Old December 14th, 2011, 00:47   #1
Bob_Fout
Oil Wanker
Bob_Fout's Avatar
Default Switching to Rotella T6 5w40
Well well well, after flirting with some of the more exotic oils over the past few years (Mobil 1 0w40, Mobil 1 ESP 5w30, Redline 0w40) next oil change is going to be Shell Rotella T 5w40.
http://www.shell.com/home/content/rotella/products/t6/
http://www-static.shell.com/static/c...rotella_t6.pdf
2003 Jetta TDI (sold) / 2015 GTI 2.0T
Photos | Mods | CJ-4 Oils | Oil Analysis | Stage II Cam
Bob_Fout is offline   Reply With Quote
Old December 14th, 2011, 06:25   #2
jettawreck
jettawreck's Avatar
What took so long, Bob??
After a long break from Rotella, I too, am switching back. I was getting M1 TDT for less than T6 for quite a while with the rebate ($12 back on 5 qts), but M1 has increased in price and did not have the rebate when it was time to stock up again, so its back to Rotella. That worked well for years in my ALH engines.
2004 Cadillac SLS (wife's)
Old December 14th, 2011, 06:37   #3
Bob_Fout
Oil Wanker
Bob_Fout's Avatar
The cost / benefit ratio of T6 is just outstanding.
I think you'll notice T6 is *much* better in the winter compared to TDT (unless you plug-in)
Old December 14th, 2011, 06:56   #4
davebugs
Since free maintenance for the first 20k I have only used the Rotella for the next 200k.
No issues at all, intake is even so clean at 185k that they didn't bother to clean it.
I do 5k changes with OEM filter (let the complaining begin). But it works for me.
davebugs is offline   Reply With Quote
Old December 14th, 2011, 07:01   #5
yatzee
yatzee's Avatar
TDI(s): see sig
about time you started using the oil that you got me to start using a couple years ago!
2015 Passat TDi 6 spd, 2005 C230 6 spd, 1991 405 mi16, 1986 and 1987 190e 2.3-16
yatzee is offline   Reply With Quote
Old December 14th, 2011, 07:02   #6
Bob_Fout
Oil Wanker
Bob_Fout's Avatar
Psh, do I as a say, not as I do
Old December 14th, 2011, 07:51   #7
DonL
Fuel Economy: 45 - 55, mostly around 48
That ought to get the 10K oci police going. I go 6K most times with a Wix filter, sometimes I think of going back to 5K. Thanks for the encouragement. Seriously.
Last edited by DonL; December 14th, 2011 at 07:53. Reason: interesting the words you can't use that best express a point of view.
DonL is offline   Reply With Quote
Old December 14th, 2011, 08:13   #8
Abacus
That helpful B4 guy
Abacus's Avatar
This has been contrary to my personal experiences with both, and I don't plug my car in.
'97 B4: 453,000 miles Malone 3, PP520's, Stage 2 cam, SBC3, ARP studs, 2 1/4" exhaust, 2.5" Cat, no mufflers or EGR.
BUG*PWR 2013 Award Winner
Old December 14th, 2011, 10:31   #9
oEo
oEo's Avatar
Fuel Economy: mid 40's
yeah Bob, make that my last oil change!
2 0 0 4 I n d i g o B l u e G o l f R C 1 T D I C L U B A D D I C T I O N @ 1 4 9 k R u n n i n g W i t h T 6 U O A
oEo is offline   Reply With Quote
Old December 14th, 2011, 11:36   #10
vwdsmguy
Fuel Economy: 49/46/42
Default Rotella 4w40
I have bought Rotella T6 5w40 for $21 up to $28/gal, the best price being at Walmart.
'02 Golf TDI, RC5, PP764's, FMIC, 2.5" T-Back, OMI, SB-3 clutch, 11mm pump, VNT17/22, 3 Bar MAP, CAT filter, 90 GPH Holley lift pump, modded D24 intake manifold, Rosten rods, Nural pistons, ported head - 15.0 @ 94 at the drags
vwdsmguy is offline   Reply With Quote
Old December 14th, 2011, 12:27   #11
VWBeamer
Fuel Economy: 42.79 mpg Woot!
I'm going to a 80,000 OCI. I'm going to change the oil, timing belt and tires all at the same time, go another 80k, and then junk the car. With the money and time I save changing oil I going to eat out more often.
800 club. 828.5 miles, 16.33 gallons, 50.79 mpg.
2004 Jetta GLS Wagon TDi-17/22, 2.5 DP.2.5 Exhaust, Stage 5 Malone Tune.3 bar MAP, pd150 Injectors, Ebay FMIC, 1.8T Pancake pipe. Gutted PD100 intake.
VWBeamer is offline   Reply With Quote
Old December 14th, 2011, 14:38   #12
Herm TDI
Herm TDI's Avatar
I use Rotella T6 for breath freshener, deodorant, mouth wash, bath oil and tooth paste, hair-tonic too.
My TDI's (and I) have trived on this stuff.
Malone Tuning Service.
HermTDI@Yahoo.com
Herm TDI is offline   Reply With Quote
Old December 14th, 2011, 15:06   #13
Ski in NC
Fuel Economy: 48-52 typical
T6 user here too in the tdi. Long time user here of dino rotella on marine engines. Good UOA's, good price, available anywhere.
2001 Jetta TDI 5sp Stock 201k mi
1981 Rabbit IDI 4sp Sold at 339k mi
1990 S-10 4.3 4wd 5sp 154k mi
1986 VW Pathfinder 1.6 45hp Marine 4700 Hrs
2001 Cummins 8.3 420hp Marine 1660Hrs..REFIT DONE!!
Ski in NC is offline   Reply With Quote
Old December 14th, 2011, 15:47   #14
Herm TDI
Herm TDI's Avatar
I miss the good o'le days of the TDI oyl wars.
One would feel the hostility through the key board!
Many evenings were filled with laughs and choaks just reading that stuff.
Now you can't even get a rise from anyone about engine oyl.
HermTDI@Yahoo.com
Old December 14th, 2011, 15:52   #15
silverbox
silverbox's Avatar
Fuel Economy: 55mpg highway@100kph
Bob, are you going to be changing your oil soon, if so I look forward to your cold weather comparison with the others you have tried.
KERMA tune, PDliftpump,11mmIP Race 520's. PD150 Intake manifold&TIP, 1722 turbo, Upgraded IC pipes and Eurojet SMIC.Stealth racepipe. 2.5DP+catback areoturbo2525 muffler. Peloquin LSD.
Koni FSD's +VR6 springs, 23mmRSB, 16x7w/Conti DWS. GLI Recaros, Wingnut short shifter, Ecodes w/relays+60/100h4's.
Cat2 Fuel filter DG/Amsoil Bypass filter
silverbox is offline   Reply With Quote
Mobil 1 VS. Rotella T6 Poolboy1191 Fuels & Lubricants 40 November 24th, 2011 12:49
Shell Rotella T6 5w40 VOA Bob_Fout Fuels & Lubricants 2 July 30th, 2011 03:13
Rotella T 5w40 now Rotella T6??? Joester Fuels & Lubricants 13 February 5th, 2010 17:20
Rotella T6 & Rotella T SB? kwalsh24 Fuels & Lubricants 8 January 28th, 2010 17:38
Rotella T6 werewolf TDI 101 6 January 20th, 2010 16:42
Page generated in 0.18784 seconds with 10 queries
[Output: 134.73 Kb. compressed to 112.62 Kb. by saving 22.11 Kb. (16.41%)]
