Old December 28th, 2011, 10:24   #1
josh8loop
josh8loop's Avatar
Fuel Economy: 45 MPG City with the previous 01M, 5-speed 60+ MPG City. Always searching for ways to make it better!!
Default After car is shut off, I have a groan/vibration coming from drivers floorboard....
Fellas,
As the title suggests, after the car is shut off, I have a groan/vibration coming from the drivers side footwell/fire wall area. I notice it when I shut the car off, and remain seated in the car for a little while gathering my stuff. It subsides after 10 seconds or so. Seems like it could be vacuum system related-perhaps a damaged check valve or damaged vac brake booster. Anyone have any experience with this? Thanks!
2002 VW Jetta TDI 5-speed(completed 01M-5-speed swap at 155K miles) 60+ MPG City.
Experimenting with the "Hybrid" 205 Deg F T-stat:
http://forums.tdiclub.com/showthread.php?t=306799&page=4
Now have Nokian Entyre Low RR tires!
josh8loop is offline   Reply With Quote
Old December 28th, 2011, 12:05   #2
tyrone shoelaces
Guest
push down the brake pedal while engine is running, remember how hard it is to push down, shut off your car, wait for it to make the sound and subside, then try pressing the brake pedal again, is it harder to press down then while the engine is running? if so then it is most likely your booster or a line to it is leaking and not holding the vaccum in, it is a standard when manufacturing vehicles that the booster should be able to hold enough of a vaccum so that if your engine was to stall that you should be able to get three to four good braking events out of the vehicle with the engine off, and the boosters are supposed to hold a vaccum for X amount of minutes without losing the vaccum it has stored.
Tyrell
Old December 31st, 2011, 16:24   #3
josh8loop
josh8loop's Avatar
Tyrell
It seems as though I can pump the brake a good four or five times after the car is shut off, and I still have vacuum brake assist. After the vacuum bleeds off, the brake pedal once again gets hard as expected. I know my vacuum system regarding vacuum lines and all is good. I have in the past replaced all the lines, resealed the vacuum pump outlet nipple, and repaired/replaced larger lines going to the brake booster. Only question now is if the vacuum check valve is having issues and oscillating intermittently when the system bleeds down. I will have to monitor things over time to come to a conclusion on this. I will give updates as I get new info.
Old December 31st, 2011, 16:49   #4
jgeorge
does the groan- vibration change in pitch or intensity when you step on the brake pedal ?
jgeorge is offline   Reply With Quote
Old December 31st, 2011, 17:11   #5
josh8loop
josh8loop's Avatar
Well, never though to check that when it was happening. That is a good idea, and one I hope to look into soon. Although it is somewhat intermittent and hard to catch.
Drivers door won't shut most of the time jella01 TDI 101 39 May 15th, 2014 19:05
whats under the drivers side floorboard? schnauzer VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 10 October 18th, 2010 15:15
Strange Drivers Side Tire Vibration PharoahTDI Ontario 7 March 11th, 2009 19:03
Vibration coming from wheels ! VOLKSWAGEN_JETTA_TDI VW MKIV-A4 TDIs (VE and PD) 10 December 4th, 2008 04:42
2001 Golf Engine Shut off Vibration bahiaeternal TDI 101 3 April 6th, 2008 11:25
Page generated in 0.14579 seconds with 10 queries
[Output: 72.14 Kb. compressed to 64.14 Kb. by saving 8.01 Kb. (11.10%)]
