JC_1992
Still have yet to receive mine as well.
On a cool engine, I put a dab of vaseline on the bottom of the pressure relief valve, stick the keystone to it, and then screw it into the pump.I have yet to find anything in installing these, I am assuming you:
1. place the keystone in the opening where the pressure relief vailve goes (with the smaller tab pointing upward)
2. Then replace and tighten the caes pressure relief valve
Am I correct?
I know this is probably very simple but I dont want to screw anything up.
Also on A side note If anyone knows places to get a new / used case pressure relief valve body please let me know. Mine is broken.
DFIS has one but I was hoping t find one local or closer than 3 to 4 days shipping
Exactly my method!On a cool engine, I put a dab of vaseline on the bottom of the pressure relief valve, stick the keystone to it, and then screw it into the pump.
Bumpity bump. So the orientation of the keystone does not matter? -- Just slap the flat surface of the keystone and center against the bottom of the valve? I'm a little mystified by the shape of the keystone if its orientation does not matter...? (I haven't removed the valve yet so it may be obvious once I look at it).On a cool engine, I put a dab of vaseline on the bottom of the pressure relief valve, stick the keystone to it, and then screw it into the pump.
Perfect, a picture is worth a thousand words.Bring it down and I'll toss it in for you, but it's easy to put in.
Here is how it sits, with a small dab of grease holding it in, so when you invert it, it doesn't fall out of the valve. When you screw the valve back in you'll feel some minor resistance at the end, but this is normal as the keystone is seating.
As to the wrench/socket, just use a 10mm open end wrench on the valve and another to turn it. It'll snap when it starts to move, but then comes out easily. I change the o-rings while it's out but have not on others and they never leaked. Piece of cake.
