Go Back   TDIClub Forums > Meetings/ GTG/ Regional Discussions > Ontario
Ontario Local discussions for those in the Ontario, Canada area.
Old November 14th, 2011, 15:18   #1
VWblue
Default Wet floor driver side
I found my driver side floor very wet.
Today heavy rain and I believe somewhere leak into my car. And my vent is open and I should close vent and will stop leak?
Or else somewhere? Let me know.
Thx
VWblue is offline   Reply With Quote
Old November 14th, 2011, 15:30   #2
Chris Tobin
Chris Tobin's Avatar
My '06 did this to the rear passenger side and some in the front passenger side floor. I suspect sunroof drain problems but have yet to confirm it. For now I park on my sloped driveway with the nose downhill if rain is expected and it hasen't leaked again yet. It was parked nose uphil when it leaked the first time.
I hope to fix it soon... I understand that there is a class action suit against VW but we may be too late to get anything from it. My local dealer in Chattanooga, TN said that there is no recall or sunroof related problem with my car according to the vin... Ya, I trust them...
Chris Tobin Freelance Editor & Photographer
Working with DIESEL WORLD, DIRT SPORTS & other mags
Custom poster size photos available. PM or email for info.
Chris Tobin is offline   Reply With Quote
Old November 14th, 2011, 15:52   #3
Toronto_Vento
Toronto_Vento's Avatar
Fuel Economy: 50/48/44
Open driver and passenger door and check the rubber nipple on the car frame towards the front of the door. I'm sure someone will post a picture. Anyhow, your sunroof drains are probably clogged. There is a TSB on this. Basically, take a pair of scissors and cut off the tip so that the drain is wide open.
If you don't have a sunroof, then obviously it's something else.
-- John K
Wingnut's HOW TO's thread
"The commuting system is so badly broken that it will take decades just to bring it up to a level where it is merely malfunctioning." - Globe Drive
Toronto_Vento is offline   Reply With Quote
Old November 14th, 2011, 15:56   #4
P2B
P2B's Avatar
Do you have a sunroof?
http://www.volksbloggin.com/2007/07/...-flowing-well/
Simon
Jettas for 29 years, TDIs for 13.
2003 Silver Jetta TDI GLS 220K PP520 RC3 6-Speed ERF
2003 Silver Jetta TDI Wagon 180K PP520 RC2
2000 Canyon Red Jetta TDI GLS 300K
P2B is offline   Reply With Quote
Old November 14th, 2011, 16:02   #5
VWblue
Yes I do have sunroof. I will check tomorrow with drain hose.
And what is TSB?
Thx
Old November 14th, 2011, 16:06   #6
VWblue
Originally Posted by P2B View Post
Thank you for link.
Old November 14th, 2011, 17:25   #7
mrvermin
mrvermin's Avatar
VW has a TSB for that issue as posted above, your local Dealer can take care of it No Charge. Just print out the TSB and take it with you to the dealer, 5 minute fix.
MrVermin
NEW: 2011 Golf Sportwagen Highline, Navi, DSG, Pano-Roof
OLD: 2001 Jetta TDI: 6speed ERF swap, Fully Built Block & Head, RC Tuned, Race520's,
Colt Stage2 Cam, PD150 Intake, PD150 RacePipe, VNT17/22, OMI, 3" Full Exhaust, 3BAR MAP, 11mm IP, Defender Skidplate, 17" Ariettas, GLI Suspension, Audi TT LCA Bushings,
mrvermin is offline   Reply With Quote
Old November 14th, 2011, 17:44   #8
VWblue
MrVermin
I found TSB said:
6007-06 JUN 07 Body - Sunroof Malfunctions or is Inoperative
That's correct?
Old November 14th, 2011, 18:02   #9
mrvermin
mrvermin's Avatar
VW TSB Number: SA-60A7-S9
MrVermin
Old November 14th, 2011, 18:49   #10
VWblue
MrVermin
Thx and will go vw dealer tomorrow to fix.
Old November 15th, 2011, 06:58   #11
Brian_Spilsbury
Fuel Economy: 4.92 ltr/100
I thought I had found the source of the leak on my driver side. The grommet for the hood release cable had a mouse nest around it. No joy though.
It poured here last night, both outside and into my car.
I don't have a sunroof.
I'm starting to think it will be less effort to build a garage than find the leak.
2004 JETTA 5 spd, stage 1
Brian_Spilsbury is offline   Reply With Quote
Old November 15th, 2011, 09:22   #12
JASONP
JASONP's Avatar
Fuel Economy: 4.5l/100
Also may want to remove the inner wheelwell liners and remove the dirt, leaves and debris that accumulates over the years
Sent from my iPhone 4S using Tapatalk
2015 Golf TDI Comfort line
2L, 6spd, Leatherette 4.5L/100 km
2001 Jetta TDI 357,000 km 01M/2002 Golf TDI 285,000 km 01/2010 GSW TDI 115,000 km 6MT/2013 Jetta TDI 47,000 km 6MT
JASONP is offline   Reply With Quote
Old November 15th, 2011, 10:57   #13
mrvermin
mrvermin's Avatar
You may want to check the Windshield seals. I encountered that issue when I borrowed a friend's car while mine was out of service. The windsield seal was leaking and while it rained it came in down the "A" pillar.
Just a thought.
MrVermin
Old November 15th, 2011, 14:33   #14
VWblue
VW Dealer fixed the drain today and wait for heavy rain.
Old November 15th, 2011, 14:33   #15
VWblue
Wet Floor, driver's side Brian_Spilsbury VW MKIV-A4 TDIs (VE and PD) 24 January 7th, 2018 11:24
Wet floor in rear passenger side blthomas General VW Discussion 20 October 5th, 2015 14:57
floor is wet on passenger side Got Haggis? TDI 101 19 March 16th, 2011 17:53
Wet Floor Drivers Side Rear TDI2Fan TDI 101 9 December 22nd, 2008 09:10
Front Pass side floor wet Arthur VW MKIV-A4 TDIs (VE and PD) 16 August 15th, 2004 19:59
Page generated in 0.18460 seconds with 10 queries
[Output: 129.38 Kb. compressed to 107.36 Kb. by saving 22.03 Kb. (17.02%)]
