Old November 27th, 2011, 20:15   #1
mcfadyen72
Default door chime disable, how?
i JUST bought a 2000 golf tdi and it was fine driving it home, the next day the door chime starts going off??!! i actually found the link on how to pull off the door panel, but then i stopped when it got to the big steel plate for the window assembly, i chickened out.
anyway i have been searching everywhere on the web on how to fix the door sensor and everything else but after all that i still have questions.
1. where is the door latch sensor? i don't see anything
2. whats the cost of just buying a new door lock sensor and having vw install it?
3. where is this relay? i don't see any relays in the fuse box that is on the drivers side dash board.
4. why did my door locks stop working intermittently after i reassembled the door panel? i pulled the fuse and put it back in and it then works fine, for a bit.
AAAAARGH!!
mcfadyen72 is offline   Reply With Quote
Old November 27th, 2011, 20:20   #2
Corsair
Corsair's Avatar
Fuel Economy: 52/48/??
Good chance you have an intermittent door position switch.
Good chance it's the drivers door (because that typically gets most wear).
This thread will probably be of interest.
http://forums.tdiclub.com/showthread...ght=switch+fix
Responding to #2- Good chance the dealer may refuse to install parts you purchased elsewhere. Also good chance the dealer cost could be relatively huge, and may take you more than one trip (more than one charge) to get it remedied.
Best Regards.... Corsair....
2002 Jetta GLS TDI 5-spd 325Kmi, 2014 JSW TDI 6M
2006 Audi A4 Quattro Avant 2.0T 6M
2004 Jetta GL wagon 2.0L (gas) 5-spd (sold)
[also had 03 TDI GLS 5spd wagon bought new, sorely missed]
Corsair is offline   Reply With Quote
Old November 27th, 2011, 20:36   #3
mcfadyen72
im thinking i just want to find the relay and pull it out, so i need to know where it is.
OR
whats the cost to have the dealer install a new vw part?
OR how can i just disable the power locks and run them manualy, with a long lock pull?
plus, that thread is pretty vague and has no pics, im not sure i want to go through with that honestly. sorry, just frustrated with my new pre-owned vw already
Old November 27th, 2011, 21:11   #4
AndyBees
AndyBees's Avatar
Gees! Do these things have a door chime? If so, mine hasn't worked from day one! Have I been blessed all these years?
'84 Vanagon '02 ALH TDI engine Malone Stage 1 tune. CAT, SS 2" exhaust, E-vac system, DMF with upgrade pilot shaft, 4.57 R&P, fan assisted IC. (32 to 35+ MPGs consistently)
Old November 27th, 2011, 21:18   #5
mcfadyen72
yes you have.
Old November 27th, 2011, 21:26   #6
Alchemist
TDI(s): '04 Golf
I can't give you a price for VW to install a new door latch assembly, but parts alone will be >$200. VW does not have the sensor, actually a switch, available separately so you must replace the entire door latch. On the MKIII cars, there was a relay on the panel below the dash, but on MKIV, it is built into the instrument cluster. There is another electrical panel, located under the dash on the firewall just in front of the clutch pedal. This is where the relays are located, but nothing that will let you silence the annoying ding. The cure is replace the latch or the switch on the latch.
Paul
I've learned so much from my mistakes I'm thinking of making some more.
Alchemist is offline   Reply With Quote
Old November 27th, 2011, 21:32   #7
AndyBees
AndyBees's Avatar
My old '87 Quantum had a chime that drove me nuts!.........damn thing worked good to the day I sent it to the junk yard!
disable seat belt chime 04 Golf ? charleez VW MKIV-A4 TDIs (VE and PD) 35 December 19th, 2010 15:15
Able to disable door chime? Mondog1 VW MKIV-A4 TDIs (VE and PD) 2 November 20th, 2007 19:41
cold/freezing chime disable? Reichard VW B5 Passat TDIs 11 July 7th, 2006 06:11
Seatbelt chime disable not working via vag-com jdh OBD Scanners 0 March 1st, 2005 13:14
Page generated in 0.13893 seconds with 10 queries
[Output: 78.81 Kb. compressed to 68.32 Kb. by saving 10.49 Kb. (13.32%)]
