Do I remember correctly that the 2-hole filter is taller, with a space at the bottom for water collection? Perhaps the thinking is, if there's water in the fuel (which seems to be rare around here...on this site, I mean), it would settle out in the filter housing and not be sucked into the system...unless the fuel is saturated with water...
Yes,the two hole filter does have a water/sediment space at the bottom. Its weak point is the olympic o-ring and the filter element hanging up on the center post when changing. The one hole filter is simpiler to change,but has no space at the bottom.
http://forums.tdiclub.com/newreply.php?do=newreply&p=3629155
CR-ONE HOLE and TWO HOLE FUEL FILTER DIFFERENCES/PICS
In this thread I will point out the differences between the one and two hole fuel filter elements and filter canisters.The first obvious difference is the one hole canister measures approx.6-5/8ths inches deep as compared to the two hole filter that measures approx. 7-1/4 inches deep.
Both canisters are the same diameter. The fuel connections on the outside of the lid are same,but the canister lids are different on the inside and outside rims. One hole has a single black o-ring that seals the lid to the canister. Two hole has a wide green o- ring that seals the lid to the canister plus a blue Olympic shaped o-ring that seals the lid/fuel passages at the center column.
Some two hole canister lids have a water removal port built into the canister lid. If you look at the two hole filter canister lid you will see the stubbed up metal tube with a torx screw and washer. To remove water from the bottom of the fuel canister you remove this torx screw and attach a line for suction. This port is connected to a fuel passage that runs to the bottom of the plastic center column. Remove approx. 3.4 oz. of fuel with a suction pump.
Both canisters have identical mounting brackets,bolts and lid attachment torx screws.
Below pic: shows the one hole filter canister on the left and the two hole filter canister on the right.
Below pic: shows the fuel canisters as compared to their fuel filter elements. The one hole filter element on the left and the two hole filter element on the right. The primary differences are the one hole element only has one green o-ring to seal the filter where it pushes onto the thermo tee tube. The two hole filter has two green o-rings.One top on bottom that seal the filter at the center column. Less chance for a bad o-ring on the one hole style. The one hole filter installs a little easier than the two hole filter. I also like the way the one hole lid indexes on the canister for proper orientation. The one hole uses two metal tabs made onto the lid,whereas the two hole filter relies on two small bumps on the center column to line up with two small indentations on the canister lid for proper orientation of the lid to canister.
The two hole filter lid has two dimples on the inside of the canister lid that line up with two matching bumps on the center column. These dimples and bumps help line up the canister lid in the correct position.
----------------PU936/1 or PU936/1X------------------ PU936 or PU936/2X------------------------
Here are the major differences between the one hole and two hole filter canisters.
Since the one hole filter canister has less depth the fuel filter element sits almost on the bottom of the canister when installed. There is little or no space in the bottom of the canister for water or sediment.
The two hole filter has almost a full 2 inches of space at the bottom of the canister to hold water/sediment.
I'm not sure why VW switched to the one hole filter design? Just my opinion,but being old school diesel. I want an area in the fuel filter canister to separate out any water or sediment.
Below pic: shows the differences between the actual filters and how they mount within the fuel filter cansiter.
The one hole filter simply slides onto a plastic tube that is built right onto the fuel canister lid. This plastic part is attached to the lid and acts just like the old thermo tee. It controls the return fuel flow thru the filter canister to allow fuel in the canister to heat up during cold weather and help prevent fuel gelling.
The two hole filter has a similar thermo device that is built into the center column and serves the same purpose in controlling the return fuel flow for heating fuel within the cansiter during cold weather.
Note: think of the cardboard as the bottom of the fuel canister. The one hole would sit on or very near the bottom of the fuel canister. The two hole filter has nearly 2 inches between the bottom of the canister and the bottom of the fuel filter element.
