Old December 18th, 2011, 16:47   #1
GGK
Default Cheap way to drain fuel filter
I picked up a brake bleeder kit from harbor freight today, on sale for $17 and change. Had to use a small piece of larger fuel line to fit on the filter though but with accessories with the bleeder, all fit nicely. Took about 6 pumps and drained 3-4 oz from filter.....took only a few minutes....no water, clean as a whistle.
2009 Jetta TDI SEDAN DSG, Built 2/09
2008 Silverado D /A 3500 Dually
Gotta love those diesels
GGK is offline   Reply With Quote
Old December 18th, 2011, 17:39   #2
South Coast Guy
Fuel Economy: Good
You were draining the fuel filter for what reason?
South Coast Guy is offline   Reply With Quote
Old December 18th, 2011, 17:42   #3
Dodoma
most probably to send to the lab to test for water I guess.
Dodoma is offline   Reply With Quote
Old December 18th, 2011, 18:36   #4
DanG144
You need to remove the old fuel before putting in the new fuel filter.
I usually remove the canister and turn it upside down, then wash it with brake clean.
Old December 18th, 2011, 22:04   #5
ZiggyTheHamster
ZiggyTheHamster's Avatar
Easiest way ^^^
2009 VW Jetta TDI - Black w/ DSG Born: 5/2009
DSG Paddle Shift Steering Wheel
RCD-510 Stereo
9W2 Bluetooth
ZiggyTheHamster is offline   Reply With Quote
Old December 19th, 2011, 14:16   #6
GGK
Mine has the old style , the drain runs to the bottom, where water settles, easy way to keep water out and to check it once in awhile.
That way if the HPFP craps out, dealer can't say it was contaminated fuel...
Old December 19th, 2011, 14:39   #7
DanG144
That is a good filter style.
I used a large syringe and a small tube to pull the bottoms off of the one's that came in here.
I did something different to my own.
Improved fuel filtration
Old December 19th, 2011, 18:32   #8
Adrenolize
Adrenolize's Avatar
Just did my service on my 2006 Jetta. Is it critical to remove this fuel from the filter housing? I took the old one out and threw the new one in figuring that this was a good chance for the new one to pre-soak for better flow at cranking.
I'm knew at this, so be kind if I just jacked it up!
Adrenolize is offline   Reply With Quote
Old December 19th, 2011, 18:39   #9
DanG144
The fuel remaining in your housing is badly contaminated - dirty side mixes with clean side.
So it is good to clean it out before installing your filter.
But your filter o-rings scrub most of the dirty fuel and particles off the mount as it slides down.
Nothing to panic over.
Old December 20th, 2011, 17:28   #10
Adrenolize
Adrenolize's Avatar
Thanks! I'll try that next time around. I will try a turkey baster first before spending more money I guess.
I saw mention about the de-greaser wipe down after cleaning the fuel out. Is this necessary?
Old December 20th, 2011, 19:18   #11
DanG144
Depends upon who you talk to. Some people are more detail oriented than others.
I dump the canister into a clean glass, after removing it, and the quickest and easiest way to clean it is then a quick squirt of brake cleaner (not engine degreaser), letting it drain out.
I do this to see if any water droplets are in there. (None so far in 3+ years.)
As long as the center stalk is clean, the rest is not really required. Any dirt or dirty fuel that is trapped in the center of the filter will go directly to your injectors. The outside of the filter always has dirty fuel.
Fuel Filter Drain NickBeek TDI 101 12 January 25th, 2011 07:34
fuel filter drain no star after tigre TDI 101 2 June 20th, 2010 14:31
Fuel Filter/water drain manganos TDI 101 8 October 17th, 2005 16:54
fuel filter drain? tony d TDI 101 3 July 4th, 2003 10:20
help - fuel filter drain europeantdi VW MKIV-A4 TDIs (VE and PD) 0 October 2nd, 2002 01:25
Page generated in 0.14957 seconds with 10 queries
[Output: 97.70 Kb. compressed to 82.36 Kb. by saving 15.34 Kb. (15.70%)]
