Old December 15th, 2011, 13:47   #46
Ski in NC
Fuel Economy: 48-52 typical
No expert on coatings, but mighty skeptical. Detroit diesel sold coated piston kits for their high output two-strokes, and they failed. Coatings came off and the very hard and abrasive debris tore up the cylinder liners. And those pistons are iron, not al. Nothing seems to like to stick to al, at least in my non-metallurgist mind.
I would not go with coatings unless you are beyond the thermal limits with your tune and duty cycle. In the OP's case, I think it can be handled by keeping rev's up when towing. Snorting around doing heavy accels are brief and heat likely does not have time to soak into piston. But thermal stresses are high there due to the temp gradient...
High output marine engines handle the piston temp issue by lowering cr, as already discussed above. This does create more fuel smoke at light load and cold start, though.
2001 Jetta TDI 5sp Stock 201k mi
1981 Rabbit IDI 4sp Sold at 339k mi
1990 S-10 4.3 4wd 5sp 154k mi
1986 VW Pathfinder 1.6 45hp Marine 4700 Hrs
2001 Cummins 8.3 420hp Marine 1660Hrs..REFIT DONE!!
Ski in NC is offline   Reply With Quote
Old December 15th, 2011, 14:05   #47
Fix_Until_Broke
Fix_Until_Broke's Avatar
Fuel Economy: 75.0/53.0/38.4
Putting the cost aside for a moment, it's a two week delay in getting it back up and running again in my unheated garage.
I have time off work at the end of the year and plenty of holiday travels planned (I have other vehicles to drive, but not anywhere as economical as a TDI). Getting the coating done would put me in the 1st week of Jan instead of next week and cost an additional $250+ in fuel not driving the TDI.
I'm going with the PD150's which should drop compression by a point I'm told. I have no concers about the durability of the coating (maybe I should) - it's a logistics and principle issue. Like IBW asked, will it do any good practically?
03 Jetta, Cat 2u, DG Steel SP w/MOGolf Mod, 3"DP, 4"EXH, EaBP100 Bypass, Euroswitch, ECodes, Driving Light, PD Lift Pump, R520's, RC5,RC6, TDTuning, Malone, ScanGaugeII, 3" TIP, 2" TOP, HE221W Compounded with GTC1444VZ, 6 Bar MAP, VR6 MAF, Vented Fender Liner, Battery Cover Mod, 11mm, Monster Mats, 215/55/17 (27.9/53.0/75) Monthly MPG Links, Euro Trunk Latch, IDParts RSB, SDI or ALH Intake, ARL Ceramic Pistons, Rosten Rods, DRW, Wavetrac, SBC, FSD's, Beef Springs, Rebuilt Head, Recaro's, Colt II, DG Sigma 6, RMT200
Fix_Until_Broke is offline   Reply With Quote
Old December 15th, 2011, 15:21   #48
mk1-83
Fuel Economy: 1:15
Pd Pistons and rods are pritty strong. It will hold just fine. I think you go with bigger nozzels to. hold the injection duration short. it make less thermal stress.
Lupo 1.9 tdi
H-beam, 1:17 cr, 12mm pump,dss-r.360,gtb2365 vklr.
300+ HP 500 nm
https://www.youtube.com/watch?v=1h3bxhWZcvk
mk1-83 is offline   Reply With Quote
Old December 15th, 2011, 17:45   #49
silverbox
silverbox's Avatar
Fuel Economy: 55mpg highway@100kph
FUB,
How were your rods and bearings? What rods are you using?
KERMA tune, PDliftpump,11mmIP Race 520's. PD150 Intake manifold&TIP, 1722 turbo, Upgraded IC pipes and Eurojet SMIC.Stealth racepipe. 2.5DP+catback areoturbo2525 muffler. Peloquin LSD.
Koni FSD's +VR6 springs, 23mmRSB, 16x7w/Conti DWS. GLI Recaros, Wingnut short shifter, Ecodes w/relays+60/100h4's.
Cat2 Fuel filter DG/Amsoil Bypass filter
silverbox is offline   Reply With Quote
Old December 15th, 2011, 18:38   #50
Fix_Until_Broke
I don't have the bottom end apart yet - probably this weekend before I get to it.
The internals are/were all OEM ALH
I went with the IE rods and PD150 ARL pistons from boraparts
Old December 15th, 2011, 18:46   #51
Keebler145
Keebler145's Avatar
Fuel Economy: ~45
I think I would have went rosten rods.... not a big fan of the IE rods....hope they work out, make sure you get the weights checked/balanced.
424,000 miles and counting, On the frame that is (as of sold date)
Gt2256v 3 in downpipe and vibrant resonator, 3in OMI and FMIC all by Whitbread, Titan 520's, Port & Polished Head courtesy Franko6, RC 6, 11mm IP, PD LiftPump. Rosten Rods, PD150 Pistons, Oil Cooler, Fuel Cooler, Diablo W/M Kit,DC III clutch, Built 5 speed with LSD
Keebler145 is offline   Reply With Quote
Old December 15th, 2011, 19:31   #52
ducesrwld
TDI(s): none
need to update your user name then to fix_until_broke_repeat
2006 Black Jetta TDI - 5 speed bought with 17,000 miles....constant work in progress. Whitbread Sleeper Package....one of the quicker BRMs on the block
ducesrwld is offline   Reply With Quote
Old December 15th, 2011, 19:53   #53
Whitbread
Whitbread's Avatar
TDI(s): Several
If it's going to be a big delay in plans for you, skip the coating. The pd150 pistons will have much better thermal absorption characteristics than stock pistons do so I wouldn't worry about it too much. Between the lower top ring land, lower cr, and internal oil cooling channels, you should be fine.
02 Jetta TDI
Whitbread Performance Innovations
-Full TDI maintenance, performance and custom fabrication services. 248-755-8118, 10AM-5PM EST M-F. Please email or call only for business inquiries. PM's are not for business communication.
Whitbread is offline   Reply With Quote
Old December 15th, 2011, 19:58   #54
JFettig
JFettig's Avatar
Are ASZ and ARL pistons the same or are they actually different?
Minnesota Malone Tuning dealer
1998 B5 Passat TDI Compound Turbos
2009 JSW Stage 3 196whp so far
DIY injector calibration http://forums.tdiclub.com/showthread.php?t=383324
JFettig is offline   Reply With Quote
Old December 15th, 2011, 21:07   #55
TDIJetta99
TDIJetta99's Avatar
Fuel Economy: low 38, high 61, avg 48
If you're set on the low rpm power, as in 1000-2000, the lower CR will destroy those dreams... I went down to 18.7XX on my build and it has the torque of a 2.slow under 2000rpm.. 2500rpm+ is a totally different story however.. A bit hard starting in the cold but nothing major.. Some of my lack of low rpm grunt is from the 2260, but regardless of the turbo, there's NO off-boost power at all...
Taking on some work here and there.. Contact me for your needs.. Can do emissions testing friendly ALH tunes on most setups, even swaps. best way to contact is text or email tdijetta99@gmail.com
TDIJetta99 is offline   Reply With Quote
Old December 15th, 2011, 21:15   #56
Keebler145
Keebler145's Avatar
Fuel Economy: ~45
ARL are out of the 4 cylinder pd150 and I want to say the asz pistons are just out of the 8 cylinder... same p/n IIRC *shrugs*
Old December 15th, 2011, 21:32   #57
v8 coupe
there is a place in MN that does coatings they can do them in a week or less usually.
From what I have read in all my tech articles it's hard to prove it works. Having said that a mentor of mine Joe Mondello use to say it's "free HP" he coated everything from briggs go-kart pistons to 2000HP tractor pull engine. Basically it doesn't give you anything extra. It only stops the heat from going where you don't want it, in the pistons and oil. Coating the head also helps, but to me the heat is needed to get the engine to operating temps.
FUB the place in MN is called TPIS here is a link good group of guys. They will be coating my modified ALH pistons.
2003 indigo blue Golf TDI Gone!
81 VW Caddy needing Some love!
91 Audi CQ AKA "Eleanor" my unicorn!
09 Rabbit S now a TDI AWD.
91 200 20vt Avant
v8 coupe is offline   Reply With Quote
Old December 15th, 2011, 21:34   #58
Fix_Until_Broke
Had a couple moments of motivation and went out to the garage and pulled the oil pan and all the rods/pisons.
Everything looks good so far
Does anyone know what kind of rings come on the pistons?
More specifically, to what finish or with what grit should I hone the cylinder bores?
Old December 15th, 2011, 21:37   #59
Fix_Until_Broke
Any theories on why a change in compression ratio would change the powerband?
Did you change cam's or anything else when you changed CR?
Old December 15th, 2011, 21:42   #60
v8 coupe
PD150 pistons need different squirters. ALH squirters will not line up with the hole in the piston to get optimal cooling.
PN is 038103157A
91 200 20vt Avant
Has anyone used radiator leak stop to stop a heater core leak??? Pcar993 VW MKIV-A4 TDIs (VE and PD) 12 October 30th, 2012 20:04
Miami to SC State Line Rest Stop Non-stop jeffstoked TDI Fuel Economy 1 November 27th, 2007 09:35
I need to stop... TylerSales TDI 101 13 March 16th, 2006 19:10
Truck stop fuel always better then non-truck stop? 03GolfTDI Fuels & Lubricants 10 July 3rd, 2003 09:03
Page generated in 0.19984 seconds with 10 queries
[Output: 142.38 Kb. compressed to 120.49 Kb. by saving 21.89 Kb. (15.38%)]
