Go Back   TDIClub Forums > VW TDI Discussion Areas > TDI Fuel Economy
TDI Fuel Economy Discussions about increasing the fuel economy of your TDI engine. Non TDI related postings will be moved or removed.
Old November 13th, 2011, 16:17   #16
Good Ol' Boy
VeeDubTDI's Avatar
Fuel Economy: see signature
Vekke, thanks for putting this thread and all of the videos together. It is all great information and I've enjoyed it.
Subscribed!
Trusted TDI Mechanics Map || TDIClub Chat
Old November 19th, 2011, 06:34   #17
Drivbiwire
Zehntes Jahr der Veteran
Originally Posted by davidm2232 View Post
so what i'm being told is that it is more efficient to push the accelerator to the floor and rev the engine up? i was always told that gradual accelerations, shifting at 1800-2100 will yield the best MPG's. I feel that in testing, if i drive more conservatively, i get better mileage. should i raise my IQ to reduce smoke under heavy acceleration? i just can't believe that faster acceleration and higher RPM's will not hurt fuel economy.
Yup, holds true even on a 747.
You burn less fuel to get to altitude at full climb power than at a reduced climb power setting. (We have three settings to choose from).
Full climb power reduces the time to climb, getting you to altitude faster and reducing the total fuel consumption. Also just like a TDI a jet engine has a near identical efficiency
map (lean burn engine just like a diesel).
The drawback is that the engines run at a higher power setting which can account for some reduction in service life (could be a factor on a $18M engine times 4), not that this is ever a concern on a stock or modified TDI engine.
For a TDI you want to get up to speed quickly and reduce the time spent in the less efficient rpm/load ranges.
Nice compilation!
Specializing in Injectors for CRI, CR, PD, VE, IDI VW, Audi, MB, SEAT and Skoda Diesel engines.
Offical Importer, Distributor and Installer for Fratelli Bosio, S.R.L. North America
Quotes and Pricing for TDI Injectors
Old November 19th, 2011, 07:20   #18
manual_tranny
Smyth Performance- Intern
manual_tranny's Avatar
Fuel Economy: Is just one piece of the puzzle that is our bottomless appetite for oil. Cars donít have to be consumable. Instead of throwing them away, we can rebuild them, better. We have the technology.
Wonderful thread! I have been thinking of making similar videos for a while now, but you beat me to it!! Thank you!
manual_tranny is offline   Reply With Quote
Old November 19th, 2011, 07:37   #19
Cogen Man
Cogen Man's Avatar
Fuel Economy: Better than the Toyota FJCruiser
Enjoyed your vid's. Made perfect sense. We can all benefit from applying these techniques. All we have to do is want to. I for one have been using some of these techniques ever sense I purchased my Golf TDI. I've gone from being a gas hog to a diesel miser. And actually having fun doing it.
Cogen Man is offline   Reply With Quote
Old November 19th, 2011, 08:09   #20
Good Ol' Boy
VeeDubTDI's Avatar
I think this thread should be a sticky.
Old November 19th, 2011, 08:13   #21
manual_tranny
X2!! Needs to be at the top of the list!!
Old November 19th, 2011, 08:42   #22
biglipps66
It all makes sense but boy am I afraid to try it for even 1 tank of fuel lol. I think my next fill up Ill try and floor it to get to speed and see what happens
biglipps66 is offline   Reply With Quote
Old November 19th, 2011, 08:45   #23
manual_tranny
Keep in mind that actually putting the pedal to the floor is not the best way to get good efficiency. For many of us, that would mean spinning our tires... not the most efficient way to drive.
50%-80% throttle will get most of us into the efficient range we're looking for without wasting fuel lighting up our tires.
Old November 19th, 2011, 08:48   #24
Good Ol' Boy
VeeDubTDI's Avatar
Exactly. 50-80% should be sufficient to get you up to speed quickly without blowing smoke, spinning tires, or generally being obnoxious. The point is, don't be afraid to load the engine up and use a good amount of turbo boost. The quicker you get up to speed, the quicker you can start coasting and using P&G techniques.
Old November 19th, 2011, 09:26   #25
biglipps66
2 very good posts thanks fellas.
I actually noticed this on both of my first big fill ups come to think of it. The first one I averaged 38.6 with my foot in the throttle quite a bit. The second I averaged 40.4, babied it a lot more and had an additional 110 miles of travel though as well. Ill definitely try this out.
EDIT:
How does this work with having to accelerate only 100-200 feet before a turn? 50-80% still and coast in gear or just go slow through a couple gears without much load?
Old November 19th, 2011, 10:49   #26
TDIMeister
Phd of TDIClub Enthusiast
Moderator at Large
TDIMeister's Avatar
TDI(s): TDI
For those who do not know or doubt how this is possible, understand that accelerating swiftly to the desired steady-state speed and posted limits does not mean driving the car in general aggressively like you stole it. On the direct contrary, you get to speed while upshifting as early as reasonably possible and looking well ahead and planning your moves, getting off the go-pedal well before stops and keeping forward momentum up where possible. I've heard a useful analogy just for illustrative purposes and it goes something like, "it's not the use of the accelerator pedal that wastes energy, but the use of the brakes."
Old November 19th, 2011, 11:03   #27
Cogen Man
Cogen Man's Avatar
Yes, this is what I believe the OP means. Also think this should be a sticky.
Old November 19th, 2011, 13:44   #28
Good Ol' Boy
VeeDubTDI's Avatar
Exactly!
Vekke's City Driving Techniques video is superb. Pay close attention as he describes his thought process while driving. To me, this verbal walk-through is the best part of the video. http://www.youtube.com/user/TunekoLt.../1/THkVciVpmxs
Old November 19th, 2011, 18:37   #29
rtn1911
Fuel Economy: Better than my Cummins
Exactly!
Agreed! The videos are great.
2011 Golf TDI 6M 2DR Blue Graphite Metallic
2009 Dodge Ram 6.7L Cummins 68RFE QC
rtn1911 is offline   Reply With Quote
Old November 20th, 2011, 12:16   #30
Vekke
Vekke's Avatar
I try to get the camera more stable ground, now it shakes little bit. Note that those are first takes on each run and some routes like in that city driving video I dont know the timing of the lights from memory.
In that finnish video is talked also about the slipping tires. you can minimize that by lining up in the intersection so that you dont have to turn your steering wheel so much when you leave it. That means more torgue can be applied to forwand movement without slipping wheels . Little slip is good for fastest acceleration but only very little, basicly you cannot control it unless you have LSD gearbox and even so its very difficult. Its best not slip at all for your tires sake.
Tomorrow will try to shoot next city driving video with more traffic. Also roads already start to be on ice so that tire slipping might be real problem tomorrow. Talking while driving is pretty easy because I know what I should and will do but trying to teach drive somebody from helpdrivers side is 5 times more difficult. You dont know what he does and his driving skills etc...
www.tuneko.com
LESS DRAG = LESS FUEL
Vekke is offline   Reply With Quote
fuel consumption lbpred TDI Fuel Economy 2 January 30th, 2012 13:53
Fuel consumption roypaci TDI Fuel Economy 0 June 16th, 2010 01:30
Fuel consumption roypaci TDI 101 0 June 15th, 2010 14:07
Fuel Consumption tdi-boy TDI Fuel Economy 2 July 2nd, 2008 17:39
fuel consumption TDI PD 130 TDI Fuel Economy 3 March 12th, 2006 18:07
Page generated in 0.17870 seconds with 10 queries
[Output: 141.84 Kb. compressed to 119.63 Kb. by saving 22.21 Kb. (15.66%)]
