| TDI Power Enhancements Discussions about increasing the power of your TDI engine. i.e. chips, injectors, powerboxes, clutches, etc. Handling, suspensions, wheels, type discussion should be put into the "Upgrades (non TDI Engine related)" forum. Non TDI vehicle related postings will be moved or removed. Please note the Performance Disclaimer. |
December 20th, 2011, 12:24
#1
mtdi nozzle pressure?
hi, i have vw 1.9tdi arg engine and gtb2260vk+lr 300tdi pump. 0460414089 11mm head.
what is good pressures injection nozzle 0.260 this pump.?
this is link to injection, http://www.dieselkontor.de/product_i...oducts_id=3093
sorry bad english.
December 29th, 2011, 05:54
#2
any info?
what open pressure works?
nozzle seller say 250-300 bar?
December 29th, 2011, 14:31
#3
on hiatus
I have samples of those nozzles, not very impressive. High leakage rates between the needle and nozzle, poor spray patterns, poor ejection and dispersion.
The pressures will vary depending on that nozzle types ejection characteristic, and desired injection window, usually this will be determined when being mounted in the test cell in respect to custom flow nozzle types of unknown origin.
December 30th, 2011, 13:32
#5
look for bosio race 520 it's bigger than pp764
pop on 220-300bar
208hp/450nm smoke free
VVT tune!!
