Go Back   TDIClub Forums > VW TDI Discussion Areas > General Automotive
General Automotive General automotive discussion. This is intended to be a discussion about other not VW and Diesel cars you may have or interested in.
Old December 30th, 2011, 18:23   #1
tdidieselbobny
tdidieselbobny's Avatar
Default '06 Pontiac Grand Prix no heat...continue w/Dexcool or use another?
2006 Pontiac Grand Prix,151k (assume original coolant).Back in Nov. I noticed the temp gauge barely moved after 10+ miles driving,and no heat coming from vents(digital climate temp.gauge,set on 90 degrees).Figured thermostat-changed that and bled air out-temp gauge moves normally,then see it drop once it reaches certain point,plus getting heat out of vents-good-problem fixed(or so I thought). No coolant smell inside car. I haven't checked the hoses going to heater core yet for temp....I know I need to change coolant-probably take it somewhere that will hook machine up and flush system.A couple questions-should I try to flush the heater core out first before taking it somewhere,or do those machines they hook up do a good job of getting crap out of system? Second-should I have it refilled w/ Dexcool after flush,or switch to another type of anti freeze for the fill(any particular brand?) TIA for any help!
97 Passat TDI-420,688 miles,totalled by 86yr.old lady-gone,but not forgotten-'15 Silk Blue Golf Sportwagen w/DSG, 23k miles....'16 Kubota BX1870 MMM/FEL, 100hrs!And now an '03 Jetta TDI 5spd w/ 420k,RC2,Sprint 520's,Dieselgeek short shifter and oil bypass, and a few other goodies....
tdidieselbobny is offline   Reply With Quote
Old December 31st, 2011, 06:12   #2
PDJetta
PDJetta's Avatar
I went through the Dex-Cool fiasco with my wife's Buick. Chances are the Dex-Cool has sludged and plugged your heater core. Can you feel the coolant hose to the heater core? If so, it should be nice and hot at engine operating temperature with the heat on. Have the heater fan on high and after a few minutes of driving, stop and feel both heater core hoses. If the hoses are both quite hot, I would suspect a plugged core. I do not know if you can clean out the core if plugged, or if it needs replacing.
On ours, I caught it before this happened. The lower intake manifold gaskets were just starting to weep and sludge was just starting to build up. As part of replacing the lower intake gaskets, I flushed the system and replaced the coolant, using Prestone orange, 5-year coolant. I forget what its called, but it is the Dex-cool compatible replacement. End of issues.
BTW I think by the '06 model year GM solved the faulty lower intake manifold gasket problems on their V-6 engines (the Buick is an '01). Still, you could have sludging issues, though. What does the coolant bottle and radiator cap and neck look like? Any sludge in there?
--Nate
Old December 31st, 2011, 10:32   #3
jgeorge
When you have your cooling system flushed, don't use a chemical flushing agent- asking for trouble.
jgeorge is offline   Reply With Quote
Old December 31st, 2011, 10:51   #4
whitedog
So what kind of "trouble" would a person expect if, Hypothetically, that dog... er Person used a chemical flush on say, a Duramax?
Just wondering...
Can fold paper in half eight times.
Old January 5th, 2012, 08:52   #5
Thermo1223
Air infiltration makes Dex-cool sludge so check for any intake manifold leaks as suggested but IMO no coolant is good for 5+ years. I personally set on 4 years unless you do rack up 100k+ miles in that amount of time.
Yes back flush the heater core & the block, chemical coolant flushes don't harm anything but they could push a slightly leaking gasket over the edge. Face it if the gasket was leaking it needed to be changed anyway.
Gone
00' Jetta 5M - '04 JW A5 - 09' Forester XT
New Blood
'16 Tiguan
Thermo1223 is offline   Reply With Quote
Old February 4th, 2012, 19:22   #6
tdidieselbobny
Update..... finally had the system and heater core flushed today. They said they got alot of chunks out when they flushed the heater core-I now have heat!!! There was no sludge buildup in tank or radiator neck before it was flushed.
Old October 14th, 2012, 08:00   #7
tdidieselbobny
Well,back to square one. Temp set on 90,barely any heat(according to wife). Don't see sludge on cap or overflow.I'll take it it for a spin and see how the heater core hoses feel. Waiting to get another estimate for core replacement-first one was about $420 + tax for core replacement and flush.The Grand Prix forum says the core isn't too buried on pass. side(2006 model). Bad enough the B4 has crappy heat(foam delete)......
Grand-prix a Montreal loudog Quebec 5 June 8th, 2008 20:20
OT: Formula 1 Grand Prix in Montreal OmegaRenegade Ontario 14 June 5th, 2008 16:43
Indy Grand Prix GolfUberAlles General VW Discussion 2 July 5th, 2006 06:25
Allsports Grand Prix this Saturday? snoopis Eastern USA 9 March 13th, 2004 12:29
Pontiac Grand Prix Fan Switch eschady General Automotive 2 July 28th, 2003 07:22
Page generated in 0.14675 seconds with 10 queries
[Output: 84.71 Kb. compressed to 73.94 Kb. by saving 10.77 Kb. (12.72%)]
