Old January 2nd, 2012, 13:43   #1
wetskier2000
Default P0101 code
Keep getting a P0101 MAF MIL on a 2005 PD Jetta wagon with 115k miles.
I began by cleaning the MAF and clearing the code. It returned several days later.
Next I replaced the MAF and cleared the code. Again returning several days later.
It was then that I noticed the 3-4 inch diameter hose from the intercooler to the turbo was no longer seated correctly. The alum fitting on the turbo end was not inserted all the way into the corresponding fitting. The spring clip's bottom section was missing. I replaced the spring, cleared the code, but again the MIL returned.
Now I noticed that the alum fitting on the end of the hose no longer had it's little tabs that hold it behind the spring clip I already replaced. I replaced the hose, it clipped in just fine now, but as you suspected, the MIL came back again.
I'm at a bit of a loss.. No blockages on the intake side, air cleaner or snow screen. The intake has never been cleaned but we run the car agressively regularly and run DieselService full time.
Ideas??
thanks!
Rick
Sold but will be missed: '05 Jetta Wagon - RC1+, G60/VR6
New Ride: 2015 Golf Sportwagen SEL. Only cosmetic changes so far(door sill and edge protection, body side molding, wind/rain deflectors).
wetskier2000 is offline   Reply With Quote
Old January 4th, 2012, 10:33   #2
wetskier2000
Ok, I've searched and searched the forum, but really found nothing about a P0101 that doesn't go along with poor performance. Our '05 seems to continue to run just fine other than a very slight hesitation my wife reports. So slight I can't even detect it, but I don't drive the car full time.
I've seen some talk about a clogged intake. I've seen the cleaning done at a GTG and it didn't look fun so I'd sure like to really know that's the issue before pulling it apart.
Rick
Old January 4th, 2012, 10:36   #3
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
from the Ross Tech WIKI-
16485/P0101/000257 - Mass Air Flow Sensor (G70): Implausible Signal
Possible Symptoms
Loss of Power
Erratic Idle
Possible Causes
Mass Air Flow Sensor (G70) faulty
Air Leak(s) after Mass Air Flow Sensor (G70)
Intake Air Filter dirty/faulty
Ground Spots corroded or Paint Residue
Wiring and/or Connections from/to Mass Air Flow Sensor (G70) faulty
Possible Solutions
Check Intake Air Filter
Check Mass Air Flow Sensor (G70)
Check Ground Spots
Check Wiring and/or Connections from/to Mass Air Flow Sensor (G70)
Special Notes
In MY 1995-2002 (?) in Europe at VW-diesel-cars G70 had the bad reputation of slowly losing his performance, causing loss of power. It's not a matter of defective or breaking down, but it is filthy / dirty (not easy to clean). You can check functionality by making a log in [01-engine], [meas.blocks-08], group 003 (3e gear, full throttle, from 1700-4000rpm)
Old January 11th, 2012, 15:02   #4
wetskier2000
Yup, done everything on the list, still no joy,,, P0101 keeps coming back... Maybe I need a guru...argh...
Rick
Old January 13th, 2012, 19:23   #5
Dimitri16V
Dimitri16V's Avatar
just solved same issue on my PD. the wire from pin 4 in the MAF connector had an intermittent connection to ECU connector.
At the least , reseat the ECU connector . at most ohm out for continuity between both ends of wire
2004 Golf TDi 412K, 87 Rocco
2016 Toyota Corolla S
2016 Golf TSI ( reinforced metal oil pan , VCDS tweaks)
Aleksander Prokhorenko , Charles Keating ,Russian and US special forces KIA against ISIS. RIP heroes
Dimitri16V is offline   Reply With Quote
Old January 16th, 2012, 14:19   #6
wetskier2000
thanks, I'll check that... Do you recall the ECM pin? I 'spose I can RTFM, can't I? The ECM has been touched in this car when it was RC'd, but it was years ago... hmmmm... Could it be that easy? Here's hoping! thanks!
Rick
Old January 16th, 2012, 20:20   #7
Dimitri16V
Dimitri16V's Avatar
pin 40 on big T94 pin connector. it should have a red/green wire on it. make sure you count the pins in the right direction to locate pin 40. it is supposed to have continuity with a pin in the MAf, i think it's 4, but check for the same wire color.
It could also be a loose T94 connector or pin 40 may be damaged. make sure the T94 engages and locks in place
Old January 17th, 2012, 05:57   #8
wetskier2000
Thanks! I pulled both connectors last night, cleaned them a bit and used some dielectric grease. (hopefully it likes that). I could not find the pinout in the FM so I closed it back up and reset the MIL. I'll check continuity next if it comes back.. thanks for the pin numbers...
The connector seemed to go back just fine and the lock seemed to work..
Rick
Rick
Old January 18th, 2012, 10:00   #9
wetskier2000
I stumbled onto the PO0101 thread about stuffing the MAF connector with dielectric grease. I tried that last night... We'll see what the wife reports.
Rick
Old January 18th, 2012, 15:25   #10
Dimitri16V
Dimitri16V's Avatar
Don't do that . these connectors are waterproofed by design.
Old January 23rd, 2012, 06:09   #11
wetskier2000
Default Intercooler??
Still no joy, ohmed out the connections just fine. Wiggling the wires didn't seem to matter. When following the bouncing ball that is the air input I notied that the right inner fender had a pretty big "pizza" slice out of the front section. Looks like it came loose and rubbed the tire. I wonder if something got thrown into the intercooler or its plumbing. I'll have to get it on the lift and take a closer look...
Anyone think this might be a PO0101?
thanks!
Rick
Old March 7th, 2012, 16:46   #12
Diesel Maniak
Diesel Maniak's Avatar
TDI(s): 74 Bug
same code here p0101
i have no loss in power or fuel economy
any updates on this situation ? same issue here , though i switched maf from my other bew to my wagon bew and the light came on after 2 hours of driving
only thing i see happening is the intercooler pipe on the egr side where the c clip is , the hose is coming off and i hear air escaping
so i ordered a kerma bew hose fix kit
i am gonna drive my jetta with the wagons maf tommorow morning and see if my jetta throws a code
Diesel Maniak is offline   Reply With Quote
Old March 7th, 2012, 18:19   #13
jetta ,97
jetta ,97's Avatar
Fuel Economy: Very good
Believe or not but recently I found that camshaft wear can do this.
I had BRM that customer was having same problem even with new MAF and new camshaft fixed problem.
I one more guy told me on his Beetle 2004 BEW it was a same thing.After cam replacement problem was gone.
I do any repair on all models,USED/NEW ECU and Cluster swap, Reprogramming Keys , Immobilizer Delete,Cluster LCD Dispay Repair -Clik here
I am trusted TDI Mechanic, VCDS
HEX+CAN
ECU TUNING-TDTUNING Authorized Dealer
MK6 Needle Sweep,MK5 with MK6 Cluster
jetta ,97 is offline   Reply With Quote
Old April 26th, 2012, 20:23   #14
Diesel Maniak
TDI(s): 74 Bug
thats an expensive fix
so far got a new clip and hose fix kit - the engine light dont come on anymore
Old May 4th, 2012, 21:58   #15
evolDiesel
evolDiesel's Avatar
Fuel Economy: FUELLY
Diesel maniak - did that kerma hose kit end up being the final solution?
Wetskier2000 - did you ever find the solution?
I have same situation, no power loss, recently installed a BoostLogic intake.
Jack
--> MY PORTFOLIO
evolDiesel is offline   Reply With Quote
CEL code P0101 straw10 VW MKIV-A4 TDIs (VE and PD) 9 July 30th, 2012 15:46
p0101 code maf or vaf teck3109 TDI 101 1 June 6th, 2010 04:12
code: P0101 or 16485 TDI-TT OBD Scanners 4 November 27th, 2007 06:00
Re-occuring P0101 Code scottab VW MKIV-A4 TDIs (VE and PD) 2 August 23rd, 2007 13:09
P0101 obd error code southherogrease VW B5 Passat TDIs 3 July 29th, 2006 19:30
Page generated in 0.16536 seconds with 10 queries
[Output: 134.14 Kb. compressed to 112.17 Kb. by saving 21.97 Kb. (16.38%)]
