Old November 6th, 2011, 19:59   #1
altern8energy
Default 2009 Jetta TDI 65,000 miles Glow Plug light flashing..
So here's my story.. Friday morning I've begun my trip to work which is about 55 miles away. 10 miles into it, while accelerating to get onto I-20, I get a flashing `Glow Plug' light on the instrument cluster. I'm like ***?!? So I drive it a bit to see if it will go out. It goes out when I'm slowing down while taking an off ramp 12 miles away from where the indicator started flashing.. So I start to take off again and about a minute later it starts flashing again....If I slow down abruptly, the light goes out..This doesn't look good and the damn owners manual doesn't really tell me much, other than it needs to be serviced.. Really?!? No ****!!
So luckily the place where I bought by 2009 Jetta TDI was only a couple miles from where I work. So I drive it into the Service Center and actually for once have the damn indicators flashing so someone can see it and I was told it would take about 45 minutes for a tech to get to it and then another hour or so to diagnose it. I'm like ok.. Well I need to get a rental so I can get back to work..
So lunch time passes and I check in on my car.. ****ing $2200.00 because a diaphragm within the turbo assembly is gone and they can't just replace that. They have to replace the whole turbo assembly. ***?!? $1200 for the turbo assembly and $800+ for labor and another $100+ to upgrade the software in my ECU, because they claim it's needed..
I only owe like $5000 on the car and I get this kind of problem at 65,000??
I asked the guy who heads the service center if this is a known issue, and he says, they get 1-2 a year that do it.. I'm like, shouldn't this be a recall issue?? Why would the diaphragm that makes up part of the turbo and Wastegate, just disintegrate.. and what would this have to do with the Glowplug indicator flashing.. He couldn't answer that question..
I hope to hell I'm not getting bufued by a VW service center because the economy is bad and they can't move enough cars, so they start screwing the customers with fraudulent repairs.
I'm thinking to myself, how do they know it's this issue?? Wouldn't they have to actually disassemble part of engine to get to the turbo assembly? Or did a ECU dump tell them this??
This is the 2nd VW I've owned that has developed hellaious repair bills. I used to have a 1995 GTIVR6 that I bought brand new and it was a blast to drive then one day the syncros between 2nd and 3rd gear locked up and I was stuck in 3rd gear.. That was a $2000 job as well.. and after they fixed it, it never did shift right...
I wasn't expecting any major repair issues until the car was well over the 150K mark.
Tomorrow or Tuesday I'm suppose to pick up my car.. I'm asking them to provide me the old turbo assembly, so I can inspect it myself. If what they say is true with having to replace the whole turbo assembly, that's pretty damn bad that VW would design a part that part of it would fail and you would have to replace the whole damn thing.. What's next? Glow Plug actually goes out and they have to replace the engine too??
That's it for now..
altern8energy is offline   Reply With Quote
Old November 7th, 2011, 07:58   #2
maine09tdi
Find a VW guru. I had the exact same thing (@108k) and KMHmotors in Lowell MA was able to make a custom bracket and use the turbo actuator from an 06 turbo (which btw you can buy) and not make me replace the turbo.
Keith: I'm thinking you could make a fortune selling the custom bracket and actuator as a "09 turbo actuator assembly".
Now I'm not sure if doing that causes any unforeseen issues, but I had my fixed last week and put ~800 miles on it and it runs great! Way cheaper than 2k for a new turbo.
If you do end up letting the dealer replace the turbo, definitely ask for the part back. Sometime someone is going to blow a turbo and you'll hopefully be able to get some use out of it. Eventually someone is going to be able to sell the real 09 turbo actuator and stop this foolishness, but until then a custom bracket seems like the right answer.
maine09tdi is offline   Reply With Quote
Old November 7th, 2011, 14:31   #3
740GLE
do a search for turbo failing on the 09+ it's becoming more common. Saddly what should be a $500 repair is $2200 because no one sources just the actuator yet.
BTW how would you discribe your driving? you agressive? sounds like you put a lot of highway miles on it.
Old November 7th, 2011, 15:05   #4
MonsterTDI09
MonsterTDI09's Avatar
One question was the hood insulation sagging? In the back of the engine compartment in the middle.
2010 Jetta sedan TDI DSG Platinum gray metallic.Build date (5/10) Mods ----EV skid plate, E code head lamps, Polar FIS
A cleaning service for DPF. http://www.dpfregeneration.com/ I have no affiliation
MonsterTDI09 is offline   Reply With Quote
Old November 7th, 2011, 17:38   #5
altern8energy
driver's side front of the hood insulation had shrunk and the tabs no longer were long enough to keep the insulation in place. I ended up using some small zipties to attach it back to the hood.
what would sagging insulation have to do with a part of the turbo going out?
Old November 7th, 2011, 17:40   #6
altern8energy
I do mostly highway driving and I do get on it from time to time to clear out the DPF.
Old November 7th, 2011, 20:18   #7
MonsterTDI09
It may be trapping heat on to actuator it's just a though.
Old November 8th, 2011, 13:21   #8
740GLE
sounds like the same way i drive
Old June 10th, 2014, 15:12   #9
JohnQ
TDI(s): Jetta
This just happened to me... and.. i popped my hood thinking, no way- but yes my hood insulation had also popped out in the rear two tabs passenger side...
I also noticed the there was a cover that was popped off of an air intake compartment? Im not familiar with turbos but it was abutting the front of the engine bay to the left (if you are facing the front of the car) of the driver side headlight.
What gives? Im not sure how long ive been driving with that cover off.
Also a 2009 jetta tdi.
Ive never had frequent problems on any of the cars ive owned in the past.. im beginning to be fearful of being both a VW owner and a diesel owner.
JohnQ is offline   Reply With Quote
Old June 11th, 2014, 11:57   #10
MacBuckeye
MacBuckeye's Avatar
TDI(s): 2009 Jetta
Fuel Economy: 40 avrg, 46.5 best
My turbo failure story (thread).....
http://forums.tdiclub.com/showthread...=turbo+failure
I would get the dealer to work with you on price. Most will if you ask them.
Sorry to hear and yes, it suxx!
2009 Jetta TDi, 191,800 miles later.... off to the crusher!
Enjoying my 2017 Honda Accord Sport SE....
MacBuckeye is offline   Reply With Quote
Old June 11th, 2014, 20:57   #11
turbocharged798
turbocharged798's Avatar
Fuel Economy: 40-50mpg
The turbo actuator is available as a separate part. PN 03L198716A
You can buy it on IDparts:
http://idparts.com/catalog/product_i...oducts_id=2797
A bit pricey but a heck of a lot cheaper than a new turbo. Pretty sad that the dealerships don't know about this and screw people over with a new turbo.
99.5 Black Jetta TDI; DLC1019 nozzles, G60/VR6, ASV .5mm pistons, EGR delete, ASR/EDL, bilstein TCs MFA cluster.. Beater car. 365K miles and climbing.
99.5 Red Jetta TDI. Saved from the crusher. 270K
04 Jetta TDI .MFA cluster, reverse light mod, bilstein TCs 200K.
turbocharged798 is offline   Reply With Quote
Old June 14th, 2014, 07:27   #12
jetta ,97
jetta ,97's Avatar
Fuel Economy: Very good
They were not available at first place.
They stated being available sometimes in 2012.
I do any repair on all models,USED/NEW ECU and Cluster swap, Reprogramming Keys , Immobilizer Delete,Cluster LCD Dispay Repair -Clik here
I am trusted TDI Mechanic, VCDS
HEX+CAN
ECU TUNING-TDTUNING Authorized Dealer
MK6 Needle Sweep,MK5 with MK6 Cluster
jetta ,97 is offline   Reply With Quote
Old June 14th, 2014, 07:36   #13
turbocharged798
Wish people would stop bumping old threads. At least state its an old thread before replying.
Old June 19th, 2014, 06:20   #14
geoman
might be an old thread but sadly is still a relevant one. for all those who care to listen, if u can't rig up a turbo timer, for goodness' sake don't turn off your car after a long hot trip or when its still hot under the hood. idle your vehic for a min or two, don't interrupt regens and you'll keep your turbo longer and less cooked! also check your 2 fans because they are hardly robust in these models. yes it will affect your fuel econ but this expense pales in comparison to the potential repair bill.
now about fuel economy...
you've got it so use it!
save a turbo...idle for 1-2min after a hot trip before shutting down.
geoman is offline   Reply With Quote
Old June 22nd, 2014, 18:00   #15
jscsir10
TDI(s): 2009 jetta
also note that the the turbo diaphragm is replacable and it only costs 600 with labor. i fought for this after my dealer played stupid about it. i had to bring them the part number in hand and make them look for it. they where not happy but did the job.
jscsir10 is offline   Reply With Quote
Particulate filter Icon, Glow plug indicator flashing, check engine light, 2009 tdi Sideways240sx VW MKV-A5 Golf/Jettas 40 July 28th, 2013 07:02
Flashing glow plug light after 5 miles? ourkid VW MKIII-A3/B4 TDIs 8 January 26th, 2011 08:22
Glow plug warning light flashing in 2001 Jetta TDI shawnna VW MKIV-A4 TDIs (VE and PD) 4 August 16th, 2010 16:50
2010 TDI Glow Plug Light Flashing Tom Gilb TDI 101 8 May 17th, 2010 05:51
Flashing Glow plug light + Flashing Oil pressure light w/ chime short_fuse TDI 101 7 August 30th, 2009 05:27
Page generated in 0.12053 seconds with 10 queries
[Output: 131.07 Kb. compressed to 110.02 Kb. by saving 21.05 Kb. (16.06%)]
