Old November 22nd, 2011, 12:56   #1
rhynoscw
Default Repaired leaking tandem pump
Had the typical engine oil leak on my 05 passat. Thought it was the valve cover, but after taking valve cover off and inspecting it, I was fairly sure that it wasn't the problem. Finally found the leak by removing 90 degree elbow from intake to plastic rigid pipe, and taking a mirror and flashlight and inspecting tandem pump with engine idling. Could see oil seeping from between the sections of the tandem pump. I removed the pump and tore it apart. After contacting the dealer and learning that there are no parts available for the pump, except for the metal gasket where it mounts to the head, I decided to try to repair it. I just took a VERY LIGHT film of black silicone to all the surfaces (they had o-ring's and/or square sided packings sealing them), and also to both sides of the mounting gasket. There are passage holes in the pump and the mounting gasket, so I only put a very thin film of RTV on the surfaces, so I wouldn't plug them off. I reassembled pump and installed and so far no leaks. Beats $300 or whatever the tandem pump costs.
rhynoscw is offline   Reply With Quote
Old November 22nd, 2011, 12:59   #2
rocketboy52
rocketboy52's Avatar
Great to know! I have the same leak!
2004 VW Passat GLS TDI 221k
1999 F250 7.3l Powerstroke 283k
DIY Chainless Since 11/2011
rocketboy52 is offline   Reply With Quote
Old November 22nd, 2011, 13:04   #3
rhynoscw
rocketboy, I sent you a pm.
Old November 22nd, 2011, 13:42   #4
aja8888
aja8888's Avatar
TDI(s): Out of TDI's
Fuel Economy: About as good as it gets!
I have the same leak from BOTH our Passats.
Originally Posted by Big Mike View Post
........"Everybody has a plan until they get punched in the face." -- philosopher Mike Tyson.
aja8888 is offline   Reply With Quote
Old November 22nd, 2011, 15:48   #5
ekkoh99
I had mine replaced at the dealer
2005 Passat WGN TDI "Balance shaft upgrade by OilHammer on 3/27/2009" NGK-09 plugs in Jan 2011
ekkoh99 is offline   Reply With Quote
Old November 22nd, 2011, 15:58   #6
rhynoscw
just curious - what did it cost?
Old November 23rd, 2011, 15:13   #7
ekkoh99
It was expensive. a few hundred. They replaced the coolant flange and the tandem pump.
Old November 25th, 2011, 06:11   #8
Pinknoise
Hi guys,
The tandem pump in the UK is 281+ trade from TPS.
I also fixed mine last weekend with gasket paste, it was leaking diesel down the block.
...but, turns out that when they go like that they are usually done anyway. VAC power was down 50%. Best to test with a VAC gauage before removing, should pull -1 Bar instantly.
On a longitudinal mount B5.5 or similar car, they are tricky to get to. Best to check everything before removing.
2003 Passat Saloon TDI 130 4Motion
Legal VAGCOM
2007 Touran TDI 105 S - NOW DEAD - Needed engine, clutch and box.
Pinknoise is offline   Reply With Quote
Old November 25th, 2011, 06:16   #9
ekkoh99
I remember the tandem pump leaking. Maybe the gasket blew and then it leaked on the coolant flange or maybe it was the other way around. either way, the mechanic says it is a pain in the but to work behind the engine.
Old November 25th, 2011, 07:17   #10
Pinknoise
Totally, I had mine out three times then discovered the vac problem and
had to end up fitting a new one anyway.
Dont know about the golf/transverse engines, but on the Passats it leaks diesel over a water pipe, which deforms and eventually bursts. Most people don't realise they have a diesel leak until coolant is pouring out.
It was only I took my car to get mapped and after we didn't get the expected results we checked the vac pump.
Legal VAGCOM
Old March 11th, 2014, 23:08   #11
rocketboy52
Rynoscw,
How about an update? did the repair hold for a couple of years? Mine is leaking pretty good, but I think its motor oil? not diesel? Anyways. I figured I would check in before I pull it off. Let me know!
Thanks,
Old March 19th, 2014, 08:28   #12
Montezuma
Is there not a safety recall for the leaking tandem fuel pumps?http://www.autotrader.com/research/a...car-review.jsp
Montezuma is offline   Reply With Quote
Old March 19th, 2014, 08:32   #13
Montezuma
In the safety section, it says that the fuel pumps were recalled because of potential cause of fire. My passat is new to me and I have not checked to see if this is applicable to me, but the fact yours is leaking makes it seem like it is applicable to you.
Old March 19th, 2014, 10:52   #14
Montezuma
Then again, I maybe mistaken on the recall, as I find no mention of it besides this article. I did notice that there are quite of few threads on leaking gaskets and replacements, but no recall. Can anyone rectify my confusion?(is that even possible?)
Old April 9th, 2016, 11:15   #15
rocketboy52
Anyone know the best place to buy one of these vac pumps? How about a part number? While I have the transmission out, I'm also thinking of replacing the coolant elbow back there. Anyone know the partnumber for that one?
Thanks in advance!
Tandem pump leaking, what to replace? turbocharged798 VW MKIV-A4 TDIs (VE and PD) 9 September 5th, 2013 10:46
PD Tandem pump leaking! Wallace TDI 101 3 April 22nd, 2012 17:57
Tandem Pump drewkeen Private TDI Items for Sale/Wanted 0 April 30th, 2011 16:55
leaking tandem pump lastirishsamurai VW MKV-A5 Golf/Jettas 3 March 16th, 2009 16:24
Possible fix for leaking tandem pumps? Wallace TDI 101 4 October 9th, 2007 12:58
Page generated in 0.15056 seconds with 10 queries
[Output: 123.64 Kb. compressed to 102.61 Kb. by saving 21.03 Kb. (17.01%)]
