Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > Other VW Group TD(I)s
Other VW Group TD(I)s To keep with the theme of VW Diesels, this message area is for discussion of other VW Group Diesels. Yes, TD's are also welcome.
Old January 2nd, 2012, 12:58   #1
gmcjetpilot
gmcjetpilot's Avatar
Default Under Hood Insulation Coming Loose FIX!?!?
I used closed cell, blue ridged insulation, cut in strips of various lengths. It is just wide enough to fit, held in by interference with the slot in the hood. I'll let you know how it works, but insulation hanging down not acceptable. ANY OTHER IDEAS? I was going to take it down and glue something ridged to the liner to make it stay better, but this is the Beta version, MkI attempt.
gmcjetpilot is offline   Reply With Quote
Old January 2nd, 2012, 13:32   #2
Samcar222
Fuel Economy: 35-38 MPG town, 45-48 hw; {40 town, 51.6 hw w/ massive tailwind, 42.6/tank are records}
Interesting. Our JSW hasn't experienced this yet, but my MkV GLI has. I've wanted to remedy this, as it looks like an airflow sensor (going to the turbo) on my GLI has warn/burnt a hole in the fiber insulation :O
'10 JSW TDI-Moms-Salsa Red-DSG-rear side airbags-pano roof-mats/splash-buy back at 90k replaced with '17 Alltrack SEL, 23k, 25/36, tank in snow
'03 ALH Jetta Wagon 5mt 305k lots o' rust, will explode at any moment
'01 BMW 530iA-Dads-Anthracite-118k
Samcar222 is offline   Reply With Quote
Old January 2nd, 2012, 16:04   #3
Joe_Meehan
Joe_Meehan's Avatar
Fuel Economy: mid-upper 40's city upper 50's - low 60's Highway
I cleaned all the old foam from the plastic engine cover and put a couple of layers of Dynamat. It is a soft sound absorbing material easy to cut to fit. I has worked well for me. It is often used for audio systems.
Joe Meehan
2002 NB Silver Ohio BAA HUM
Joe_Meehan is offline   Reply With Quote
Old January 5th, 2012, 18:38   #4
MonsterTDI09
MonsterTDI09's Avatar
I just had both cars hood insulation replace under warranty.I had the same concern about air over the turbo.
2010 Jetta sedan TDI DSG Platinum gray metallic.Build date (5/10) Mods ----EV skid plate, E code head lamps, Polar FIS
A cleaning service for DPF. http://www.dpfregeneration.com/ I have no affiliation
MonsterTDI09 is offline   Reply With Quote
Old May 27th, 2012, 23:23   #5
epc
My Golf TDI after 65k miles has the same problem. The heat from the area between the firewall and the engine on the passenger side is making the mat floppy and unable to retain its shape, so the tab on the mat cannot stay inside the slot on the underside of the hood.
Any idea? I am thinking about yanking off the entire mat...
epc is offline   Reply With Quote
Old May 28th, 2012, 08:21   #6
MonsterTDI09
Try to get it replace under warranty a new one is around $100.They did change the design.If you take it off the may burn the paint on the hood.
The one thing that did work but it was a pain to get in with out scratching the paint.I used the metal spring end on a heavy duty clip the type that holds stack of papers together. I can post a picture if you need to.Come on over I can help you out.
Ps I had both replace under warranty.
Tom
Old May 29th, 2012, 01:34   #7
spyTDI
spyTDI's Avatar
Fuel Economy: 37 average, so far.
http://www.dynamat.com/products_car_...hoodliner.html
I've looked into this for my Karmann Ghia, but I suppose it would work just as well for the TDI. May be worth a look if you don't wanna bother with the OEM option, under the circumstances.
2001 Golf 2DR TDI (Gone, not forgotten)
.184's, DG Race pipe, Frantz Bypass Filter
(The new addition)
2010 JSW TDI, Salsa Red, 6 Spd
H&R Rear sway, DG Short Shifter
spyTDI is offline   Reply With Quote
Old May 30th, 2012, 19:17   #8
epc
Tom
I have over 65k miles. I highly doubt they will warranty the mat. Could you post the part number of the new mat they gave you?
Old May 31st, 2012, 07:21   #9
MonsterTDI09
The part number 1k0-863-831-D Sound ABS.
Tom
Old May 31st, 2012, 12:36   #10
veedubfreak
TDI(s): 2011 golf
My 04 GLI did this. I was able to take the clips out and expand them a bit more to hold it in, but it still had a few spots that liked to fall over the clips.
veedubfreak is offline   Reply With Quote
Old August 20th, 2013, 17:05   #11
Scorpo900
Scorpo900's Avatar
TDI(s): Golf 2011 4D
Fuel Economy: 45 mpg
I'm working on designing a retainer bra for it. for real! A few strips of metal band from front to back and a cross member in the center all welded together. The bra will be supported in the same support ports of the factory mat with rubber or similar brackets. Not even have a design yet. Will post progress.
Scorpo900 is offline   Reply With Quote
Old August 26th, 2013, 19:56   #12
Scorpo900
Scorpo900's Avatar
Done. :-)
Sent from my AT100 using Tapatalk 2
Old August 29th, 2013, 18:02   #13
gmcjetpilot
Originally Posted by Scorpo900 View Post
Done. :-)
Nice Scorpo900.... clean looking.....
Old January 2nd, 2014, 08:45   #14
gloaming
gloaming's Avatar
Fuel Economy: 25-35mpg city and 45-55mpg highway.
Has anyone just tried some glue? Mine is coming loose as well on the drivers side and it looks like it was factory glued with some type of adhesive. I wonder if crazy glue or Aileens craft glue will work? Though the craft glue will probably just melt under any type of heat circumstance
gloaming is offline   Reply With Quote
Old January 3rd, 2014, 17:01   #15
gmcjetpilot
The back is fuzzy soft fiber like house insulation. You can't glue it. It would just bull the fuzzy insulation off. You could glue some nylon posts to the metal hood and push through insulation. You then would slid some kind of snap onto the post. I have looked at the auto part stores and they have stuff that is close.
Hood Insulation? MonsterTDI09 VW MKV-A5 Golf/Jettas 33 March 19th, 2014 13:25
Under hood insulation vwmk4 TDI 101 2 December 31st, 2011 14:04
Hood Insulation MkVer VW MKV-A5 Golf/Jettas 6 September 26th, 2011 06:44
How important is the insulation under the hood? Oblio13 General Automotive 6 December 3rd, 2009 21:21
Hood Insulation TDIray VW MKIV-A4 TDIs (VE and PD) 2 December 17th, 2005 12:05
Page generated in 0.17583 seconds with 10 queries
[Output: 127.37 Kb. compressed to 105.77 Kb. by saving 21.59 Kb. (16.95%)]
