| TDI Conversions Discussions on converting non TDIs into TDIS. More general items can be answered better in other sections. This is ideal for issues that don't have an overlap and are very special to swaping engines. |
December 15th, 2011, 16:40
#1
1983 Toyota 4x4 AHU Swap
Disclaimer: My first few posts will be copies from a build thread on another site.
Here is some information about what I am doing. The truck is a 1983 Toyota pickup. The engine is a AHU from a 1998 Jetta. Currently I am going to be running this truck as an M-TDI using a Land Rover 300 TDI pump. I am using an intercooler from a Volvo, as well as the radiator (both fit nicely in the Toyota). For the time being I will be using the stock K03 turbo. The truck has a w56 5 speed transmission with dual cases. The rear axle will have a locker when I am done. Here are some shots from when I started the project.
Its first bath in 2 or so years.
Old engine pulled, ready for the new power plant
Fitting the adapter plate
First test fit. As I imagined, I am going to have to remount the transmission because it is too far back. But as you can see this engine is way smaller than the 22r. I will have no problem fitting an intercooler and all the needed stuff in this engine bay.
More on the next post
December 15th, 2011, 16:42
#2
Well haven't got a whole lot done, but I have been doing a little cutting.
My plan is to have motor mounts built by the end of the weekend, along with possibly the transmission and duals mounted up, as long as I am able to get the transmission and duals from the two guys that I am buying them from. I ordered some puck style motor mounts and a full set of spring bushings so that I can install the new front springs that I had laying around. I am not going to lift the truck much or at all really, but currently the stock springs that are on the truck have sagged out like the majority of first gens. that I have seen and just want the truck to sit level.
I cut the stock mounts off the frame due to the fact that they were too far forward for this engine, along with the fact that I am opting to build from stage one instead of working around something meant for a completely different setup.
Furthermore, I decided to go with the w56 5 speed over the L series that was in the truck, due to the engine-firewall interference. The L series is 20.875 inches long, while the w56 is 25.5 inches in length. This means that I will effectively gain the needed firewall clearance without the need to do any modifications to the transfer case crossmemeber. One other advantage is that this extra length will allow me to route the exhaust from the passenger side, between the firewall and the back of the engine, out to the drivers side like the factory Toyota exhaust.
Well I guess that is enough rambling for now, here are some pictures.
I forgot to take my camera out in the shop last night so I do have a little bit more progress, although I do not have any pictures of it right now.
Once I have the transmission and the duals in my hands and get the motor mounts built, I should be moving a little faster on this.
December 15th, 2011, 16:43
#3
Once again i didn't get much done. I did however find myself a rebuilt w56, dual cases, hy-steer, IFS box and a detroit all in one shot. I had to drive to a town that I didn't even know existed, but that isn't an issue for me.
This is how all the parts came
First thing to come out
The only thing that it did not come with is a dual case crossmember. I am going to order one this week along with a front axle rebuild kit and some other misc. parts.
I am going to try to have the motor mounted in the truck by the end of this weekend, although I cannot promise that will happen. So far I have been failing myself on making any actual progress on this thing.
#4
Well I finally got a solid weekend to work on this project. My crossmember showed up on Friday, and I was able to get the transmission and cases mounted in the spot where they needed to be. After this was done i got to work building the motor mounts. By the end of the weekend I was able to finish the motor mounts and had the motor sitting in the truck with no hoist!
The passenger side of the 1.9L was great for building a mount off of. The drivers side on the other hand was a little bit of a challenge. After all was said and done I feel good about how they turned out. They feel solid and the engine/transmission/cases seem to line up good.
Here are some pictures
I had to relocate the mounting of the crossmember due to needed the engine to be placed in the engine bay differently than if it was behind a 22r. Not only that I put a w56 in place of the L series that came stock in this truck, meaning the transmission had gained around 5 inches in length. The supplied mount holes in the crossmember positioned the transmission about 4 inches to far forward. I ended up drilling a new set of holes to move the transmission back to where it needed to be. I made some plates so that it would still bolt to the frame in four places, although I do not have pictures of them.
Start of the passenger side mount
Frame side passenger mount
Complete Mount
Start of the drivers mount
Finished passenger mount
Frame mounting points
Underneath shot. I will be adding hy-steer and may have some pan/tie rod clearance issues. Nothing a custom pan cannot fix!
Thats all for tonight. I am going to install the OME front springs and start working on the hy-steer this week. Marlin is 2 weeks out on my parts to rebuild the front axle. I am also going to finish the sliders this weekend if I don't end up going to the beach.
December 15th, 2011, 16:44
#5
#6
Well the past week or so has been pretty busy, so not much work has been done. I did receive my parts from Marlin and Volkswagen on Friday, also I was able to pickup all my exhaust components so that I could begin building. I made it to pick-and-pull and found myself a few things.
Here are some pictures of what little I have been able to accomplish.... Which is basically nothing :shaking:
I chose an intercooler from a mid-80's Volvo. It basically resembles a cummins intercooler, with the exception of the plastic end caps. I don't necessarily like that they are plastic, but the availability is large so if something goes wrong I can find one easily.
Almost a perfect fit for a Toyota!
Don't mind the painters tape.... This is the mock up with the 22r radiator. I ended up buying the Volvo radiator and will be using it for ease of fitment and mounting. The fan setup will be from a 1995 Ford T-Bird. Its an 18" wind machine!
A/C-delete pulley for the AHU.
I had one 45* bend laying around to see how much firewall trimming I was going to have to do. Surprisingly 2.5" tubing will fit pretty good. My Plan was to run full 3", but decided to go with a 2.5" down pipe and 3" out to the rear of the truck. Due to the extra weight that this engine will be pushing I need the exhaust to flow in order to keep the EGT's in check.
December 15th, 2011, 16:45
#7
Well I'm home from school for a month now and this project is coming along nicely. Not going as fast as I would like, but I am making progress. Well enough talking, I'll get right to the pictures.
So my first intention was to use the Toyota radiator and the Ford cooling fan that I bought. Although, turns out since I was going to use the Volvo intercooler, I might as well use the Volvo radiator. The fit is amazing. I ditched the Ford fan and went with a slim fan and built an aluminum fan shroud.
Start of the fan shroud
Engine bay fitment
Used some threaded inserts to bolt the intercooler/radiator brackets into
More on the next post.
December 15th, 2011, 16:46
#8
Before I left for school I had nearly completed the downpipe. I had tached it all together, but never got around to finishing it. Because the VW exhaust exits on the passenger side, and the Toyota exited on the drivers side I had to make the downpipe cross from one side to the other, behind the engine block and between the firewall. Something like fitting a 2.5" diameter pipe through a curved 2.75" diameter path. Also, the part that is not so user friendly is the part that requires you to pull the engine in order to remove the downpipe from the truck. With all that said, I test fitted the downpipe to make sure there was no engine block/firewall contact. After finding that it all looked good it was time to weld.
All welded up
A little experimental TIG action. My camera sucks so I cannot take all that great of macro photos.
The downpipe worked out fairly well. This is a shot from under the truck where the downpipe will connect to the exhaust.
Another shot of the space that the exhaust needed to fit through.
I was planning on having the downpipe ceramic coated, but for the sake of time I decided not to, plus the cost. I will be wrapping it instead. The only issue with the that amount of heat in that location is the vac. pump. I will most likely build a heat shield for the pump so the plastic fitting doesn't melt. I might have to wrap the starter as well. The turbo sits really close to it and I don't want to melt it down.
The past two nights have been spent timing the engine. VW uses a mark on the flywheel, a hole in the bellhousing and a cam lock tool to time these engines. Well the Toyota bell does not have the hole so I decided I would make a new way to time this engine. I stuck a bolt in the lathe and made a nice pointer for the balancer.
I ground a little line in the balancer and painted it yellow so it should be easy to spot.
December 15th, 2011, 17:11
#9
From this point on the posts will be new material.
I didn't get much work done on the truck today. I ended up running around town buying up parts that I need to move forward with this project.
I ordered some Titan 764s for the truck today from Aaron @ Bora Parts. Amazing guy, and the service and prices are great. It's nice living in Oregon where I can drive across town and pick up the parts the same day. On my way home I dropped the nozzles and injector bodies off at DFIS in Portland to be installed and balanced. The new nozzles should help with power and decrease the amount of stress that the pump sees.
There will be more coming soon.
December 15th, 2011, 18:22
#10
I am just starting on this exact swap myself. I am looking forward to seeing how it goes for you.
Jaysin
December 15th, 2011, 18:39
#11
Fuel Economy: 34-39 b.m; 46-49 a.m.
Nice work man!!  ...i really like the rock sliders...was thinking of something similar for my truck, you're so going to love this thing when it's done
check out my for sale thread "The junk man cometh'!!!"
December 15th, 2011, 19:31
#12
Jaysin
I have seen alot of people (on the internets that is) doing Toyota TDI swaps, although I have never seen any in person. I cannot wait till I get to drive it. Should be fun. Good luck on your swap.
Thanks man. Yeah I kinda feel sliders are a necessary component even if you are not a hard core wheeler. I don't plan on wheeling this truck hardcore, but I plan on using it to camp and for trail runs. Like I mentioned before I highly doubt I'll actually use the dual cases but they were needed in this situation to make the swap work.
I cannot wait to start driving it. Once I know I like driving it and get some time on it and nothing goes wrong I will be tearing the engine down for a full rebuild and some more performance! More to come for sure.
December 16th, 2011, 13:51
#13
Fuel Economy: 00 NB-39, 01 Golf-41, 94 Toy-30
Nice setup. Gets me more anxious to start mine. Soon, very soon.
2000 Beetle, 5spd, RC2, Sprint520s,(daughter's 2nd new car)
2001 Golf GL 2dr, 5spd, TDTuning-Stg4, R520s, SBC Stg2-Endurance, 17/22, WhitBread DP, 3bar MAP
92 Dodge crewcab diesel(custom stretch) 4x4
94 Toyota Ex-Cab 4x4 (01 ALH) TDTuning-Stg4, PP764s, SBC Custom Clutch, 17/22, 3bar MAP
December 25th, 2011, 22:20
#14
Merry Christmas
Christmas day update:
So I things are starting to take shape, but the process has been pretty slow. I have made several trips around to find all the parts that I need.
I was able to get the oil filter adapter mounted and the lines made. I mounted the fuel filter and lift pump, and ran new rubber line. I am using a mkI fuel filter head and a lift pump upgrade for a 1996 Chevrolet 6.5TD. I planned on mounting the fuel filter in the engine bay, but I wanted to run the lift pump after the filter so that the fuel would be filtered before entering the pump. I was able to mount the filter and pump near the tank and it actually turned out better than I thought it would.
I modified the coolant neck at the back of the head allowing me to connect the heater core without interference with the firewall.
The last time I went into the shop I forgot my camera. I will get some more tomorrow; however, I was did get some pictures from earlier in the week and early today.
Today I finished welding up the passenger side motor mount because I for some reason had forgot to. I cleaned and painted all the motor mounts along with the fuel filter mount and oil filter mount. I pulled the engine and welded the downpipe flange on 100%. I sprayed the downpipe with ceramic high heat paint, baked it in our shop wood stove room and wrapped it with header wrap. When wrapping the downpipe I used the wrap wet so I could get a nice tight wrap. I will get some pictures of the wrapped downpipe tomorrow.
Well that is all I feel like typing now. Here are some pictures.
Picked up my new holes. These should help make a few more ponies.
Remote oil filter parts
The Mann filters are really tall. I had a hard time deciding where to put this thing. Where I ended up putting it should work really well.
Finished remote assembly
More on next post.
December 25th, 2011, 22:27
#15
As I mentioned above, I will have some more progress shots tomorrow or later this week. I am going to try to have the radiator plumbed by the end of the day tomorrow and hopefully be able to have the engine running by the end of this week.
Lift pump
New fuel system
Kind of a bad picture, but I was able to bend the existing Toyota fuel lines and make them work for this conversion. The fuel lines are about 1/4 inch, kind of small but I with the addition of the lift pump I should be able to move enough fuel to make the engine happy. If not I will upgrade to some 3/8 inch lines.
New coolant neck
Fits nice. I can even use the stock Toyota heater hose. I am however running the neck backwards. There is a slight mismatch between the hole in the head and the hole in the neck but it still seals and should work just fine.
Stay tuned.
