Old November 20th, 2011, 17:27   #1
miketoth1979
miketoth1979's Avatar
Fuel Economy: 32/46/60.5 (towing, avg., best)
Default P0402, EGR Excessive Flow, and my solution
Last week, my engine check light on my '01 5sp Golf illuminated while I was driving, and when I scanned the car, the error code read "P0402 - EGR Excessive Flow" The performance of the car was strangely not affected at all. No limp mode. Plenty of power, as always.
This struck me as odd, so I did a bunch of research on this site. Turns out, the EGR doesn't directly measure its own airflow, but instead uses an indirect measurement based on what the Mass Airflow Sensor (MAF) is reading, or some such nonsense. To get the P0402 code to show up, one of the following things was happening:
- The EGR was not opening/closing, maybe a leaky diaphragm in the EGR itself
- The EGR was not opening/closing because the N18 valve wasn't working
- The EGR was not opening/closing because of some other vacuum leak
OR
- The EGR really WAS opening and closing, but the stupid MAF sensor was measuring incorrectly, which was confusing the ECU when it didn't get the numbers it expected, which caused it to throw the engine code.
I checked for vacuum leaks but found none. N18 was working just fine. Since I have a bit of a weepy EGR, I wondered if this had anything to do with the problem...
Turns out, it doesn't, and it was just a dirty MAF sensor. I used some MAF sensor cleaner and gave it a thorough spraying (but NO scrubbing). Popped it back in the car, started it up, and no more engine code for the past several days and many miles. Glad I found that out before I spent any money on new valves, hoses, MAF sensors, etc!!
Moral of the story: code "P0402- EGR Excessive Flow" is bogus. If the EGR system really did have a vacuum leak, wouldn't the EGR be stuck closed? And that wouldn't be excessive flow at all...it would be no flow. So if you get this engine code, check your MAF, because it could be the culprit.
'01 Golf 5spd TDI 130K - Defender Steel Skidplate, Curt Towing Hitch, Independently-Powered Trailer Light Converter, DG 100k TB kit, Metra Aux ipod input added, MOOG VR6/wagon springs, Blausport shocks and struts, engine and trans stock
miketoth1979 is offline   Reply With Quote
Old January 26th, 2012, 10:07   #2
copbait
actually it is excessive flow at the maf not the egr, which is what happens when your egr is stuck closed, it is not pulling air for the cleaner because it is coming from the exhaust. But congrats on the cheap fix, I am never so lucky
copbait is offline   Reply With Quote
Old January 26th, 2012, 10:12   #3
UFO
UFO's Avatar
TDI(s): 2001 Beetle
Fuel Economy: 50mpg on B100
Yes, since the ECM is measuring EGR using the MAF, when the EGR is not flowing you read an excess amount of air, hence "excess flow". Nice that you can fix an issue by just cleaning the contacts.
2001 Beetle - EGR delete, 01M-ectomy, Atlas skidplate, vented, Frostheater.
I'm not coasting, I'm shifting slowly.
UFO is offline   Reply With Quote
Old July 29th, 2014, 09:43   #4
cumminsfromthecold
cumminsfromthecold's Avatar
Fuel Economy: TDIYota 28-30, always on B20-B99.9, R32 terrible, blue B4 TBD
Default P0402, '02 TDI Jetta Wagon
Helpful post among all of those on the P0402. I'll resurrect this one.
I've got all of the same symptoms miketoth described - great performance, yet this code.
Car is 1 week new to me. I've ruled out N18 (12V got solenoid moving just fine), EGR is clean from previous owner, EGR diaphragm holds vacuum. There was an aftermarket boost gauge line installed that I removed and capped at the custom-made hole in the hard piping line between intercooler and intake. New vacuum lines installed where needed. The one thing I haven't done is focus on the MAF sensor.
When you say you cleaned the MAF, you mean you sprayed it's screen (electrical connection cleaner?) and/or the connection contacts? Could you elaborate? Thanks
'84 Toyota truck 1Z TDI build thread, Frankentuned.
Previously: 1997 B4 Passat TDI (1Z) 5-spd (burgundy), 1999.5 Jetta TDI sedan (ALH) 5-spd, 2001 Passat W8 Sedan (01V), 2001 Jetta wagon TDI (ALH) 5-spd, 2000 Passault rallye wagon 4Motion (01V) (2.8l).
cumminsfromthecold is offline   Reply With Quote
Old July 31st, 2014, 03:24   #5
CoolAirVw
CoolAirVw's Avatar
TDI(s): Jetta
Fuel Economy: 40
This is not true at all. I've encountered this code several times and everytime its been a bad diaphragm in the egr valve vacuum pod.
Richard. ASE Certified Master Auto-Technician with L1 Advanced Engine Diagnostic Rating. ATRA Certified in Rebuilding, Diagnosing & Installing Transmissions. ASE Certified for Passenger Car Light Diesel Engine.
Now offering Malone Tunes!..............http://www.kansascitytdi.com/
CoolAirVw is offline   Reply With Quote
Old July 31st, 2014, 06:30   #6
Powder Hound
Powder Hound's Avatar
Then why did cleaning the MAF fix the OP's problem?
Old July 31st, 2014, 06:32   #7
Powder Hound
Originally Posted by cumminsfromthecold View Post
...When you say you cleaned the MAF, you mean you sprayed it's screen (electrical connection cleaner?) and/or the connection contacts? Could you elaborate? Thanks
Electrical connection cleaner would be OK for the contacts, but there is a separate MAF cleaner product that would be sprayed on the MAF sensor itself. No need to disassemble the device, just make sure the spray is directed at the sensor.
Old July 31st, 2014, 08:40   #8
Vince Waldon
Vince Waldon's Avatar
...and it's a hot film sensor rather than the more traditional hot wire sensor (needs a different can of cleaner... ie NOT the one with the picture of a a hot wire sensor on it )... and many will say spray-cleaning a hot film sensor is a crap shoot right from the get-go.
Vince Waldon Edmonton AB Canada
Note: The above is to the best of my knowledge- but at the end of the day simply interweb opinion, worth EXACTLY what you paid for it, and if used done so at your own risk.
Vince Waldon is online now   Reply With Quote
Old July 31st, 2014, 11:17   #9
CoolAirVw
CoolAirVw's Avatar
TDI(s): Jetta
Fuel Economy: 40
Then why did it fix the ones I've had here? Mine we diagnosed with information gathering from the car. The valve doesn't open, the diaphragm was ruptured. The original poster never did any real info gathering. Did he pull the elbow pipe and see if the valve opened? Did he cycle the solenoid with vagcom to see if the solenoid applied vacuum to the EGR pod? Did he pump up the actuator and see if the diaphragm was ruptured. NO he just assumed it was a dirty maf and cleaned it. If he's right then fine, but I'll bet you have to clean the maf sensor at least a dozen times to fix a ruptured diaphragm.
Why did it fix his??? How should I know? (who cares)
Theory one. He posted that it was fixed then a few days later the code reoccured.
Theory two... His code was a fluke and clearing it would have been enough.,
Theory three... who cares.
But for every one reading this... certainly, clean your Maf sensor first, just dont be confused when the code keeps reoccurring. And if you have access to a mityvac then see if the diaphram is ruptured or maybe even make some of the checks I mentioned above.
Old July 31st, 2014, 12:31   #10
Votblindub
Votblindub's Avatar
I'm signing up for more info and going to try some maf cleaner. You never know *shrugs*, it's cheap and worth a shot, at least.
Sprint 520 Nozzles, 2.5 inch catless mufflerless BuzzKen exhaust, Malone stage 3 chip, 01M, Frostheater Full details
Full details
FB page for wagon lovers I have VAGCOM/VCDS
Votblindub is offline   Reply With Quote
Old September 2nd, 2014, 04:27   #11
Powder Hound
So what happened?
Old September 2nd, 2014, 07:07   #12
Votblindub
Votblindub's Avatar
So what happened?
With mine?
Full details
Old September 2nd, 2014, 08:38   #13
CoolAirVw
CoolAirVw's Avatar
TDI(s): Jetta
Fuel Economy: 40
So what happened?
Send him a PM and ask him.
It would be nice if there was follow up.
Maybe,..,., been driving year and its worked the whole time. Car is fixed. No other work was done other than cleaning the maf.
or .... sorry I made this post as the code reoccurred 2 weeks after making the post. I eventually fixed it with a vacuum hose (or egr replacement).
Old April 11th, 2015, 19:32   #14
ukle
TDI(s): 2001 Jetta
Default My solution
I got an excessive flow error code and thought I'd share how I ended up fixing it for the archive.
I connected my mityvac to the out port of the N18 valve and saw there was maybe 4-5 inHg which told me either the vacuum pump wasn't generating vacuum or the valve wasn't passing it...
Then attached the mityvac to the EGR valve and manually vacuumed. It took about 10 inHg to actuate--I knew it was working because I saw the requested and actual flows equalize on the vagcom. EGR ruled out.
Then measured the vacuum on the line going into the N18 and saw 20-25 inHg, so I pulled the solenoid out and played around with it. Applying a voltage (12-13V to the "flat side" on the polarized connector) I'd hear a faint clunk, but nothing when the voltage was released. Vacuum wouldn't hold after releasing the voltage, and even applying vacuum to the in and closing off the out port.
Using the head of a nail, I cracked the valve open by prying apart the top half, and pulled the head off. The inside was really dirty and caked in a white powder which I thought might have been some kind of dried up lithium grease, maybe? The valve is about 14 years old after all. After gently cleaning the diaphragm and lightly coating in lithium grease, it still wouldn't work after reassembly. I figured the plunger wasn't returning to the fully upright position, perhaps the pressure exerted by the diaphragm had been reduced over the years since there wasn't a return spring.
So I cut a tiny piece of spring and dropped it down into the solenoid's hole. It just fit around the peg at the bottom and when compressed was a bit shorter than the peg, but when extended, above.
I think the spring gave it just enough of a boost to push the diaphragm back up against the tiny metal tube connected to the in port, thus sealing it.
No more code and no $200 replacement. Hoping the hack holds up...
ukle is offline   Reply With Quote
Excessive EGR Flow Detected, Code 16786 P0402 gsbar VW MKIV-A4 TDIs (VE and PD) 17 February 23rd, 2016 13:34
EGR: Excessive Flow 16786/P0402 To DIe for TDI 101 5 December 7th, 2009 16:47
P0402 troubleshooting (EGR Excessive flow detected) GardRail TDI 101 40 September 1st, 2008 18:29
P0402 Excessive EGR flow error jtmgrfx VW MKIV-A4 TDIs (VE and PD) 7 July 8th, 2005 11:41
P0402 Excessive EGR flow error jtmgrfx TDI 101 0 July 1st, 2005 10:32
Page generated in 0.16071 seconds with 10 queries
[Output: 131.63 Kb. compressed to 110.73 Kb. by saving 20.90 Kb. (15.88%)]
