Old December 5th, 2011, 13:51   #1
its_go_time
TDI(s): 05 jetta
Default Coolant heater
Getting ready to install a Zerostart 8000 on my '05 PD jetta. Question: why does the check valve need to be removed from the heater?
Thank you in anticipation.
its_go_time is offline   Reply With Quote
Old December 5th, 2011, 14:51   #2
maxwellp
maxwellp's Avatar
Fuel Economy: 47.25
The check valve works to make sure the coolant flows in one direction when it is heating. Where we place the heaters on these cars coolant flows in the opposite direction when the engine is running...So it can't have a check valve.
http://www.frostheater.com/frostheater.htm
1998 Beetle TDI Malone Tuning Stage 2
2001 Dodge Cummins 5.9
2005 Dodge Cummins 5.9
maxwellp is offline   Reply With Quote
Old December 5th, 2011, 17:56   #3
its_go_time
TDI(s): 05 jetta
That's what I've been reading. But, what I don't understand is why the two hoses can't just be reversed so the heater is moving the coolant in the same direction as it naturally moves...Is that a dumb question? Where do the two hoses going into the oil cooler go? If I reversed the hoses, would it try and move the coolant against the thermostat instead of into the engine?? I don't get it...
Old December 6th, 2011, 14:18   #4
its_go_time
TDI(s): 05 jetta
I found a coolant flow diagram for the ALH motor. I hope it's similar if not identical to the BEW?? In it, it appears that the oil cooler is part of the bypass circuit for when the thermostat is closed. It seems to me that you could connect a heater in either direction, and the engine is still gonna get warmed. So...why don't ppl just leave the check valve in place, and hook the heater up so its moving coolant in the same direction as the pump. It seems to me that it would be more efficient with the one way valve in place?
Old December 6th, 2011, 16:31   #5
david_594
david_594's Avatar
Fuel Economy: 51.7/48.2/40.7
The issue is the coolant moves via convection since there is no pump in the zerostart. So if you reverse the two hoses the heated coolant will still be trying to move in the same direction.
david_594 is offline   Reply With Quote
Old December 7th, 2011, 14:56   #6
its_go_time
TDI(s): 05 jetta
If I reverse the two hoses, the coolant will be convecting in the opposite direction, no? Doesn't matter, I guess. This is where everyone puts them. They put them in opposite normal flow, and remove the check ball. It seems to work for ppl, so that's what I will do. It just doesnt make any sense to me.
Does anyone know what the height difference is between the water pump and the side of the head where the coolant comes out. Zerostart requires the coolant to be pulled into it from a low area on the block and the heated fluid put back up high. That might explain why we need to mount it backwards?
Old December 7th, 2011, 17:22   #7
maxwellp
maxwellp's Avatar
Fuel Economy: 47.25
The heated coolant will always go up, opposite normal flow. So running it goes one way. Plugged in it goes the other. that's why you remove the check valve.
Old December 7th, 2011, 17:40   #8
jgeorge
Does the frost heater have a checkball which requires removal before installation? Thinking of getting one.
jgeorge is offline   Reply With Quote
Old December 7th, 2011, 17:53   #9
maxwellp
maxwellp's Avatar
Fuel Economy: 47.25
I would check with frostheater but my guess is that if you buy their kit you would just put it on.
Old December 7th, 2011, 18:58   #10
its_go_time
TDI(s): 05 jetta
OK, so I removed the check valve in preparation for installation this w/e. Its at the bottom, on the inlet fitting. Comes out really easy. I just screwed a 5/16-18 machine screw into the black plastic body and pulled it out by hand. 10secs, max.
Old December 10th, 2011, 13:02   #11
its_go_time
TDI(s): 05 jetta
I've noticed that most ppl mount these heaters under the battery. The 1500W unit is quite large, so mounting it here seems like quite a tight fit. The power steering line uses up a lot of room in this area. Has anyone mounted their heater inside the front fascia, ahead of the left wheel? There's a crapload of room here. What would be the downsides of placing the heater here??
Old December 10th, 2011, 13:36   #12
david_594
david_594's Avatar
There shouldn't be any real issue mounting it there. Thats where the webasto gets mounted. My only concern would be making sure its not making contact with anything that could melt(like the fender liner).
Typically people use a different style zerostart heater that mounts much more easily below the battery.
Old December 10th, 2011, 14:47   #13
WAKeele
Fuel Economy: Good enough to never go back to gas!
With my FrostHeater, my instructions said to just remove the old lines and in with theirs. But that's for a MKIV ALH.
WAK
2002 Jetta TDI--318,XXX miles--manual (Sachs G60/VR6 clutch & flywheel)--Dieselgeek Panzer Skidplate, Ventectomy, FrostHeater, Bilstein TC Sport struts, Bosio Sprint 520 injector nozzles, Unitronic Stage 1+ Performance Software
WAKeele is offline   Reply With Quote
Old December 10th, 2011, 19:43   #14
its_go_time
TDI(s): 05 jetta
I put the car on stands and pulled out the wheel liner. I like this spot the best. Its the lowest you can go while still being enclosed, and there's a ton of room here. The only hitch is having to run the intake line through the plastic engine cover. The output from the heater would be no prob as it would just loop over the frame rail back to the engine. I'll have to make a bracket of sorts to keep it from floppin around as well.
Old December 10th, 2011, 21:26   #15
david_594
david_594's Avatar
Find the mk4 webasto install instructions. They will give you some ideas on how best to mount it in that area along with ideas for routing the coolant lines.
block heater vs. inline coolant heater general lee TDI 101 23 January 24th, 2013 20:54
Zerostart coolant heater or magnetic block heater? kilo69 TDI 101 22 January 30th, 2008 06:53
block heater/coolant heater Croberts TDI 101 11 October 1st, 2005 15:31
Coolant Heater Ericina VW MKIV-A4 TDIs (VE and PD) 8 November 23rd, 2004 20:34
Oil pan heater? Nope, a coolant heater! glxke VW MKIV-A4 TDIs (VE and PD) 7 February 6th, 2001 10:31
Page generated in 0.16836 seconds with 10 queries
[Output: 127.57 Kb. compressed to 106.65 Kb. by saving 20.92 Kb. (16.40%)]
