Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > VW MKVI-A6 Jetta Sedan (~ 2011+)
VW MKVI-A6 Jetta Sedan (~ 2011+) Discussions area for the MkVI (2011+) Jetta sedan. This model was originally codenamed NCS (New Compact Sedan).
Old November 16th, 2011, 11:37   #1
whiplash willy
whiplash willy's Avatar
Default 39* Degree Outside Temp Warning
Does anyone know how to disable that annoying 39* Degree Outside Temp Warning that automatically comes up when it is below 40* F? (With Vag-Com)
I hate how it always pops up on the MFD screen, and switches the display from whatever it was on.
NCS & DSG Free Since 5/5/12!
whiplash willy is offline   Reply With Quote
Old November 16th, 2011, 12:03   #2
> Luke <
And I await the answer, without the Vag-Com....if available..
As of 3/2/17: Latest 10 Fill-up Moving Average = 51.5 MPG. at 260,417 miles. Zero Oil usage. Only Chevron Fuel. I also carry a 6 gallon reserve container, used weekly: Thus allowing me to fill every Sunday. Latest fuel use average from purchase date = 50.4 ^ MPG & still Very happy with my vehicle.
> Luke < is offline   Reply With Quote
Old November 16th, 2011, 12:11   #3
pdt165
What is the purpose of said warning?
LED bulbs in almost all possible locations. Aftermarket OEM Fogs. ESP Off Button. Malone Stage 1.5 Tune.
Micro-Can, Jupiter FL, PM me.
pdt165 is offline   Reply With Quote
Old November 16th, 2011, 12:23   #4
JSWTDI09
JSWTDI09's Avatar
It is to warn you of the possibility of "black ice" formation. I have no idea why they chose 39 degrees to be the warning level.
Have Fun!
Don
P.S. I, too, would be interested to know if this can be turned off. I live somewhere 39 degrees is common (in the winter) but freezing is rare.
JSWTDI09 is online now   Reply With Quote
Old November 16th, 2011, 12:25   #5
Cogen Man
Cogen Man's Avatar
Fuel Economy: Better than the Toyota FJCruiser
Possible ice formation on roads. Yes I know, 40F is a little high for ice. I hate this feature on my 2011 Golf. It pops up at 4C with a little chime sound. I use it to dust off the long johns.
Cogen Man is offline   Reply With Quote
Old November 16th, 2011, 13:02   #6
aja8888
aja8888's Avatar
TDI(s): Out of TDI's
Fuel Economy: About as good as it gets!
If it comes on in south Texas, then we know its winter!
Originally Posted by Big Mike View Post
........"Everybody has a plan until they get punched in the face." -- philosopher Mike Tyson.
aja8888 is offline   Reply With Quote
Old November 16th, 2011, 13:11   #7
jbright
Might be alerting us to the possibility of ice formation on bridges and overpasses, etc. which can ice up earlier than regular road surfaces (even if the air temperature is above freezing).
2009 Jetta TDI, black, tan interior with black dash, DSG, 16" Wheels, Build date 11/08. 'Fixed.'
47.8 mpg best tank, all interstate @ 70 mph ----- 157,000 miles on odometer.
2004 Toyota Solara SLE V6 (wife's), 1979 Diesel Rabbit (RIP), 1981 VW Diesel Pickup (RIP), 1986 Jetta gasser (gone).
jbright is offline   Reply With Quote
Old November 16th, 2011, 13:19   #8
MayorDJQ
If the air temp drops from 45F down to 39F, no ice is going to form anywhere, bridge or otherwise. The bridge superstructure will only be as cold as ambient.
I'm sure someone will chime in with "supercooling", but that's not likely to happen either.
MayorDJQ is offline   Reply With Quote
Old November 16th, 2011, 13:51   #9
Engineers<3Diesel
Ok I won't use the term supercooling. Ice can form on bridges even when the outside temp is above 32F. This is due to air flow under the bridge and pressure drops that can occur (change in pressure = change in temperature).
A good example of this is on my 70 air cooled VW beetle intake manifold. Even when it is 80 degrees outside, the pressure drop causes temps to lower and gas to drop out of suspension in the air. Also deemed a "frozen intake" they can get down to 40-50 degrees in the summer which is why tubes were put in later models to pull off exhaust gas and run it through tubes welded to the intake. This helped keep them warm and prevent the gas from "freezing".
Engineers<3Diesel is offline   Reply With Quote
Old November 16th, 2011, 14:19   #10
MN_TDI12
I was thinking about posting this exact same question. What I find annoy the most is that it take over your mini MFD but doesn't reset back to the info position that you had it on so you have to click back thru.
2012 VW Jetta TDI w/ Nav, Malone Stage 1.5 and DSG Tune, 2Micron's Contain Flow
I have VCDS - Micro/CAN
MN_TDI12 is offline   Reply With Quote
Old November 16th, 2011, 14:27   #11
740GLE
Yeah but what about when the temp goes from 0F in the morning to 39F in the afternoon you still think there may be some ice on the roads?
Old November 16th, 2011, 15:22   #12
jbright
http://science.howstuffworks.com/nat...uestion566.htm
Old November 16th, 2011, 18:05   #13
MayorDJQ
That's a different story. If it's 0F when I wake up tomorrow and warms to the 30s, I'll be expecting ice. Unfortunately the MFA isn't smart enough to know when it makes sense to warn the driver or not. If I wake up tomorrow and it's 39F and stays 39F all day, I'm still not going to worry about ice on any of the many bridges I cross during the day.
I just think the warning is stupid. I don't mind the snow flake so much, but the chime is annoying. VWs chime for everything: low fuel, low windshield washer fluid. I know American society has been dumbed-down overt the last few generations--hence only 1 in 6 Americans being able to drive a manual transmission. Why not chime when humidity rises in the cabin and condensation is likely to form on the inside of the glass? Or when it's hot outside and you shouldn't leave your dog in the car with the windows up?
Old November 16th, 2011, 18:47   #14
elconquistador
elconquistador's Avatar
LOL that's kind of a jump there, because most cars driven on the road today are Auto. There is a difference between "dumbed-down" and "ignorant" of something.
2011 VW Jetta 2.0 TDI
-Feb/2011 Build Date
2004 Isuzu Axiom
elconquistador is offline   Reply With Quote
Old November 16th, 2011, 19:38   #15
DuvalSt
Talking
I believe historically Volkswagen has sold and is still selling more manual transmissions than automatics. Probably the only manufacture (maybe other than BMW and Porsche) doing so. Of the 13 VW's I've owned, only 2 were automatics and that's because my new wife of 10 years claims she use to drive with 3 on the tree, but can't drive with 4 (or more) on the floor. Go figure. As for leaving the dog in the car when it's hot, break a window out first, then call the police. As for the chime, turn up the radio.
DuvalSt is offline   Reply With Quote
Finally got the tire pressure warning to go off -- 39 PSI ajm80031 VW MKV-A5 Golf/Jettas 21 June 8th, 2014 06:36
Why at 39 degree? MonsterTDI09 VW MKV-A5 Golf/Jettas 50 December 6th, 2010 08:10
please help. Temp warning incipienz TDI 101 9 December 18th, 2006 23:31
temp warning light went off draksia VW MKIV-A4 TDIs (VE and PD) 4 January 4th, 2003 07:55
Temp. Warning Light TDIPower VW MKIV-A4 TDIs (VE and PD) 0 August 17th, 2000 07:45
Page generated in 0.16923 seconds with 10 queries
[Output: 131.58 Kb. compressed to 109.86 Kb. by saving 21.72 Kb. (16.50%)]
