what used to be a vehicle bay to concentrate more on the machining side of the business. We do have a backlog of engines that will soon be completed, when our porting machine is in place. It is very nice to have a 'push-button' and repeatable process, which will definitely improve the total time of engine building.
Many of the porting jobs pictured here are actually 'polishing' jobs. The size and shape of the port is critical and we certainly have an improved design The critical dimensions are at the openings of both the exhaust and intake, the inside turn of the exhaust and the opening of the intake to the swirl chamber.
We are also finding it wise to invest in tooling that will expose porosity. Even if the porting job is done perfectly, the cylinder head may contain bubbles in the casting which can cause failures.
Frank's VW TDI's, LLC
1007 Olive St.
Lockwood, MO 65682
417-232-4634
FranksTDIs@sbcglobal.net
'02 80k grey leather, 99.5 R.I.P 153k
'85A2 NA 375k, '91 A3 290k Always Silver, Always a Jetta
Franko6 is offline   Reply With Quote
Old December 21st, 2017, 21:19   #71
Mongler98
Originally Posted by franko6 View Post
>>last weekend, we took possession of a dedicated cnc machine which includes a custom-made jig and digitized porting for the most commonly ported cylinder heads:
>>the alh and ahu versions.
>>2018
OH i cant wait!!! supper happy to hear this.
*Anticipates Head Job!
Old December 29th, 2017, 10:55   #72
Gordon Peterson
Gordon Peterson's Avatar
Fuel Economy: 40mpg
I am sending you a head for porting, a valve job and a nice stage 2 cam. Will be great in my 59 Ford truck project. I am guessing there will be allot of heads run thru that machine.
03 Jetta TDI wagon "SMOKE" (mine)
trusted guru's: r90sKirk, JETaah, Franko6
Heads nozzles,TB kits, etc.: Franko6
Gordon Peterson is offline   Reply With Quote
Old January 2nd, 2018, 12:03   #73
Franko6
Hi, Gordy...
Yes, I have a pile of them to do, so just what's backed up, we got plenty to do. First I have to figure out making a wye instead of a delta for the 3rd leg of the phase converter. Don't have the advantage of 3 phase wiring to the shop...
I'll send you a label.
1007 Olive St.
Lockwood, MO 65682
417-232-4634
Old January 2nd, 2018, 12:10   #74
Franko6
Hi Gordy,
I'll send you a shipping label. No problem.
Once I figure out the wye instead of delta for the third leg of the rotary phase converter, I'm sure the bugs will go away.
I do have a backlog of heads, so it will be nice to clear them out.
Mongler, now that I was explained what you meant, I have to say, I enjoyed the humor..
"Shut up and take my money!"
https://www.youtube.com/watch?v=TrXBEuG7I3A
1007 Olive St.
Lockwood, MO 65682
417-232-4634
Old January 2nd, 2018, 15:14   #75
snadam
snadam's Avatar
Purely out of curiosity, how come you're messing with a rotary converter in this day? VFDs aren't that expensive anymore and if it gets you up and running more quickly the payback would be pretty quick given that you already have a backlog.
11 GOLF - EURO GTI SHIFT KNOB - GTI REAR SKIRT - GTI DUAL EXHAUST - HUPER OPTIK CERAMIC TINT - OTHER THAN THAT IT'S A RELIABLE CAR, I MISS MY O1' BORA
02 NB - CUSTOM PAINT - 11MM IP - 2.5" EXHAUST - BOSCH .205 - UNITRONIC - BIG BRAKES - SKID & FMJ - KONI FSD & OEM SPORT SPRINGS - HID LAMPS - BILSTEIN PSS9 COILOVERS FOR SALE
snadam is offline   Reply With Quote
Porting head,questions again. dieseljohnny TDI Power Enhancements 23 December 27th, 2009 02:13
head porting KROUT TDI Power Enhancements 38 November 15th, 2008 07:08
Porting ALH head Pat Dolan TDI Power Enhancements 56 July 18th, 2008 03:13
Head Porting devonutopia TDI Power Enhancements 26 August 26th, 2007 15:03
porting the head BlakGolf TDI Power Enhancements 39 January 21st, 2007 15:20
Page generated in 0.21191 seconds with 10 queries
[Output: 132.68 Kb. compressed to 111.30 Kb. by saving 21.37 Kb. (16.11%)]
