| TDI Power Enhancements Discussions about increasing the power of your TDI engine. i.e. chips, injectors, powerboxes, clutches, etc. Handling, suspensions, wheels, type discussion should be put into the "Upgrades (non TDI Engine related)" forum. Non TDI vehicle related postings will be moved or removed. Please note the Performance Disclaimer. |
December 14th, 2011, 08:04
#31
if you know how to use them, telescoping gauges can work very well in combination of a good micrometer. I frequently see people mis-using them, it is sometimes hard to get a good measurement on them if you can't feel it just right.
December 14th, 2011, 08:09
#32
Fuel Economy: 48-52 typical
To accurately measure bores, I use three tools: A dial bore gauge, a micrometer, and a standard. The bore gauge has to be set using the mic, and the standard is used to make sure the mic is dead on. The bore gauge is handy as you can sweep the bore in numerous areas while watching the dial. Also, on little engines you can't get your hands in the bore with an inside mic, another tool that works. Inside mics are slow to take measurements.
Check ENCO in NV, they have good prices on measuring tools. I use name brands, but that took quite an investment. A bore gauge can be an off brand (usually) as you can check the performance of the tool with the mic. It really is just a transfer tool.
I've tried using bore snap gauges, but it is hard to get accurate measurements.
2001 Jetta TDI 5sp Stock 193k mi
1981 Rabbit IDI 4sp Sold at 339k mi
1990 S-10 4.3 4wd 5sp 154k mi
1986 VW Pathfinder 1.6 45hp Marine 4700 Hrs
2001 Cummins 8.3 420hp Marine 1645Hrs..in the yard for REFIT!!
December 14th, 2011, 08:14
#33
What is the down side to bore out the block? Cost of new pistons and the machine shop cost? At least you would know the bore is true. And you are going to buy some new pistons anyway, right?
Just asking - not advocating.
Also, what needs to be done to boost the power between 1000 to 2000 rpm??? Smaller turbo?
JJ
1996 B4V, Hella E-Codes, full GLX leather, EuroTuning.cz 02A 6 speed conversion w/.71 5th and .588 6th gear, A4 shift linkage and trans tower conversion by Matt-98AHU, Sprint 520 nozzles, GQ ecu w/TDtuning stage 3, 20 lbs. boost, 112 hp and 224 lb/ft tq. at the wheels (as of 12/1/12)
December 14th, 2011, 08:19
#34
Here are a couple how-to use a telescoping "snap" gauge properly:
http://constructionmanuals.tpub.com/...s/14256_93.htm
http://bbs.homeshopmachinist.net/sho...10&postcount=2
Once it is tightened up inside the bore, carefully make sure you're in the center, then tip it like above. at this point, don't tighten it any more. carefully measure it. You will get some varying measurements but with practice you can get good at it. I can typically measure stuff to about .0005" with them.
December 14th, 2011, 08:31
#35
Originally Posted by Fix_Until_Broke
Ok - lots of comments to address here...
All of the other things that the car needs (suspension and such) are definately needed and way beyond overdue. Then combining the engine repair/replacement now and everything associated with that, I just wanted to make sure that I wasn't "polishing a turd" here. The overwhelming consensus is that it should be fixed and I agree with that. This car has done everything I've ever asked of it, thousands of miles pulling trailer, my dependable daily transportation, excelllent mileage (52+ MPG average over lifetime). I know what this car is/is not and buying something new/used would start that learning curve over and besides that I like the car  .
That said, now to decide how/what to repair this thing. It sure seems that lowering the compresion would help keep peak cylinder pressures and piston temps down. Lower compression will generally loose thermal efficiency but might prevent this from happening. ~18.5:1 would be about as low as I'd want to go to insure good starting in the winter. Any opinions on a thermal barrier on the tops of the pistons - Maybe keeping the 19.5:1 CR for good starting and a thermal barier would make the pistons live? I'm aiming to improve power in the 1000-2000 RPM range so this is the time to make any changes/improvements to support that.
I'm assuming that this failure was due to thermal stress on the pistons, most likely from towing and resultant operation at continuious high loads for hours on end. If I get it apart and find the oil squirter plugged on #3 pistion or some other evidence of another cause of the piston failure, I'll let everyone know. EMP's during the heavy trailer towing are equal to boost and IAT's are ~50F over ambient. A larger oil cooler would probably be a good idea (no oil temp gauge, but will be getting one).
My trusted mechanic is adamant that the block should be bored/trued up and that it's probably not round and would have trouble sealing the rings if it was just honed. I'm going to try and get a 3-4" micrometer and bore gauge to see if the cylinder is true enough to hone or not. Given the marks on cylinder 2 in particular it could be either way.
What about a complete engine swap? A PD150 and 6 speed from across the pond?
Are there any 16 valve motors that will more/less go in?
A CR without all the emissions stuff would be cool as well?
I guess all the statements I've made about "Well, it has not blow up yet" are no longer valid  .
I think it was pretty unanimous most of us said ASV with ceramic coating for stock compression and better thermal control or pd150 pistons to drop compression which have thicker crowns and would also have better thermal control. Matt makes a valid point on getting some rosten rods, it's cheap insurance.
I don't know that a 1756 will lower your EMP and EGT. You need to get a bigger exhaust wheel to really accomplish that. Not sure why you want to make more power in the 1000-2000 range, really not good for the motor. At that RPM you're really lugging the old girl and stressing the internals.
If you're going to do that definitely make sure you get an OEM weight or maybe heavier flywheel. If you're going to drive it like an old farm tractor you better build it like one.
424,000 miles and counting, On the frame that is (as of sold date)
Gt2256v 3 in downpipe and vibrant resonator, 3in OMI and FMIC all by Whitbread, Titan 520's, Port & Polished Head courtesy Franko6, RC 6, 11mm IP, PD LiftPump. Rosten Rods, PD150 Pistons, Oil Cooler, Fuel Cooler, Diablo W/M Kit,DC III clutch, Built 5 speed with LSD
December 14th, 2011, 09:51
#36
Fuel Economy: 75.0/53.0/38.4
If I can just hone the bores for new pistons/rings, then I don't have to remove the engine from the car saving a fair ammount of time/effort. If it has to come out, it will, but being generally lazy, I'd rather not if I don't have to.
03 Jetta, Cat 2u, DG Steel SP w/MOGolf Mod, 3"DP, 4"EXH, EaBP110 Bypass, Euroswitch, ECodes, Driving Light, PD Lift Pump, R520's, RC5,RC6, TDTuning, Malone, ScanGaugeII, 3" TIP, 2" TOP, VNT 17/22, 3 Bar MAP, VR6 MAF, Vented Fender Liner, Battery Cover Mod, 11mm, Monster Mats, 215/50/17 (27.9/53.0/75) Monthly MPG Links, Euro Trunk Latch, IDParts RSB, SDI or ALH Intake, ASV Ceramic Pistons, Rosten Rods, DRW, Wavetrac, SBC, FSD's, Beef Springs, Rebuilt Head, Recaro's, Colt II, DG Sigma 6, Gauges
December 14th, 2011, 10:20
#37
Fuel Economy: mid 40's with mixed spirited driving
02 Jetta TDI. Part 2
Whitbread Performance Innovations
-Full TDI performance and custom fabrication services. 248-755-8118. Dealer for SBC, TD Tuning, Wavetrac, Peloquin, Venair, and Vibrant.
December 14th, 2011, 10:57
#38
Are the PD150 and ASV pistions interchangable? Bowls in the same location, etc?
I assume the PD150's have a larger bowl to drop the compression? Any idea what the CR drops to on with the PD150's
Swaintech for coatings I assume? Anyone else who does coatings like this?
I think I have all the measurement equipment lined up and will try and measure the bores tonight.
I've wanted to put a heavier flywheel in for a long time - figured it would smooth things out quite a bit.
Regarding lugging and stress on the internals, I think the pistons and rods should address a lot of that. I'm not looking to make 200 HP at 2000 RPM, but just extend the power curve down the RPM range. BMEP's are significantly lower (half) than some of the 200+HP 400+ft-lb TDI's out there.
Maybe to ask another loaded question....OEM head bolts or ARP's?
December 14th, 2011, 11:11
#39
PD150's drop it a whole point IIRC so 18.5. I never measure, but from the eye they look like they have a larger bowl.
Swaintech is about the only one I know of. ASV and PD150 pistons are interchangeable on rosten rods  but the OEM rods need tapered to fit a PD150 piston IIRC again.
When I bought my ARP headstuds they were only 80 bucks more than buying headbolts. Knowing I would be pulling the head again I bought something I could reuse. I had issues with the headbolts stretching and lifting on me at 24psi on a 17/22. My coolant bottle was always over pressurized and had soot in it.
Flushed the coolant installed the headstuds and the problem went away.
December 14th, 2011, 11:13
#40
Yes, they are basically the same. PD150's are 18.5:1 CR, the ASV's are 19.5 like ALH's.
I've used both Swaintech and Polydyn, been very happy with both.
Do the ARP's, again very cheap insurance at this point. Literally I just did a head gasket on a car with a stock turbo that was pressurizing coolant yesterday. It'll never be easier than now to fix all the factory short comings.
December 14th, 2011, 21:20
#41
Here's the cylinder bore measurements. I used a telescoping bore gauge and a 3-4" micrometer. The micrometer was ~0.0005" large on both the 3" and 4" gauge blocks at room temp. I let them set in the garage for a couple hours to get to the same temp as the engine (~40F). It took a few measurements to get the hang of it - I repeated the first 8 measurements I took after I completed the first set and got more consistent numbers with the other bores the 2nd time. I double checked most of them by the time it was all done. My guess is that the numbers are +0.0000"/-0.0010"
- means side to side across the bore
| means frint to back across the bore
Top of bore just below where the rings stop
#1 - 3.1320"
#1 | 3.1318"
#2 - 3.1310"
#2 | 3.1315"
#3 - 3.1315"
#3 | 3.1320"
#4 - 3.1300"
#4 | 3.1320" I did these two 4-5 times and it's about 0.0020" different
Bottom of bore just above top of piston
#1 - 3.1300"
#1 | 3.1310"
#2 - 3.1310"
#2 | 3.1310"
#3 - 3.1315"
#3 | 3.1310"
#4 - 3.1300"
#4 | 3.1305"
I don't have my bentley manual at hand (left it at my friends shop 250 miles away), but 79.5mm = 1.1299 inches so being 1-2 thousandths over and relatively round for the most part does not make me think it needs to be bored out/trued up.
Flex hone it in the car, new pistons, etc and get it back on the road?
Should the cylinders be honed with a torque plate?
I'm going to find accurate TDC and mark the flywheel as long as it's apart.
Anything else I should do while I'm here?
December 15th, 2011, 11:46
#42
Piston coating is ~$250 + Shipping and takes ~2 weeks turnaround.
Is it worth it?
December 15th, 2011, 11:49
#43
definitely worth it. especially for low rpm higher egt running like you want to do!
December 15th, 2011, 12:16
#44
Should the head also be coated? OEM't the goal to keep as much heat in the.cylinder as possible to push the piston down?
JJ
December 15th, 2011, 12:38
#45
Does anyone have any data that shows coating pistons in a diesel helps? Diesels run relatively cool compared to gasoline engines. I've debated doing this for my track day Golf. I'm not even sure what data would be useful, but I wonder if it's worth the expense.
2002 Jetta wagon, 278K, RC6 and other stuff; 1993 Mercedes-Benz 300D 2.5, 190K; 1997 Passat, 253K; 2012 Golf, 15K; 1990 Miata, 66K. Principal, http://www.idparts.com
