Old January 1st, 2012, 19:01   #1
OldGrayOwl
TDI(s): 2002 Jetta
Default Transmission Shudder
I have a 2002 Jetta TDI with auto tranny. It is shuddering slightly at about 40 mph.
Has anyone tried Dr. Tranny Instant Shudder Fixx in these?
I have used it in my 1999 Ford F-150, and it completly elementated the classic Ford shudder.
Thanks,
John
OldGrayOwl is offline   Reply With Quote
Old January 2nd, 2012, 05:27   #2
rt_hawk
rt_hawk's Avatar
Fuel Economy: 40-TDI, 14-7.3 PSD, 32.9-Triumph
I'd trust the lubegard platnum additive over any others. Oreillys is one place that sells it. It too will help with shudder, that is, if it isn't something more serious, the 01m is a finicky thing. How many miles on your 01m? When was the last time the fluid was checked/changed?
-Sean - I have vag-com
-08 F-250 6.4 CCSB, dpf-del., h&s, DIY-CAI, diy egr delete & coolant bypass.
-06 Jetta TDI GLS DSG, 100k, DIY zerostart heater, tune and egr delete soon...
rt_hawk is offline   Reply With Quote
Old January 2nd, 2012, 11:29   #3
OldGrayOwl
TDI(s): 2002 Jetta
Lubeguard is the company that makes the Dr. Tranny.
It has 216K on it and as far as I know, it hasn't been /checked/changed. I thought that after about 100K, if you didn't change the auto transmission oil, you don't do it.
Last edited by OldGrayOwl; January 2nd, 2012 at 11:31. Reason: Add comment about Lubeguard.
Old January 2nd, 2012, 14:54   #4
rt_hawk
rt_hawk's Avatar
Didn't know that about dr. Tranny. VW calls the 01m a lifetime fill, but fluid analysis shows that fluid changes every 40 to 50k should be the norm. The 01m sheds lots of wear metals. I would change the fluid and filter. It will also give you a better idea if anything is about to break (metal in pan). I think there is a write up in the "how-to's". Good luck!
Old March 23rd, 2012, 19:44   #5
OldGrayOwl
TDI(s): 2002 Jetta
Talking
Well,
I had the tranny fluid changed and added the Lubegard Platinum additive. and it smoothed out the transmission. No more shudder. The fluid was almost as black as the oil in my diesel engine!!
It is a LOT better now.
Old March 23rd, 2012, 21:50   #6
shuswap
Originally Posted by OldGrayOwl View Post
Well,
Thanks Grayowl. Keep us posted if anything changes, will you?
shuswap is offline   Reply With Quote
Old March 24th, 2012, 06:36   #7
rt_hawk
rt_hawk's Avatar
Great to hear!
Old August 11th, 2012, 11:04   #8
OldGrayOwl
TDI(s): 2002 Jetta
It's been 5 months, and it is still shifting nice and smooth. the transmission now has about 235000 miles on it.
Old August 11th, 2012, 17:48   #9
rt_hawk
rt_hawk's Avatar
Good to hear!
05 passat transmission shudder ulooknatme VW B5 Passat TDIs 13 February 17th, 2011 21:37
transmission shudder Zanzibarbob7 VW MKIV-A4 TDIs (VE and PD) 6 September 3rd, 2009 14:58
transmission shudder Razooki Ontario 5 May 19th, 2008 17:27
Manual Transmission Clutch shudder seattlemagnum TDI 101 4 August 13th, 2006 14:44
Manual Transmission Clutch shudder seattlemagnum VW MKV-A5 Golf/Jettas 5 August 7th, 2006 18:10
Page generated in 0.17399 seconds with 10 queries
[Output: 90.05 Kb. compressed to 76.78 Kb. by saving 13.28 Kb. (14.74%)]
