Old November 11th, 2011, 10:54   #1
lambo11293
TDI(s): leon
Default flashing dash lights and beeping
basically when ever i switch off my 2001 seat leon tdi all the dash lights start flashing and beeping, i have tried everything and it still continues, so now its either send my instrument panel off to be looked at or get another but does anybody know if they have like a imobiliser built in to it please or whether i can just plug another one in and it will all work, cheers.
lambo11293 is offline   Reply With Quote
Old November 11th, 2011, 10:59   #2
Geobmx4life
Geobmx4life's Avatar
Fuel Economy: 2005Golf TDI 50mpg...best 60
Find someone with VCDS/Vag-Com, near you and have the codes read.
Geobmx4life is offline   Reply With Quote
Old November 11th, 2011, 14:58   #3
Joe_Meehan
Joe_Meehan's Avatar
Fuel Economy: mid-upper 40's city upper 50's - low 60's Highway
You may be able to have your local auto parts store try to read any codes that may be stored. Many will do it for free. They generally can't read all our codes, but they may be able to pin it down. Vag-com or VCDS are better, but not always easy to find.
Good Luck
Joe Meehan
2002 NB Silver Ohio BAA HUM
Joe_Meehan is offline   Reply With Quote
Old November 11th, 2011, 16:00   #4
Seatman
Seatman's Avatar
Fuel Economy: No idea
They need to be programmed in but it could be something else, what have you tried so far?
Seatman is offline   Reply With Quote
Old November 12th, 2011, 04:32   #5
lambo11293
TDI(s): leon
I have tested earth strap for resistance which was 0.001 if i remember rightly, i then cleaned up earth conections from battery to chasis and bell housing and done another earth. when i first cleaned the earths off all i had on me was a flat blade @crewdriver but that stopped it for a week and once it started again i did it properly with sand paper and had no luck which is when i did another earth and still had no luck! I have a plug in computer at work so ill have a look on that on monday, i also know a vag specialist so ill have a word with him and see what he says but i think the next thing is to send mine off for testing, i kind of hope its ecu because i again know a guy who will do it cheap and ill get him to chip it at the same time, cheers for all help.
ABS and flashing Brake dash lights on my '03 Jetta TDI Wagon...Advice? Sideoiler TDI 101 36 September 18th, 2015 17:59
Flashing dash lights. JAnderson VW MKV-A5 Golf/Jettas 1 July 19th, 2010 15:46
Brake light beeping and flashing slm801 TDI 101 3 May 22nd, 2006 05:09
Brake and ABS lights flashing, beeping. snoopis VW MKIV-A4 TDIs (VE and PD) 11 April 25th, 2005 18:18
Flashing dash lights!!?? elitdi TDI 101 3 August 27th, 2004 05:41
Page generated in 0.10270 seconds with 11 queries
[Output: 68.54 Kb. compressed to 60.67 Kb. by saving 7.87 Kb. (11.48%)]
