Old November 16th, 2011, 07:41   #1
97B4TDi
97B4TDi's Avatar
Fuel Economy: 46-52
Default Testing the Coolant Temp Sensor
I've noticed a lot of threads on here going over CTS issues and couldnt find anthing about this so I was curious: Is there a way to test it to determine if it is faulty?
Thanks!
'97 Passat: 315,XXX Miles, Malone Eco Tune, Bosio PP 502, FAT/KFC Mod, Ventectomy, DRL Kill, 1000 Mile Club x3 / Auto Trim DESIGN
97B4TDi is offline   Reply With Quote
Old November 16th, 2011, 08:02   #2
dieseljunkie
If you have VCDS, check coolant temp and ambient temps when the car is dead cold and they should be close to each other. If you do not have VCDS, measure the resistance of both sensors. At any given temp, one should be close to double of the other. That's what I have observed on my sensor, which I believe to be good.
96 Passat TDI wagon ~145k SOLD!
92 Ecodiesel 205k
dieseljunkie is offline   Reply With Quote
Old November 16th, 2011, 08:19   #3
97B4TDi
97B4TDi's Avatar
Fuel Economy: 46-52
Thanks!
I know one is close to the block.
Where is the other?
Old November 16th, 2011, 08:39   #4
dieseljunkie
It's on the plastic coolant flange on the head between cyls 3 and 4. It has 4 terminals, 2 per sensor.
92 Ecodiesel 205k
Old November 16th, 2011, 14:00   #5
97B4TDi
97B4TDi's Avatar
Fuel Economy: 46-52
Alright, i'll check it out!
Thanks again for the help.
Old November 17th, 2011, 07:52   #6
97B4TDi
97B4TDi's Avatar
Fuel Economy: 46-52
Ok What pins go to what sensor?
Im asking this because the temp has been floating around 160-175 on my dash gauge rather than the normal ~190. I've noticed it for a while and may just benefit from replacing it and seeing where to go from there. The car I am referring to is in my signature and for a little history i have no clue if or when the thermostat was last replaced.
Old November 19th, 2011, 07:17   #7
mech644
I had a similar situation with my Golf, ALH vs AHU but systems function similarly. I replaced the temp sensor and the thermostat, problem all fixed. The 'stats have a reputation of becoming slow to respond over time and the sensors can be dodgy as well
2012 Platinum S-line A3 DSG- bought back by VW
2000 Golf 5spd, 301k, the usual mods, sits forlornly in the backyard.
2006 Jetta DSG- gone
2015 GHB SEL 1.8 tsi
2014 Touareg
mech644 is offline   Reply With Quote
Old November 19th, 2011, 07:42   #8
dieseljunkie
Search for a Digital Corpus's thread that I posted in. I think I posted which color wires is which sensor.
92 Ecodiesel 205k
Ambient Temp Sensor Testing? tron2003 TDI 101 34 September 8th, 2016 16:48
Replaced the coolant temp sensor. fixed short GP cycle, now temp gauge is wrong. 2TDIguy VW MKIII-A3/B4 TDIs 3 October 21st, 2010 17:55
Coolant temp sensor Resistance vs Temp plot billybaru13 TDI 101 6 January 28th, 2010 15:08
coolant temp sensor replace, w/o coolant drain frugality VW MKIV-A4 TDIs (VE and PD) 27 April 13th, 2008 08:00
Coolant temp sensor vs. fuel temp sensor Jimwsea TDI 101 0 May 16th, 2006 05:54
Page generated in 0.14547 seconds with 10 queries
[Output: 88.38 Kb. compressed to 76.23 Kb. by saving 12.15 Kb. (13.75%)]
