Old November 3rd, 2011, 03:08   #1
blu_jet_92
blu_jet_92's Avatar
TDI(s): 2002 Sedan
Fuel Economy: Torque > MPG
Default Lost both keys.......what now?
So my gf successfully lost both keys in one week. The car is sitting in a ccorn field in the middle of nowhere..... What the heck do I do...? I do have a doner car (vr6) that I could pull the ignition from and I have two keys for that, but what would the imobilizer do with that? Any thoughts?
blu_jet_92 is offline   Reply With Quote
Old November 3rd, 2011, 08:07   #2
Lightflyer1
Lightflyer1's Avatar
Tow dolly/truck and dealer and cash.
2015 Beetle TDI.
Old November 3rd, 2011, 08:09   #3
davebugs
It's amazing how many cars are hauled into the dealer simply due to keys.
davebugs is offline   Reply With Quote
Old November 3rd, 2011, 08:35   #4
belome
Fuel Economy: 47'ish
I guess since you haven't married her yet, it shouldn't be too hard to rectify the situation... just start putting her stuff on the front porch, she will get the hint.
The only thing I can pass is a fuel stop, but I'm OK with that.
My claim to fame - I was banned from VWVortex!
belome is offline   Reply With Quote
Old November 3rd, 2011, 08:48   #5
blu_jet_92
blu_jet_92's Avatar
TDI(s): 2002 Sedan
Unfortunately I already spent the 2k on some overrated rock. :/
Old November 3rd, 2011, 08:49   #6
blu_jet_92
blu_jet_92's Avatar
TDI(s): 2002 Sedan
Next question. If the immobilizer is disabled, what would happen with a different ignition?
Old November 3rd, 2011, 09:07   #7
jetta ,97
jetta ,97's Avatar
Fuel Economy: Very good
You can order key from dealer via VIN number and you will get same key as your car had. Key will not be able to run the car because immobilizer needs to be adopted. It usually takes 1 day to get it.
If you delete immo , car will run but immo light will flash on instrument cluster all time.
I do any repair on all models,USED/NEW ECU and Cluster swap, Reprogramming Keys , Immobilizer Delete,Cluster LCD Dispay Repair -Clik here
I am trusted TDI Mechanic, VCDS
HEX+CAN
ECU TUNING-TDTUNING Authorized Dealer
MK6 Needle Sweep,MK5 with MK6 Cluster
jetta ,97 is offline   Reply With Quote
Old November 3rd, 2011, 10:45   #8
joseluis.17g
when my dad bought my car, it only had the valet parking key, we went to the dealership and they wanted to charge like 200 dlls for each key plus programing and pairing car with key, but we found near my house a guy with a vag-com sort of stuff who was able to do witchcraft and some other stuff to a key and everything works, remote, ignition and everything and he did all that for like 150 dlls for everything
joseluis.17g is offline   Reply With Quote
Old November 3rd, 2011, 10:56   #9
blu_jet_92
blu_jet_92's Avatar
TDI(s): 2002 Sedan
Where is the best/cheapest place to order keys from?
Old November 3rd, 2011, 13:45   #10
chewyboy
TDI(s): '00 NB TDI
check out this place as well some good info there http://www.sidewinderkey.com/
chewyboy is offline   Reply With Quote
Old November 3rd, 2011, 13:58   #11
jetta ,97
jetta ,97's Avatar
The safest is Dealer.
Be aware that many of aftermarket keys has wrong or used chip in the key and you can end up with brick in your hand.
Also no one will be able to cut key By VIN number except dealer,lock smith can duplicate key but not cut by VIN, if you find one that can do those keys.
HEX+CAN
Old November 3rd, 2011, 14:05   #12
kjclow
Fuel Economy: 55 max / 44 avg on beetle ~37 on JSW
Most lock smiths are supposed to be able to make keys with immobilizer chips for VWs now. There was a class action law suit a few years back because of VW being the only place to get a key made that actually worked. Search the web for local ones or, heaven forbid, let you fingers do the walking. If you have any of the tags that came with the original keys, you might be able to get a key cut and programmed without having to take the car in. Never tried this but that's what I've been told from different dealers.
2010 silver/black JSW TDI with DSG, 2011 red Golf TDI with dsg, 2003 red/gray Passat 1.8l gasser
kjclow is offline   Reply With Quote
Old November 3rd, 2011, 14:07   #13
Lightflyer1
There are "others" who can do the programming part, but they are few and far between. Probably not in the middle of nowhere in a cornfield either.
2015 Beetle TDI.
Old November 3rd, 2011, 14:21   #14
jetta ,97
jetta ,97's Avatar
It is not possible to program the key with out car.
HEX+CAN
Old November 3rd, 2011, 15:41   #15
blu_jet_92
blu_jet_92's Avatar
TDI(s): 2002 Sedan
how hard is it to do an immobilizer delete?? i just ordered two keys from VW this afternoon... but i'd rather just delete the immobilizer than pay to have it towed 40+ miles and then pay 100 just to have them puts on a computer for a few minutes...
All Keys are lost!!!!!! :( :( TDIPOWERMAN TDI 101 21 October 6th, 2011 03:52
Lost Keys LukeWilson TDI 101 4 December 20th, 2010 02:17
Lost Keys. All of them. Please help riofrio VW MKIII-A3/B4 TDIs 28 July 8th, 2010 07:06
LOST KEYS Help :( tj421rb TDI 101 12 January 30th, 2008 16:23
Lost both of my keys. P180 General VW Discussion 11 January 4th, 2002 19:11
Page generated in 0.17188 seconds with 10 queries
[Output: 128.10 Kb. compressed to 106.78 Kb. by saving 21.32 Kb. (16.64%)]
