Go Back   TDIClub Forums > VW TDI Discussion Areas > TDI Fuel Economy
TDI Fuel Economy Discussions about increasing the fuel economy of your TDI engine. Non TDI related postings will be moved or removed.
Old December 5th, 2011, 07:09   #1
physicshogon
TDI(s): 2012 Passat
Fuel Economy: [URL=http://www.fuelly.com/driver/Olivia/passat][IMG]http://mefi.us/images/fuelly/sig-us/92859.png[/IMG][/URL]
Default Digital Tuning Box for 2012 Passat?
I'm a novice TDI user and just now getting into making modifications and I'm intersted in installing a digital tuning box on my 2012 Passat TDI (for the SOLE purpose of increasing fuel economy on cross-country drives).
To be clear, I'm NOT in search on that that increases rail pressure (due to high rate of rail failures already). So to all you TDI gurus out there, which model(s) do you suggest I take a look at?
physicshogon is offline   Reply With Quote
Old December 6th, 2011, 22:56   #2
DPM
Fuel Economy: 38.5- 47 Forester, 49-55 Peugeot
the only boxes I can tink of that aren't rail-pressure are from PSI; they intercept the injector signals instead.
But whether one is available to suit the revised injection system on the new US Passat I have no idea...
http://www.psi-motorsport.com/turbod...tid=2808&lg=en
DPM is online now   Reply With Quote
Old December 6th, 2011, 23:32   #3
tcp_ip_dude
tcp_ip_dude's Avatar
Fuel Economy: 46@75mph/51@60mph/City 38mpg
Just keep your foot out of it. Diesels are fuel throttled engines (unlike air throttled gasoline engines), the new Common Rail Engines run ultra-lean as it is during steady state highway driving, you control all fuel entering the combustion chamber with the pedal, the biggest impact on fuel economy is how you drive it. Get a Scangauge II and you can easily see this by monitoring fuel flow.
For example, I have a Revo tune (http://www.revotechnik.com) for my car, it's good for an additional 45HP and 53 ft/lbs of torque and the fuel economy shows it when I request power (i.e. by putting the pedal all the way down), however if I drive normally, for instance on cruise control at highway speeds, the tune has zero impact on my fuel economy over the stock ECU tune.
Search the site here, there are several lengthy threads on the topic, search for "hypermiling".
______________________________
'10 Jetta 6M Sedan, 35% Llumar tint, WeatherTech Floor Liners, TDIclub Plate Frame, B2, PS, ScanGauge II, Micro-Can VAG-Com
tcp_ip_dude is offline   Reply With Quote
2012 Passat in Automotive Engineering International Digital Editions uhy22 VW Passat Family (NMS and B7) TDIs (2012+) 5 October 6th, 2011 11:30
Dragon Digital Tuning Box for 1.4 / 1.9 / 2.0 PD Engines (30% gains) ultra_joel88 Private TDI Items for Sale/Wanted 0 July 18th, 2008 05:56
digital tuning box benshaw TDI Power Enhancements 1 December 3rd, 2007 09:33
For Sale: Digital Tuning Box VW Golf MK5 MKV TDI Deeem Private TDI Items for Sale/Wanted 0 March 8th, 2007 00:39
PSI Motorsports digital diesel tuning box. cetaneburner TDI Power Enhancements 4 July 23rd, 2002 19:27
Page generated in 0.12487 seconds with 10 queries
[Output: 58.00 Kb. compressed to 52.38 Kb. by saving 5.62 Kb. (9.69%)]
