Go Back   TDIClub Forums > Classifieds/For Sale/Wanted > Private TDI Items for Sale/Wanted
Private TDI Items for Sale/Wanted VW TDI/Diesel related items for wanted and for sale by private individuals. Group Buys and commercial posts should be in the "Vendor & GroupBuy" section.
Old December 20th, 2011, 08:38   #1
orion2.0
orion2.0's Avatar
Fuel Economy: 50mpg
Default D24 intake manifolds!
Hi all. I am looking to see if there is any interest in d24 intake manifolds modded to fit the TDI. These manifolds have a 3" plenum and long smooth equal-length runners.
A couple years back I adapted one for my ALH and loved it...so I bought up the other ones I could find. These will be cleaned, cut, welded, and "D" ported to match the tdi intake ports. The inlet can be made on either the driver or passenger side.
I am looking to get $350 for a finished manifold.
orion2.0 is offline   Reply With Quote
Old December 20th, 2011, 08:48   #2
orion2.0
orion2.0's Avatar
Fuel Economy: 50mpg
here is a link to an old thread with pics
http://www.fastdubs.org/forums/showt...274#post119274
Old December 20th, 2011, 09:24   #3
Got Bearings?
Got Bearings?'s Avatar
Fuel Economy: 36 / 50
I would love to dyno one to see if it makes power.
The New Commuter Car: 2009 Cadillac CTS-V 556 HP, 6.2L Supercharged V-8, 6 speed manual
The Old Commuter Car: 01 Golf GLS TDI WRECKED AND GONE!
The Slow Car: 95 Impala SS 383, 6 speed, 391HP , 440TQ
Looking for Battery Cables, better & cheaper than OEM? Click here for info
Got Bearings? is offline   Reply With Quote
Old December 20th, 2011, 09:37   #4
bikerboyriley
bikerboyriley's Avatar
Fuel Economy: 46 mpg
WOw looks nice! Tempting..
bikerboyriley is offline   Reply With Quote
Old December 20th, 2011, 13:48   #5
orion2.0
orion2.0's Avatar
Fuel Economy: 50mpg
honestly I would love to see a before and after dyno to see exactly what gains it yields... obviously its relative to other mods and fueling.
An underfueled engine would probably see no gains. An overfueled (smokey) car would see noticable gains due to improved airflow and more complete combustion.
Personally, I dont like a smokey car. My car already had more airflow than fuel when I installed this manifold so I didnt notice much of a gain. But, now I can push more fuel before i get smoke. It obviously flows much better than a stock alh or even a PD manifold.
I think this would really compliment a ported head with cam (which I plan on doing).
Old December 20th, 2011, 13:49   #6
Johnny_Law
Johnny_Law's Avatar
TDI(s): 2003 Jetta
I am interested, but will your set up work with this turbo intake pipe:
http://www.idparts.com/catalog/produ...roducts_id=981
Obviously I will need to adjust the mounting points for the OMI, but I just want to make sure there is enough clearance between the intake and firewall and no massive kink from the MAF to the inlet of the OMI.
Thanks,
Johnny_Law is offline   Reply With Quote
Old December 20th, 2011, 14:31   #7
OnePutt
OnePutt's Avatar
Fuel Economy: Highway - 47
+1
I've been looking for an upgraded IM for my car. The PD130/150 IM is the most common upgrade out there. Any idea or thoughts on performance gains on this unit? I know it's tough to say because every car is modded differently.
What differences have you noticed in drivability between the stock IM and your D24 IM?
-= Silver | 2001 | Golf | 4 door | 140k | WHP 155 (with VNT17, .216 nozzles & stock IC) =-
Installed - Santa Monicas - Recaros - Panzer plate
- 6 speed (01M > 02M) w/ LSD - 3 bar - Sport interior - Alpine deck w/ Polk components - R32 stuff - 17/22 - EJ FMIC - OMI -McNally Boost/EGT gauge - DG SS - 2.5 DP - Titan 502 - Malone Custom Tuned
Waiting for me in the garage/on the way - LOTS of goodies
OnePutt is offline   Reply With Quote
Old December 20th, 2011, 14:39   #8
orion2.0
orion2.0's Avatar
Fuel Economy: 50mpg
Originally Posted by OnePutt View Post
+1
I did not notice a big difference... the reason being I was already underfueled when I installed the manifold. Since I already had enough air vs fuel... more air didnt change anything.
Does your car smoke when you accelerate hard? Then you would more likely see improvement from one of these. Honestly, I think its something you should do to improve airflow AFTER head porting/cam upgrade. I think the head ports are a bigger chokepoint than the stock manifold.
I would like to invest in some dyno tests, however, I dont have enough manifolds to make it feasible. These suckers are hard to find.
Old December 20th, 2011, 15:25   #9
kenmaira
Are these passenger side in?
VAG-COM owner
2001 GL, Stage 2 Clutch, Lightweight Flywheel, Dieselgeek Racepipe, Titan 764's (.234) Ceramic brake pads, 11mm Injection pump IN! 10/30/2011, Bilstein TC Sports front & back!
kenmaira is offline   Reply With Quote
Old December 20th, 2011, 15:53   #10
orion2.0
orion2.0's Avatar
Fuel Economy: 50mpg
Thanks,
Im not 100% sure but I would say probably not. using this manifold will require some tinkering/custom work if you want to use the stock airbox. I know others have done it so it is possible.
I have a totally different intake which parallels the turbo-to-FMIC pipe and has the air filter behind the passenger side bumper vent.
These arent a quick plug and play manifold like the PD ones are.
Old December 20th, 2011, 15:57   #11
orion2.0
orion2.0's Avatar
Fuel Economy: 50mpg
I can make it either passenger or driver side inlet. The unmodded d24 manifolds are open on both ends so I can make it inlet on either side.
The current ones I have are not modded to work on a tdi yet...I am waiting until someone wants one before I make it for this reason specifically. I will make it to the buyers request.
Old December 20th, 2011, 16:24   #12
foxracer1
foxracer1's Avatar
Fuel Economy: Low34/Avg40/best54
How much unmodded shipped to 43616?
15Passat DSG SEL stock for now 33k mi
06 Jetta DSG 246k mi Malone stg2 egr cat delete 18" Audi Flat Fives got totaled and I bought it back. Soon to be fixed.
04.5 Ram 2500 Cummins 4x4 6spd crew cab short bed 174k mi
Vag-Com owner
foxracer1 is offline   Reply With Quote
Old December 14th, 2013, 15:16   #13
seanthom
Do you still have any d24 intakes available? Thanks! -Sean
seanthom is offline   Reply With Quote
WTB - D24 Intake Milage King Private TDI Items for Sale/Wanted 4 August 29th, 2011 17:38
FS: Modified D24 Intake CERBER Private TDI Items for Sale/Wanted 14 August 1st, 2011 07:27
pnp D24 intake and TIP fenwick458 Private TDI Items for Sale/Wanted 3 October 2nd, 2010 05:41
WTB: D24 intake Rub87 Private TDI Items for Sale/Wanted 6 June 10th, 2010 03:55
FS: D24 intake manifolds trocar Private TDI Items for Sale/Wanted 15 March 23rd, 2010 17:09
Page generated in 0.14762 seconds with 10 queries
[Output: 118.30 Kb. compressed to 99.82 Kb. by saving 18.49 Kb. (15.63%)]
