Old September 10th, 2012, 11:56   #31
JFettig
JFettig's Avatar
same as Fix_Until_Broke
http://forums.tdiclub.com/showpost.p...99&postcount=9
Minnesota Malone Tuning dealer
1998 B5 Passat TDI Compound Turbos
2009 JSW Stage 3 196whp so far
DIY injector calibration http://forums.tdiclub.com/showthread.php?t=383324
JFettig is offline   Reply With Quote
Old September 11th, 2012, 12:58   #32
adamss24
Fuel Economy: 35-45mpg
2.5 tdi Transporte T4 van:
v6 tdi 180Bhp:
1.9VE Tdi:
adamss24 is offline   Reply With Quote
Old September 11th, 2012, 13:58   #33
Got Bearings?
Got Bearings?'s Avatar
Fuel Economy: 36 / 50
Focus!!!
The New Commuter Car: 2009 Cadillac CTS-V 556 HP, 6.2L Supercharged V-8, 6 speed manual
The Old Commuter Car: 01 Golf GLS TDI WRECKED AND GONE!
The Slow Car: 95 Impala SS 383, 6 speed, 391HP , 440TQ
Looking for Battery Cables, better & cheaper than OEM? Click here for info
Got Bearings? is offline   Reply With Quote
Old September 14th, 2012, 15:08   #34
2footbraker
2footbraker's Avatar
Wow those are some terrible pictures.
2006 Jetta TDI - Malone Tuning stage 4, G60/VR6, Vogtland 55mm/Koni Sports, Darkside GTB1749V, EGR delete, Frank's BRM cam, etc.
Several other IDI's and TDI's
2footbraker is offline   Reply With Quote
Old September 16th, 2012, 03:40   #35
KPG
Hello guys.
There some pics off my ALH head.
KPG is offline   Reply With Quote
Old September 16th, 2012, 03:41   #36
KPG
and more...
Old September 16th, 2012, 06:07   #37
Franko6
We do our share of porting.
The profile pics that fettig and FUB show are similar to what we make. We do not go as radically close to the water jacket at FUB's picture shows. But as those pictures indicate, you can't see most of the critical modifications unless you cut the thing apart.
Every time we have shown porting pics, someone always comes out and says how we did it wrong... but here is what we do, based on our goals.
There is a problem with the intake port, as we do not agree with the right angle at the apex of the swirl chamber going into the bowl under the valve. If the head is going to crack, and a hard-driven engine is more prone, it will crack into the water jacket at the intake port beginning at that right angle. We round out that corner... carefully. We make about a 3/8" radius.
We remove material at the inside radius of the exhaust. Some who do porting feel that the exhaust gases aren't affected by that corner. We disagree. That is exactly where the bottle neck is. You have to be careful removing too much metal around the valve guide on the exterior radius of the exhaust port, or you will have a very poorly supported valve guide with a greatly reduced heat transfer area. Exposing more of the exhaust guide also creates a heat absorption in the guide, which is a negative effect. So, removing metal from the opposite side of the bottleneck is a good idea. Also, if you make comparisons to the later exhaust ports, say in the BRM and CBEA, VW has taken steps to smooth and open up that inside corner. So, what we have been doing on the inside radius is vindicated.
Between the ALH and the AHU, there is a major difference in location of a water jacket. We found out early when practicing on AHU cylinder heads. If you match the port to the exhaust manifold and go straight back on the head gasket side, you will break into the water jacket. Basically, we match the port opening to the exhaust manifold, then angle up and over the water jacket. We remove only a little material over the water jacket at that point.
Also for both ALH and AHU, you have to watch out for the head bolt holes in the exhaust. If you were to grind straight back from a line that matched the exhaust manifold, you will break into the head bolt holes. We believe it is good practice to match the port opening size, but not very good when you break into a head bolt hole...angle your cut around the bolt hole.
On the intake, we open up the bowl and smooth the angles going back from the swirl chamber. If you think there is much room in the intake runner to remove metal, just feel the web between the two center intake ports. It's very thin.
For about 3 inches, the intake only gets smoothed up with very little material removed. We do not build a full race head, so we do not remove the swirl chamber. A swirl chamber cannot work unless there is turbulence, so some expectation of flow loss is mandatory, with the payoff that you are going to make a cylinder head that will work efficiently when cruising. That is our opinion.
Frank's VW TDI's, LLC
1007 Olive St.
Lockwood, MO 65682
417-232-4634
FranksTDIs@sbcglobal.net
'02 80k grey leather, 99.5 R.I.P 153k
'85A2 NA 375k, '91 A3 290k Always Silver, Always a Jetta
Franko6 is offline   Reply With Quote
Old September 16th, 2012, 06:20   #38
JFettig
JFettig's Avatar
Thanks for the post Frank, can you outline where the waterjacket is on an AHU head with a pic maybe? I feel like I went a little large based on what you say about the AHU.
If I had to guess, I'm guessing you are outlining the top side of the port in this pic where it is outlined in red? http://i121.photobucket.com/albums/o...e/head4mod.jpg
Also, where do you put that 3/8" radius? If its where I'm thinking, it would hurt flow, but I'll let you show us where it is. It isn't right in the center where this pic is focused is it?
http://pics.tdiclub.com/data/500/Jet...ported_-_r.JPG
The external corner or internal corner?
Old September 16th, 2012, 17:55   #39
Franko6
The right angle of the intake port should be rounded with a 3/8" radius.
1007 Olive St.
Lockwood, MO 65682
417-232-4634
Old September 16th, 2012, 18:05   #40
JFettig
JFettig's Avatar
I am guessing you mean 3/8 diameter?
Old September 16th, 2012, 18:17   #41
2footbraker
I found out first-hand how close the water jacket is to the exhaust port, however mine was on a 1.6td head. Be careful!
Old September 16th, 2012, 19:08   #42
Franko6
Sorry the picture didn't come out very good...
We use a 3/8" sanding drum on a die grinder. Work the right angle until it's smooth.
1007 Olive St.
Lockwood, MO 65682
417-232-4634
Old September 16th, 2012, 19:11   #43
Franko6
2footbraker,
Yeah, you know what I mean... The older heads are a bit rougher on the castings and more variance. The good thing is that you can probe those water jackets to see how far you want to go.
If I find $1200 burning a hole in my pocket, there is an ultrasonic depth gauge that you can accurately determine wall thickness. So far, the money is still in my pocket.
1007 Olive St.
Lockwood, MO 65682
417-232-4634
Old September 17th, 2012, 13:12   #44
Bob S.
Franko, Thanks for the thoughtful explanation.
A B4V, a CRUA & a couple BRMs & ALHs in the family.
Bob S. is offline   Reply With Quote
Old September 18th, 2012, 06:26   #45
JFettig
JFettig's Avatar
Does anyone have any volumetric efficiency figures for these heads or at least some direction in figuring it out?
I'm looking for volumetric efficiency over the rpm range.
Porting head,questions again. dieseljohnny TDI Power Enhancements 23 December 27th, 2009 01:13
head porting KROUT TDI Power Enhancements 38 November 15th, 2008 06:08
Porting ALH head Pat Dolan TDI Power Enhancements 56 July 18th, 2008 02:13
Head Porting devonutopia TDI Power Enhancements 26 August 26th, 2007 14:03
porting the head BlakGolf TDI Power Enhancements 39 January 21st, 2007 14:20
Page generated in 0.17840 seconds with 10 queries
[Output: 133.32 Kb. compressed to 111.75 Kb. by saving 21.57 Kb. (16.18%)]
