Old December 4th, 2011, 13:34   #1
kevinmcgrease
TDI(s): 98 jetta
Default 98 jetta hard start
hi. I've had my tdi for about a year now but have been having starting issues since last winter. I live in upstate NY. It is hard to start even if the temps are above 50F if the engine is cold. My local greasemonkeys don't have the knowledge to address the tdi, and have replaced the glow plugs, relay, etc. with no luck. Where can I go either on this site or otherwise for a hard start tutorial? thanks
kevinmcgrease is offline   Reply With Quote
Old December 4th, 2011, 13:50   #2
kevinmcgrease
TDI(s): 98 jetta
I've also been using starter fluid (I know, I know!) which works great, but I'm gonna kill the engine soon!
Old December 4th, 2011, 13:57   #3
whitedog
If you have access to anyone with VCDS, you could learn alot about what is going on with your engine but you need to go over some basics like fuel quality and over all engine health.
Have you had the compression checked? Are you running the original injectors and injection pump? How many miles on these parts? How is the power? Any smoke? What is the maintenance history of the car?
There are lots of other questions folks will want to know to help you.
Can pump my own gas.
Old December 4th, 2011, 14:03   #4
sootwagen
sootwagen's Avatar
Fuel Economy: Who cares???
Where in upstate NY are you?
(O8)==(\X/)==(8O)
2003 Jetta GL Wagon TDI 5spd, Indigo Blue
sootwagen is offline   Reply With Quote
Old December 4th, 2011, 16:00   #5
greenskeeper
greenskeeper's Avatar
Fuel Economy: 53mpg
above 50F (actually 40F) the GPs aren't even turned on.
when was the timing belt changed? if the timing is retarded it could lead to hard starting. find (or buy ~ best value) a vagcom to see what is going on.
how many miles? once started does the car have power without any smoke indicating a compression or wear problem?
Gunga galunga...gunga -- gunga galunga.
98 JETTA TDI (SOLD) PP764s, RC3, 5deg advanced, 0.68 5th
97 F-250 Crew Cab 4x4 7.3L PSD E4OD (stock)
99 F-250 Crew Cab 4x4 7.3L PSD ZF-6 (4" turbo back, Hydra chip)
greenskeeper is offline   Reply With Quote
Old December 4th, 2011, 16:22   #6
maxwellp
maxwellp's Avatar
Fuel Economy: 47.25
hi. I've had my TDI for about a year now but have been having starting issues since last winter. I live in upstate NY. It is hard to start even if the temps are above 50F if the engine is cold. My local greasemonkeys don't have the knowledge to address the TDI, and have replaced the glow plugs, relay, etc. with no luck. Where can I go either on this site or otherwise for a hard start tutorial? thanks
Does it start hard when the engine is cold? As in sitting over night.
Does it start hard when the engine is hot? As is just drove it 30 minutes, shut is off, 5 minutes later it is hard to start.
Is there any time that is starts well? (not using the spray)
Just trying to lay some ground work.
1998 Beetle TDI Malone Tuning Stage 2
2001 Dodge Cummins 5.9
2005 Dodge Cummins 5.9
maxwellp is offline   Reply With Quote
Old December 6th, 2011, 10:47   #7
maxwellp
maxwellp's Avatar
Fuel Economy: 47.25
I just installed a Malone Tuning Stage 2, Fixed my hot and cold start problems!!!
Old December 6th, 2011, 11:21   #8
alphaseinor
My guess is fuel, or compression... your engine is a AHU, not an ALH, so keep that in mind.
Do you run WVO? if so it's probably an air leak, or some seal somewhere causing an air leak.
alphaseinor is offline   Reply With Quote
Old December 26th, 2011, 06:33   #9
kevinmcgrease
TDI(s): 98 jetta
I'm sorry to all who have taken the time to try to help me that I haven't aanswered your comments sooner. I don't even know how to answer threads, I really have no experience with these forums, so bear with me...
I don't have that access. also, the computer won't recognize the scanner (or vise versa), which seems to be problem #1, becasue there's no communuication with the engine.
Any ideas about making the ecu read to the scanner?
I haven't had the compression checked because my local mechanics don't have specific tools for diesel. There is a dealer, about an hour from me, but that's about it. As far as I know, all of the parts you asked about are original, but I will go thru the past bills to be sure. (The previous owner kept great records).
It has great power for 300,000. One other interesting thing about it's mis-functions is that the odometer zeroed out around 5k ago.
Very little to no smoke, except on starting, and especially, of course, hard starts.
Thanks again, whitedog, and everyone else. I think I have figured out how to respond to answers, and just changed the options for answers to come to my email address (had the wrong setting on).
Old December 26th, 2011, 06:36   #10
kevinmcgrease
TDI(s): 98 jetta
Hi sootwagen, I am in Sullivan County, 12747.
Old December 26th, 2011, 07:42   #11
whitedog
One thing you mentioned about the electrical is that on the 98 Jetta, the odometer will reset to zero at 300,000 miles.
On the generation of cars after your, an aftermarket radio will cause problems connection to the ECU, but I don't know about your A3 generation.
Be very cautious of the dealer since they are known for not knowing much about the TDI engine. Be prepared to drive a few hundred miles to get to a knowledgeable TDI mechanic since they seem to be scarce in parts of NY. But mainly, don't fall back on the dealer to save some time. Often times they will do repairs that cost way more than a days wages than can be done for a small fraction of the price by a competent TDI mechanic.
Old December 26th, 2011, 10:24   #12
kevinmcgrease
TDI(s): 98 jetta
Hi Greenskeeper, thanks for the input, sorry about not getting back sooner, besides trying to figure out my vehicle woes, I'm also totallly unfamiliar with forums and how to respond, post, etc, but I hope I've got it down now.
Unfortunately, one main problem is that the ecu wont register on the vag com at the dealer who said he needs at least 3 hours just to try and figure out whty it won't register! So I have no readings or hints about timing, etc. The previous owner claimed to have changed the belt, so that would have been about 20-30,000 ago.
I just got off the phone with the previous owner who said he swapped out the motor about 4-5 years ago with an engine that had 140,000 on it, so it probably has close to 200,000. he also put on a new (or perhaps rebuilt) turbo at the same time. He claims he religiously got 50mpg (this was about 3 years ago. I've never gotten above 40 since I've had it for over a year.)
Once running, I don't see any smoke.
Can I check the timing without using a vag com? can it be adjusted without special tools? do I need to also set the timing in the injector pump, as someone told me I would?
Thanks for your help!-kevin
Old December 26th, 2011, 10:35   #13
kevinmcgrease
TDI(s): 98 jetta
Hi maxwell, thanks for the response, sorry to take so much time, I didn't see your answer until today!
Hard start only when cold, even in mild (50-60f) temps. Spraying worked fast, but now not at all. (just a tiny 'pfft!" would get it going). when the car cooled down in cooler temps (30-40), it would take a spray to get it going after sitting a few hours.
Runs good when warm, with intermittant power losses sometimes on demand. Bad mpg (less than 40). No compression test done, but has great power when running well, just bad mpg. No smoke after warm up.
can I check for a vaccuum leak or check the timing without using a vag com ?
thanks again., kevin
Old December 26th, 2011, 10:39   #14
kevinmcgrease
TDI(s): 98 jetta
Hi lphaseinor, thanks for the response. sorry to have not gotten back sooner; still tring to figure out how to navigate this forum.
what is the difference or significance of an ahu vs. and alh motor?
I do not use wvo, but the previous owner did who reported none of the effects I am experiencing.
Thanks again, kevin
Old December 26th, 2011, 10:42   #15
kevinmcgrease
TDI(s): 98 jetta
I have a factory radio in the car, but it stopped working last winter when I changed the battery and never got the code to reset it.
Thanks for the heads up about the dealer. I don't know anything about their mechanic other than he is German and is supposed to eat sleep and breathe diesel. But I guess they all say that...
98 Jetta TDi Hard Start edjet VW MKIII-A3/B4 TDIs 3 August 13th, 2011 00:13
98 TDI hard to start/air in lines theoriginalgerhard VW MKIII-A3/B4 TDIs 3 February 8th, 2011 15:24
98 Jetta tdi Hard to start hot, now no start DRVRFWND VW MKIII-A3/B4 TDIs 6 February 7th, 2011 23:01
98 TDI Hard start cold no codes thrown? jlscheele TDI 101 6 April 14th, 2010 20:06
98.5 TDI, hard to start bennyandtash General VW Discussion 2 April 3rd, 2005 14:44
Page generated in 0.16599 seconds with 10 queries
[Output: 130.80 Kb. compressed to 109.86 Kb. by saving 20.93 Kb. (16.01%)]
