Stumbled upon some financial woes... might have to sell my pride by the end of December. This all depends if I get a phone call with a job offer I am expecting in the first few weeks of December.
So I bought this car privately in May of this year and it has two ladies as previous owners.
2000 2-door Golf (Built in Wolfsburg, Germany)
238 000 km running on Synthetic
Black on Black Euro Interior, Very clean, Wolfsburg-style Seats
AC blows cold
Sunroof is amazing
Comes with a set of Michelin Winter tires
Tint
Work (Everything done by me):
15k Timing Belt, Rollers, Water pump
5k front axles replaced with VW re manufactured units.
10k replaced ball joints on both sides.
5k passenger wheel bearing.
15k on rear rotors and pads.
10k on Shift Rod Bearing and Seal
10k Rear Main Crank Seal
15k Air and Fuel Filter
Break, Trans, Coolant fluid replaced within 10k
Performance:
VNT-17 with approx 35k (PD150 adapter + braided oil supply line)
Bosio Sprint 764 nozzles pop tested approx 30k
Unitronic Stage 3 Tune set to 22psi
Boostvalve set to contain spikes to 24psi
Diesel Geek EGR Block off plates and EGR cooler delete
EGT probe installed ready to be connected to a Gauge
DC Stage 1 Clutch (Good for 200hp/356tq) approx 10k
G60/VR6 Lightened Flywheel 16.5 lbs
3bar MAP
Stereo:
400w Kenwood 4-channel amp hooked up to 4 competition speakers
100w JBL mono amp hooked up to 12' sub with a capacitor
Some Sony deck that came with the car.
Very clean sound... Sound is soo crisp and loud enough to make your ears bleed... some ppl would prefer more bass.
Full Disclosure:
Very Minor Scratches and Rust (Doors and Hatch mainly)
Stupid tint on front windows is peeling, if you drive me to the guy who installed it in Brampton he will fix it for free.
I rear ended a guy while driving on stop and go traffic a week ago. Just had to replace front bumper, drivers fender, drivers headlight, hood, grill, radiator with support and AC condenser. Was not going fast enough to bend or damage the frame in any way. It just cracked all the plastic and bent up the body parts. Original rebar was re-installed and was perfectly straight.
Writing all this it makes me pretty sentimental as ALLOT of work has been put in this car to make it drive AMAZING. It hasn't been even a year owning this car and fixing it up. Hopefully someone will be able to enjoy it as it is ready for crazy mileage to be put on.
I do not beat on my cars and I have never come close to hitting the rev limiter with this car as an EGT gauge has not been installed. I hooked up a temporary Boost gauge when setting up my boost valve and made sure max boost was kept in control. This car pulls hard and is deserving of an all red TDI badge.
What should the price be?
AC blows cold
Sunroof is amazing
Tint
Performance:
3bar MAP
Stereo:
Full Disclosure:
