Old December 26th, 2011, 21:54   #1
tothemax
tothemax's Avatar
Default How can tell if my water pump stopped pumping?
Car overheated a cpl times when pushing her hard..... noticed the fans will not come on without turning on the AC.... noticed the top water hose going to the radiator is super hot but the bottom hose is cold.
How can tell if the water pump stopped pumping?...
Noticed temperature goes to the 205... 210...range.. at times
The fans both work if the AC is switched on but not otherwise.... I bypassed the fans at the temp switch.. .they both came on... thought it was the switch... changed the switch .... still no fans working after changing out the switch ..
then I changed the thermostat... still no fans working..
The heater in the cab seems to work fine and I get plenty of heat from there....
There does not appear any flow into the expansion tank when the engine is running...
I am suspecting the water pump failed but not 100% sure ... is there a way to find out for sure if it is pumping or not?
Another 20,000 mi or so to the next TB change.... so maybe it's time to change the whole thing our early?
You thoughts?
tnx
tothemax is offline   Reply With Quote
Old December 26th, 2011, 21:57   #2
gquenstedt
Best way to confirm is take out the thermostat and try to spin the impeller with your finger. It should not spin.
Check out my website: www.gqlaw.us
gquenstedt is offline   Reply With Quote
Old December 26th, 2011, 22:06   #3
Ski in NC
Fuel Economy: 48-52 typical
Open cap on plastic coolant bottle. With engine idling, the top hose should be dribbling coolant into bottle. Get someone to rev motor, dribble should turn into a stream. No flow there and likely impeller is slipped.
2001 Jetta TDI 5sp Stock 201k mi
1981 Rabbit IDI 4sp Sold at 339k mi
1990 S-10 4.3 4wd 5sp 154k mi
1986 VW Pathfinder 1.6 45hp Marine 4700 Hrs
2001 Cummins 8.3 420hp Marine 1660Hrs..REFIT DONE!!
Ski in NC is offline   Reply With Quote
Old December 27th, 2011, 04:23   #4
chrisfiat
TDI(s): 97 jetta
Fuel Economy: 48
will over heat very quickly at idle or on the road
third diesel, 97 tdi jetta 210000 50mpg avg
vag-com, ase master
i am the diesel tech at duponts service center
1976 Fiat 124(you know the top goes down)
chrisfiat is offline   Reply With Quote
Old December 27th, 2011, 06:03   #5
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
Yeah, shoulda checked that impeller while you had the 'stat out.
oilhammer
www.cardocautomotive.com
Old December 29th, 2011, 19:46   #6
tothemax
tothemax's Avatar
It does not overheat quickly while on idle but if I push is super hard... like in racing.. it does.. also jsut driving it on the freeway normally, it gets up to the 200 to 205...
Also another dumb question... can the pump fail slowly where it still pumps but not as strong as it should? or does it fail suddenly like ... is there only two case .. either it pumps or it does not?
I plan to take the thermostat out again this weekend to check the impeller but would like to know the answer to the above question... I did the test of looking into the expansion tank while someone else is revving the engine and I did see an increase in flow into the bottle but it still appeared pretty weak and there was a lot foam/ small bubbles in there...
It did not look a like a strong flow ... not really sure what it should look like... I guess I should check on my Golf to see what a normal flow looks like... I will as soon as my boys come back w/ the Golf...
Old December 30th, 2011, 05:35   #7
mlemorie
TDI(s): 2004 Jetta
Fuel Economy: Avg: 43-44
To make it easier I usually pull the return line off the bottle and hold it over the opening while I have someone start the car and rev it. It makes it a lot easier to tell just what kind of flow you are getting. I have seen a few pumps that cracked around the inside ring where it mounts to the shaft. They would still spin and pump fine at lower RPM ranges, but once the RPM came up and they started spinning faster they would start to slip. Although usually the whole thing just breaks apart.
I have VCDS and plenty of tools.
mlemorie is offline   Reply With Quote
Old January 3rd, 2012, 10:48   #8
rocketeer928
rocketeer928's Avatar
Did you have a chance to check out the water pump's impeller last weekend, Pierre?
2003 Jetta GLS TDI with RocketChip RC5-ASV-Euro tune specific to my performance modifications - Platinum Gray
yo
rocketeer928 is offline   Reply With Quote
Old January 3rd, 2012, 11:02   #9
DanG144
If it is reliably keeping your cabin heater pumping out heat, I don't see it being the water pump.
The water pumps can fail such that they slip intermittently. They will tend to slip more when hot.
When you say the car overheated, what temperatures were you seeing? What were you reading them on? 210 on the head outlet temperature pushing it hard is normal, in my opinion.
But remember the gauge is computer driven; it reads centered (90C or 190F) over a wide range of temperatures - about 167 F to 225 F. So as soon as it goes up off of center it is already at 226F, not 191F.
The fans are typically turned on by the radiator thermoswitch which is halfway down the radiator; if you have any breeze across it the fans will rarely come on as it has cooled below the fan setpoints prior to getting halfway down the radiator.
Bentley fan operating points, from the radiator thermoswitch:
low speed
on - 197-206 F (92-97 C)
off - 183-195 F (84-91 C)
Fast speed
on - 210-221 F (99-105 C)
off - 195 - 208 (91-98 C)
Old January 20th, 2012, 00:02   #10
tothemax
tothemax's Avatar
I did check and it's tight so I assume it's working... still can't get my fans to get going... oh well .. .just have to not race any more Audi's and I'll be fine..
Old January 20th, 2012, 05:41   #11
dan kerkstra
Fuel Economy: unk trans is on floor
Just my 00.2 , due to age make sure the radiator isn't limed up onthe inside restricting the flow, had my dodge diesel start to overheat each time I put it under load, put in a new radiator fixed the problem, long shot, but acted the same as your.
dan kerkstra is offline   Reply With Quote
Old January 20th, 2012, 06:08   #12
DanG144
I have also seen radiator heat transfer restrictions. The interior passages were clean and open, the exterior looked fine, but corrosion from a salt environment (Hawaii) had caused poor heat transfer at the fin to tube junction.
water vs plastic water pump video leicaman TDI 101 56 July 15th, 2016 11:44
water pump maniaq TDI 101 1 March 29th, 2010 06:39
Injection Pump Leaked Then Stopped terrydtdi TDI 101 4 July 15th, 2009 13:12
Injection pump not pumping? jconnelly TDI 101 7 March 2nd, 2007 15:41
Stretch Bolts for water pump/ water pump change. Vinyl_Addict TDI 101 7 July 11th, 2006 09:11
Page generated in 0.13596 seconds with 10 queries
[Output: 112.52 Kb. compressed to 95.29 Kb. by saving 17.23 Kb. (15.31%)]
