Old January 2nd, 2012, 23:26   #1
Got Bearings?
Got Bearings?'s Avatar
Fuel Economy: 36 / 50
Default Head porting pictures
Recently, I've seen people post pics of head, showing the porting done but I can't find the threads anymore. If you have any pics to post or links to pics, would you mind sharing them on this thread?
I would appreciate it and I'm sure others would too.
Thanks!
The New Commuter Car: 2009 Cadillac CTS-V 556 HP, 6.2L Supercharged V-8, 6 speed manual
The Old Commuter Car: 01 Golf GLS TDI WRECKED AND GONE!
The Slow Car: 95 Impala SS 383, 6 speed, 391HP , 440TQ
Looking for Battery Cables, better & cheaper than OEM? Click here for info
Got Bearings? is offline   Reply With Quote
Old January 3rd, 2012, 16:36   #2
Got Bearings?
Come on.. don't be so shy!!! I know people have them. Post'em up!
Old January 3rd, 2012, 18:04   #3
Nash_TDI
Veteran Member -TDIClub Enthusiast
Nash_TDI's Avatar
Fuel Economy: 63.25mpg max
IMG00164-20101129-1215 by Nash_TDI, on Flickr
I wish I had taken more, but I didn't.
2.0 ALH, GTB2260, 12mm, etc, etc.....
www.nashimporters.com http://louisvillevw.org/
TDI Repair Available, TBs, Clutches, Manual Swaps, BSM, etc..
PD Cam tools, BSM tool, VE & PD TB tool rental available.
Nash_TDI is offline   Reply With Quote
Old January 3rd, 2012, 19:49   #4
GTiTDi
Macht Schnell! Vendor
GTiTDi's Avatar
Location: 3 Spruce st Wareham, gateway to Cape Cod Massachusetts
Here ya go..a 1Z head updated to 7mm valves/guides , 3 angle valve grind and some mild porting http://forums.tdiclub.com/showthread...=304978&page=9
91 GTI CJAA (was 1Z powered) (2012 TDIfest Radical class winner) CTN+(eurotuning 6th) fully deleted, 3" SS downpipe and side pipe running standalone using the Tischspiegel
MK2 GTI build
schnellsnailFB
GTiTDi is offline   Reply With Quote
Old January 4th, 2012, 06:57   #5
arne487
arne487's Avatar
Fuel Economy: 62.4 max, 53 avg
This is an interesting one:
http://forums.tdiclub.com/showthread.php?t=266569
His: '03 Golf - The Saga Continues
'04 Passat Wagon 1.8T 4-Motion 5-Speed - Bone Stock
Hers: '10 TDI Cup Jetta - Now back in the hands of VW.
arne487 is offline   Reply With Quote
Old January 4th, 2012, 11:49   #6
Got Bearings?
Thanks for the pics and links. If anyone has pics they don't want to share publicly, you can PM me and will not share them with anyone.
Thanks!
Old January 4th, 2012, 19:55   #7
Sootman
Sootman's Avatar
Fuel Economy: 30 +/- MPG
Here's a few from my ALH
Sootman
A friend will help you move. A good friend will help you move a body.
Audi Quatro A3 gasser. Hey is it my fault I can't buy a diesel Quatro??
http://www.idparts.com/catalog/index.php
Dyno: http://forums.tdiclub.com/showthread.php?t=352348
Sootman is offline   Reply With Quote
Old January 4th, 2012, 20:05   #8
JFettig
JFettig's Avatar
How much material is actually removed from the ports? Every intake port I have seen appears to just be smoothed out.
Minnesota Malone Tuning dealer
1998 B5 Passat TDI Compound Turbos
2009 JSW Stage 3 196whp so far
DIY injector calibration http://forums.tdiclub.com/showthread.php?t=383324
JFettig is offline   Reply With Quote
Old January 5th, 2012, 20:18   #9
Fix_Until_Broke
Fix_Until_Broke's Avatar
Fuel Economy: 75.0/53.0/38.4
All the above ports look like they have had very little material removed from them - just a bit of polishing and smoothing out any rough edges.
I think the intake ports are pretty good "as is". Not that there can't be improvements in flow rate by porting, but at the cost of intake charge swirl. In Alex22's thread where he had both flow and swirl measurement there was significant loss in swirl at low to mid valve lifts where the valve spends most of it's time.
The exhaust ports have quite a bit of room for improvement in my opinion.
Here's what I did on my head
Intake
Exhaust
03 Jetta, Cat 2u, DG Steel SP w/MOGolf Mod, 3"DP, 4"EXH, EaBP100 Bypass, Euroswitch, ECodes, Driving Light, PD Lift Pump, R520's, RC5,RC6, TDTuning, Malone, ScanGaugeII, 3" TIP, 2" TOP, HE221W Compounded with GTC1444VZ, 6 Bar MAP, VR6 MAF, Vented Fender Liner, Battery Cover Mod, 11mm, Monster Mats, 215/55/17 (27.9/53.0/75) Monthly MPG Links, Euro Trunk Latch, IDParts RSB, SDI or ALH Intake, ARL Ceramic Pistons, Rosten Rods, DRW, Wavetrac, SBC, FSD's, Beef Springs, Rebuilt Head, Recaro's, Colt II, DG Sigma 6, RMT200
Fix_Until_Broke is offline   Reply With Quote
Old January 6th, 2012, 09:47   #10
Satiro
Satiro's Avatar
Intake
Exhaust
Thanks for those pictures! are very enlightening for me. I will have to make that work soon.
Rub87remap ARLpistons PD100rods Sputters ARLbolts Rosten'sMainStuds VitonSeals PortedHead Rosten'sValveSpring ASVpump 11mmHead DE143 11mmSprings GT18v Race520 BigFMIC fuelCooler LiftPump CRfuelFilter PD130Manifold Dbilas260cam BlackLifters OilCooler 312mm+porscheCalipers Sigma5SSK BilsteinEibach MK4RearBearings/Calipers EibachProKitSwayBars
Satiro is offline   Reply With Quote
Old January 6th, 2012, 15:34   #11
apomiett
TDI(s): A2 mTDI
Hello.
Do you want pictures of pd or ve head? I have few $hitty pics of a ported pd head and can take pictures of a head disection. I`m porting a ve style head at the moment so i can take pictures of that also.
I totally agree. Most pictures that i have seen in this forum only show minor pocket porting which has very little effect and to my opinion are totally worthless for the cost and effort.
apomiett is offline   Reply With Quote
Old January 6th, 2012, 15:50   #12
JFettig
JFettig's Avatar
Please post PD and VE porting.
Old January 6th, 2012, 16:01   #13
Got Bearings?
Yes, post them both!
Old January 6th, 2012, 20:50   #14
joseluis.17g
please do so..
joseluis.17g is offline   Reply With Quote
Old January 10th, 2012, 17:41   #15
PRA4WX
TDI(s): 1Zzzzzzzz
PRA4WX is offline   Reply With Quote
Porting head,questions again. dieseljohnny TDI Power Enhancements 23 December 27th, 2009 02:13
head porting KROUT TDI Power Enhancements 38 November 15th, 2008 07:08
Porting ALH head Pat Dolan TDI Power Enhancements 56 July 18th, 2008 03:13
Head Porting devonutopia TDI Power Enhancements 26 August 26th, 2007 15:03
porting the head BlakGolf TDI Power Enhancements 39 January 21st, 2007 15:20
Page generated in 0.16981 seconds with 10 queries
[Output: 138.39 Kb. compressed to 116.58 Kb. by saving 21.81 Kb. (15.76%)]
