Old November 4th, 2011, 08:51   #1
DjEclipse
Default Rotella T6 Dealer said not to use it?
Hi all,
I just bought a 01 TDI and am wanting to do an oil change this weekend.
I checked the oil a few days ago and saw it was low, I read here that the Rotella T6 5W40 was a good synthetic oil to use so I bought some and topped up the oil. I have no clue what was in there before.
While I was at the dealer buying the oil filer, air and cabin filters I asked about the rotella oil T6. He said that I can't use the Rotella T6 oil as it does not meet the VW 505.00 specification for oil. and that I should use the Castrol 5w30 that they sell.
I don;t mind spending a little more for oil but I don't believe that the castrol 5W30 the dealer is selling is a god choice.
So is the Rotella t6 ok to use, and/ or is there a better oil I should be using.
Thanks.
DjEclipse is offline   Reply With Quote
Old November 4th, 2011, 08:55   #2
tdi90hp
i suggest you do some reading....hundreds of threads on this...
tdi90hp is offline   Reply With Quote
Old November 4th, 2011, 08:57   #3
eb2143
eb2143's Avatar
Fuel Economy: Lifetime average ~ 50 mpg
Originally Posted by What Oil Should I Use Thread
PART ONE: For engines that are NOT "pumpe-duse" or "common-rail". This is for the older-design mechanical rotary distributor pump engines.
You must use a synthetic engine oil, recommended viscosity 5w40 although 0w40 is also permissible (and in the case that the oil meets specifically one of the VW 505.xx standards then the viscosity does not matter, it could be different), AND in the fine print on the bottle that lists what standards that the oil conforms to, it must list either VW 505.00, ACEA B3, ACEA B4, API CJ-4, CI-4, API CH-4, or API CG-4. (Note: "Either" means ANY ONE OF, not necessarily all of them. For example, if it's VW 505.00 but doesn't list the others, that's fine, because VW 505.00 is "one" of the standards listed and you only need "one".) But do NOT assume that any synthetic oil will meet these standards. READ THE BOTTLE. For example, most versions of Mobil 1 do NOT meet these standards (they are meant for gasoline engines). Also, any oil that is suitable for a P-D is fine for a distributor-pump engine.
Your dealer is wrong. See above, or just look at your car's manual.
Your engine does not exclusively require 505.00. Used oil analysis show T6 5W-40 to be superior to Castrol 5W-30. Stay with T6.
2001 Jetta TDI 5mt, 280,000 miles (bought new 02/2001)
Bosio Sprint 520s, Koni FSDs, VW HD Springs, 10mm spacer, Audi TT LCA bushings, 034 motorsports strut mounts, E-code lights, Audi TT "short"-shifter, IDparts rear sway bar, DG Panzer plate, Caterpillar 2m fuel filter, Frostheater, GLI Recaros, GTI 3-spoke steering wheel, Audi S3 shifter, R-line stainless pedals
eb2143 is offline   Reply With Quote
Old November 4th, 2011, 09:00   #4
DjEclipse
Thanks for the reply. I have done a lot of reading on oil (among other things), but after talking to the dealer I figured I would ask here.
So basically the dealer is now recommending sub par oil for these cars? Why would they change the oil recommendation? Do they have a deal with Castrol or something?
Old November 4th, 2011, 09:02   #5
davebugs
Imagine a clueless dealer?
I've used it for over 200k in my 01 Golf with OEM filters - you'll be fine.
I do change it every 5k since it's so cheap and good insurance.
Let the OCI bashing begin, but it works for me.
davebugs is offline   Reply With Quote
Old November 4th, 2011, 09:06   #6
eb2143
eb2143's Avatar
They are recommending the oil that most dealer's sell AFAIK. It's a fine oil (my car used it for 80,000 during dealer service), just not as robust as T6. For them to say that you can't use T6 is what irks me, as it's untrue, as stated in your owner's manual. 0W/5W-40 is all I would run in a TDI anyway. Save money, run T6 10,000 mi OCI. Now that's what I call cheap insurance
Old November 4th, 2011, 09:24   #7
oEo
oEo's Avatar
Fuel Economy: mid 40's
Here's a good list of CJ-4 5W40 oils to start with. There's also Euro oils which can be found on some of the vendors sites as well.
http://forums.tdiclub.com/showthread.php?t=215098
2 0 0 4 I n d i g o B l u e G o l f R C 1 T D I C L U B A D D I C T I O N @ 1 4 9 k R u n n i n g W i t h T 6 U O A
oEo is offline   Reply With Quote
Old November 4th, 2011, 09:28   #8
boertje
boertje's Avatar
My 01 bug always used some oil when I was running the dealer castrol 5w-40. Then I switched to Mobil one TDT and it started to use even more oil (quart per 8000). Then I tried the T6 and my oil consumption completely stopped.
My oil of choice is Shell T6 5w-40 in my entire fleet.
'01 and a 2nd '01 and a '03 NB TDI with 6 spd manual. '06 NB GLS TDI DSG.
All with Malone tuning of course.
Auto to 5/6 spd manual swap with wiring instructions for MKIV. Click here.
boertje is offline   Reply With Quote
Old November 4th, 2011, 09:34   #9
davebugs
Perhaps I shouldn't say this, because you know how it goes now it might cause me problems.
But in 215k miles (first 20k maintenance done by dealer though) I've never consumed any oil (except one time when oil pressure sender went bad). Still don't. Other than what dealer used it's had nothing but Rotella T fully synthetic. What I've been able to observe of my engine (like turbo replacement at 180k for a VNT17 where the intake wasn't even dirty enough to clean) it all looks great inside as well.
Old November 4th, 2011, 09:36   #10
DjEclipse
Thanks again for the replies. I will use the T6 and disregard what the dealer said.
I will probably be changing the oil every 8000km's give or take a few, I am used to the 5000km changes for gas cars and 10,000miles between changes seems so long.
Cheers
Old November 4th, 2011, 09:57   #11
dieseldorf
top post dawg
dieseldorf's Avatar
Nah, DJ, the API truck oils are good to go 10k miles intervals without breaking a sweat, assuming a stock engine that's in good shape. At an 8k kms interval, the oil is just starting to show degradation on the ULSD fuel.
Old November 4th, 2011, 10:59   #12
DjEclipse
Really? That's 16,000km's At those intervals the difference in price between the oil is negligible really...
Old November 4th, 2011, 11:07   #13
belome
Fuel Economy: 47'ish
Actually, to determine what OCI you should be using we need to know what kind of driving are you doing? Mostly highway, mostly city, lots of starting and stopping? etc.
I do all highway, all the time... I do 15k OCI's with TDT.
The only thing I can pass is a fuel stop, but I'm OK with that.
My claim to fame - I was banned from VWVortex!
belome is offline   Reply With Quote
Old November 4th, 2011, 11:17   #14
dieseldorf
top post dawg
dieseldorf's Avatar
That's correct.
And now you are beginning to see what you've been missing all these years.
The 16k kms interval has been in place for years. Nothing new there.
Old November 4th, 2011, 11:24   #15
DjEclipse
I would say my driving is 65% city, 35% highway, I m not in a major city so I don't do bumper to bumper traffic often. But I do not baby my vehicles, I tend to get the worst mileage out of every car I drive because I have a lead foot.
Mobil 1 VS. Rotella T6 Poolboy1191 Fuels & Lubricants 40 November 24th, 2011 12:49
Rotella T6 is 1l containers? yatzee Ontario 5 March 25th, 2011 08:58
Rotella T 5w40 now Rotella T6??? Joester Fuels & Lubricants 13 February 5th, 2010 17:20
Rotella T6 & Rotella T SB? kwalsh24 Fuels & Lubricants 8 January 28th, 2010 17:38
Rotella T6 werewolf TDI 101 6 January 20th, 2010 16:42
Page generated in 0.18973 seconds with 10 queries
[Output: 130.91 Kb. compressed to 109.52 Kb. by saving 21.39 Kb. (16.34%)]
