Old December 5th, 2001, 10:05   #1
vwbmw
Fuel Economy: 47
Default Translation of Fuse info-card icons?!?
Well, I've just taken delivery of my first TDI: 02Golf5M4dr-blk/blk! ..with a free/spare relay 109 [img]images/icons/wink.gif[/img] Yesterday I was helping someone solve a malfunction in tailight assembly on an '87 Jetta ..easily diagnosed thanks to the owners manual having a concise list in fuse-numerical order, with 2-3 english WORDS describing what's fused and the fuse SIZE needed. So whazzup with the lame "internationalized" fuse "icon" reference card in the new cars [img]images/icons/confused.gif[/img] I'd asked the salesman to provide me copy of whatever TEXT version of those Icons the service guys must have in a manual somewhere; he says service uses the same icon-card (hard to believe). I've enlarged the icon-card 2X and still can't readily guess what half of them are! ..nor does it indicate fuse needed. Yes, in daylight, I can see the color of the fuse, but Murphy's law suggests that it'll be dark and raining when I'd need to figure out what's needed. The '87 manual lets one learn what's likely needed without even looking at the fuse box. The 2002 icon-card seems counterintuitive, a step backward. I've only flipped through the manual once, so may have missed something ..but is there a URL that decodes these too-clever icons?!
vwbmw is offline   Reply With Quote
Old December 5th, 2001, 10:32   #2
MOGolf
MOGolf's Avatar
Default Re: Translation of Fuse info-card icons?!?
See this jpg; print it and put a copy in your glove box. It comes from the RB manual. Size is about 300K.
99.5-02 Jetta/Golf fuses
MOGolf is offline   Reply With Quote
Old December 10th, 2001, 08:31   #3
vwbmw
Fuel Economy: 47
Thanks, MIGolf, for the reference (can't access it yet since the image server is down). Sorta surprised no one else shares my inability to decipher the fuse icon-card symbols. 3 show a 'key', but each means what? 5 are an engine w/'zap', but differ how? Several other duplicates, etc, and 10 that look like an open book with a ! on left 'page' ..perhaps those are for MS-Windows plug-ins :~)
Old December 10th, 2001, 10:01   #4
gardentender
RIP, Gone But Not Forgotten
Fuel Economy: 53+/46/41
vwbmw, you are not the only one that's been stymied by those hieroglyphics.
gardentender is offline   Reply With Quote
Old February 3rd, 2013, 11:03   #5
Lee L
TDI(s): '04 Jetta
Fuel Economy: 38/42
Thanks for posting a readable version. My sunroof has developed a mind of it's own and the last thing you want to see on a snowy morning is your sunroof tilted open with no human input. So being able to pull the fuse offers piece of mind.
Lee L is offline   Reply With Quote
Old February 4th, 2013, 08:36   #6
TDIGAZ
TDIGAZ's Avatar
Fuel Economy: Of Course! 5.05 l/100kms or 56 mpg/47 USmpg over 316 fill-ups
Some more fuse info...
Fuse arangements in fuse bracket/battery:
S162. Glow plugs (coolant) (50A).
S163. Fuel pump (FP) relay/glow plug relay (50A).
S164. Coolant fan control (FC) control module/coolant fan (40A).
S176. Relays panel interior (110A).
S177. Generator (GEN) (90 Amp.) (110A).
Generator (GEN) (120 Amp.) (150A).
S178. ABS (hydraulic pump) (30A).
S179. ABS (30A).
S180. Coolant fan (30A).
"Life is a Highway"
Protected by an Evolution Atlas skid plate
Some handy 'How to's' : Troubleshooting Low Power (AKA Limp Mode)
TDIGAZ is offline   Reply With Quote
Old February 4th, 2013, 09:07   #7
Rxfire
Rxfire's Avatar
MKIV FUSE LIST
1. Washer nozzle heaters, glove compartment light, memory seat control module (10A).
2. Turn signal lights (10A).
3. Fog light relay, instrument panel light dimmer switch (5A).
4. License plate light (5A).
5. Comfort system, cruise control, Climatronic, A/C, heated seat control modules, automatic day/night interior mirror, control module for multi-function steering wheel, control unit in steering wheel (7.5A).
6. Central locking system (5A).
7. Back-up lights, speedometer vehicle speed sensor (VSS) (10A).
8. Open
9. Anti-lock brake system (ABS) (5A).
10. Engine control module (ECM): gasoline engine (10A); diesel engine, Model Year 2000 > (5A).
11. Instrument cluster, shift lock solenoid (5A).
12. Data Link Connector (DLC) power supply (7.5A).
13. Brake tail lights (10A).
14. Interior lights, central locking system (10A).
15. Instrument cluster, transmission control module (TCM) (5A).
16. A/C clutch, after-run coolant pump (10A).
17. Open.
18. Headlight high beam, right (10A).
19. Headlight high beam, left (10A).
20. Headlight low beam, right (15A).
21. Headlight low beam, left (15A).
22. Parking lights right, side marker right (5A).
23. Parking lights left, side marker left (5A).
24. Windshield and rear window washer pump, windshield wiper motor (20A).
25. Fresh air blower, Climatronic, A/C (25A).
26. Rear window defogger (25A).
27. Motor for rear windshield wiper (15A).
28. Fuel pump (FP) (15A).
29. Engine control module (ECM) gasoline engine (15A); diesel engine (10A).
30. Power sunroof control module (20A).
31. Transmission control module (TCM) (20A).
32. Injectors: gasoline engine (10A); diesel engine (15A).
33. Headlight washer system (20A).
34. Engine control elements (10A).
35. 12 V power outlet (in luggage compartment) (30A).
36. Fog lights (15A).
37. Terminal (86S) on radio, Instrument cluster (10A).
38.
Central locking system (with power windows), luggage compartment light, remote/fuel tank door, motor to unlock rear lid (15A).
39. Emergency flashers (15A).
40. Dual tone horn (20A).
41. Cigarette lighter (15A).
42. Radio (25A).
43. Engine control elements (10A).
44. Heated seats (15A).
S179. ABS (30A).
2 each 2003 GLS Jetta Wagons (White/tan leather and White/black leather), 5 speeds, Panzer plates, roof rack cross bars (hers), homelinks, 520 nozzles, ventectomies, trailer hitch (mine), VR6 front springs (hers); 1 inch lift kit w/ESP (mine) 1986 Isuzu Trooper Turbo Diesel, 1985 Isuzu P'up NA Diesel
Rxfire is offline   Reply With Quote
Old January 27th, 2014, 09:59   #8
coachgeo
Originally Posted by Rxfire View Post
MKIV FUSE LIST
not correct. #28 is an empty slot with no fuse contacts on my 2000 TDI Golf
coachgeo is offline   Reply With Quote
Old January 27th, 2014, 14:38   #9
eric_chapman
TDI(s): 2000 alh
Fuel Economy: crappy
cause the TDI has no fuel pump, its says gasoline engines only in the bently
eric_chapman is offline   Reply With Quote
Old January 27th, 2014, 18:12   #10
muzy
TDI(s): 02 jetta TDI
Fuel Economy: in process
But if it were a gasoline car it would have? Pretty sure the gas and diesel share same fuse block?
muzy is offline   Reply With Quote
Old January 27th, 2014, 20:49   #11
coachgeo
While your correct this is a TDI forum w/tdi discussions Now where is that poking ya with a stick emoticon when you need it
anyway judging (or miss judging) by comments in here and other threads; apparently some TDI's do have a fuel pump in the tank? Just not the 2000 model year?
This has all been so confusing. A good number of folk have mentioned in here that the Bently Manuel can be rather vague and in some places actually wrong in one place and correct in another on the same topic. In particular the electrical info.
Page generated in 0.15580 seconds with 9 queries
[Output: 101.79 Kb. compressed to 86.34 Kb. by saving 15.45 Kb. (15.18%)]
