Old December 23rd, 2011, 10:08   #1
STRANGETDI
Default 2012 Golf: How do I remove the front grill...
I removed the 4 torx screws on top, but it does not seem to want to come out. Not putting too much pressure on it as I don't want to break anything. Am I missing something here? What else do I need to do?
Changing the VW emblem to a glossy black.
Chris
CURRENT: 2012 GOLF w/ TECH, 4DR, 6SP MANUAL, 116K miles
OLD: 1999.5 Golf GL TDI,Up'd,.216s,17 OZ Rims,Eibach Pro-Kit&Dampers,TT SS 2.5" Exst. 222,000 - Sold to Rossman83
STRANGETDI is offline   Reply With Quote
Old December 23rd, 2011, 10:15   #2
Softrockrenegade
Softrockrenegade's Avatar
I believe the emblem just twists and pulls off ! No need to remove the entire grill ...
Softrockrenegade is offline   Reply With Quote
Old December 23rd, 2011, 13:49   #3
STRANGETDI
I heard that too, but it doesn't seem to want to turn. It also has been said that it is easier if you remove the grill so you don't risk breaking anything on the emblem.
Chris
Old December 23rd, 2011, 14:03   #4
STRANGETDI
Got this off the golfmk6.com forum:
It can be done just by turning the emblem counterclockwise and pulling it out but if you don't want to brake any of the emblem clips you have to remove the upper grille first.
1) Remove the upper grille ( 4 T25 torx screws off the top of the grille assembly, then press the top of the bumper down, and at the same time pull the grille gently up and out.
2) Turn the emblem counterclockwise (about 20 degrees, you should hear a click) You have to turn the emblem first to align its clips with the “slots”.
3) Turn over the grille
4) Push down the bottom of the net (there are 2 clips holding it on the bottom)
5) Push and slide down the “net” just a little (there are 2 more clips holding it on the top)
You can also do it in a different order #4 and 5 first and then #1 (turn the emblem while watching the clips on the back) if you are afraid you can brake them.
6) Use a small screwdriver or a paint can opener (it has a small hook and it will be easier to pull the clips)
7) Find one of the clips and pulling it toward the center of the emblem, pull down the emblem at the same time (first make sure that the clips are aligned with the “slots”). If not align them first by turning the emblem to the left or right a little.
8) Do the same for the second clip. Usually that’s enough to remove the emblem but you can do it with the third one, too.
9) Put back the “net”
10) Put the emblem back
11) Turn it clockwise to align it (you will hear a click)
Chris
Old December 23rd, 2011, 16:20   #5
ToeBall
If you're trying to remove the emblem, it twists. If you're trying to remove the whole top grill, then remove the torx screws along the top and pull the grill straight forward. I usually start at one side so the clips come out easier.
2010 VW JSW TDI "Barley", 6-speed manual, Blue Graphite - 255/40's on 18x8's, Sigma6, B&M Shifter, Malone Stage 2, Koni coilovers w/H&R springs, 28mm front/27mm rear swaybars, GTD Grill, 900W stereo, PDE downpipe, Banks exhaust, APR intake, Votex kit.
ToeBall is offline   Reply With Quote
Old December 23rd, 2011, 20:01   #6
STRANGETDI
Here's another link for removal:
http://www.vwgolf.net.au/showthread....Bumper-Removal
another link:
http://myfastgti.com/volkswagen/thre...6-front-badges
and another link:
http://forums.vwvortex.com/showthrea...ler-on-MK6-GTI
Chris
Old December 7th, 2015, 21:31   #7
ricks
ricks's Avatar
Fuel Economy: 38ish mixed, 49 highway
Twisting mine was next to impossible. The direction is counter clockwise. Maybe the liberal application of WD40 would have helped. Instead I removed the front grill and broke off two of the three clips. No worries since I had a new black badge which rotated snugly into place.
Rick S, '10 JSW TDi, '71 914-6 3.0
ricks is offline   Reply With Quote
removing front grill on my Mk 6 Golf TDI tdiPT VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 3 July 10th, 2010 04:49
Front grill falling apart on anyone else (lower front bumper grill) on 2010 Golf TDI ibid VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 6 May 10th, 2010 11:28
[WANTED] Front Grill Golf G4 (Home Made) metavox Private TDI Items for Sale/Wanted 0 March 28th, 2010 03:48
How to remove/unclip front grill? CSM Jetta VW MKIV-A4 TDIs (VE and PD) 2 May 30th, 2009 19:00
Wanted: 2000 Golf small front grill rmr25 Private TDI Items for Sale/Wanted 0 November 15th, 2002 17:29
Page generated in 0.12479 seconds with 10 queries
[Output: 81.61 Kb. compressed to 70.75 Kb. by saving 10.86 Kb. (13.31%)]
