Go Back   TDIClub Forums > VW TDI Discussion Areas > TDI Fuel Economy
TDI Fuel Economy Discussions about increasing the fuel economy of your TDI engine. Non TDI related postings will be moved or removed.
Old November 2nd, 2011, 07:32   #1
GodStang
TDI(s): 2012 Jetta
Default 2012 DSG tricks for better mpg?
I hate to start another one of these as it seems to be asked a million times but in all my research everything seems to be the older models and manuals. I have a DSG 2012 Jetta TDI. Wife said it has to be an auto and she controls the sex in the family so ya we got an auto so please do not say swap to manual cause that is not happening. My tire pressure is at ~90% of max psi on tire side wall. I shift into neutral when going down steep hills and coast into stops and time lights to save gas. I am also light footed to save gas.
So that leaves me with my question. Has anyone started modding the newer cars to gain better gas milage and I so what have you done and what gains have you seen? What of the old TDI tricks work on the new TDIs?
GodStang is offline   Reply With Quote
Old November 2nd, 2011, 07:49   #2
TomB
Fuel Economy: 34 mpg on first tank
Not funny. Rude. This makes you look bad not her and is not necessary here. Really have some class or at least Klass.
2007 Jeep Grand Cherokee 3.0L MB Diesel
2012 Passat TDI SEL Premium Opera Red/Titan Black
2015 Audi A3 TDI Prestige S-line Lotus Gray Metallic/Black Leather
TomB is offline   Reply With Quote
Old November 2nd, 2011, 08:10   #3
Elfnmagik
Elfnmagik's Avatar
I shift into neutral when going down steep hills...
I believe VW has stated this is not good for the DSG.
HPFP, DSG, DPF, DMF...I hate acronyms!
Elfnmagik is offline   Reply With Quote
Old November 2nd, 2011, 08:14   #4
Elfnmagik
Elfnmagik's Avatar
Also, you're not doing the engine any good by pussy footing around trying to save fuel.
Old November 2nd, 2011, 08:22   #5
WVU TDI
WVU TDI's Avatar
You got 39.3 on your FIRST TANK with a DSG and you're complaining about the mileage?
The mileage will slowly get better as the engine breaks in and as you learn to drive the car.
Stop putting it in neutral going down the hills, any extra wear and tear that might cause the DSG will quickly negate the hundreths of mpg's you - might - be picking up from doing it.
Don't baby the car off the assembly line, it needs to see some revs and boost to get everything settled in nicely.
1997 Passat TDI (sold)
2001 Golf TDI (sold)
2010 4dr Golf TDI, 6M (sold)
2013 Passat TDI SE, 6M -- turbo failed at 9500 miles.
WVU TDI is offline   Reply With Quote
Old November 2nd, 2011, 08:48   #6
SoTxBill
rotflmao!!!!!
THE DSG is still a good choice. It actually is faster in most cases, and can come very very close or do as good in mpgs...
up shift quickly and keep rpm down. try to keep rpms under 2800. go with michelin tires, get 20,000 miles on it to loosen it up.
Most mods give some power but usually use more fuel. All the easy stuff has been done by the manufactures... driving sensably is the best thing you can do... and the car will always get fantastic mpg at 50 vrs 75 mph.
Recent study shows that 3 out of 4 people make up 75% of the population.
Its considered bad luck to be superstitious.
98% of all Statistics are made up.
According to statistics, every human has one testicle and one large breast.
98% of Lawyers give the rest a bad name.
SoTxBill is offline   Reply With Quote
Old November 2nd, 2011, 08:52   #7
GodStang
TDI(s): 2012 Jetta
Was not complaining about the mileage. Just trying to learn and was wondering after driving technique what are good things to do. Thanks for those with good advice on improving my driving. This is my first turbo and first desiel.
Old November 2nd, 2011, 09:35   #8
emdeeaitch
... I shift into neutral when going down steep hills and coast into stops and time lights to save gas. I am also light footed to save gas...
Because diesels breath differently than gas engines, this may be having the opposite effect. Whereas gas engines have a strong engine brake effect, diesels have more of a "compressed air spring" effect that allows them to coast a long way while "engine braking" as compared to gas motors. This compressed air effect is why to seriously engine brake with a diesel you need to add an actual "jake brake," which is not going to happen on a passenger vehicle.
To my point, I have found that with any TDI, be it manual or DSG, the MPG goes through the roof when engine braking up to a stop or turn. Just leave it in an appropriate gear and let it roll.
It may (and I say may because I don't have to tools to measure it other than the fuel computer) take more fuel to keep the engine running at idle than will be consumed to coast in gear.
For a good explanation of the mechanics behind what I'm saying, read the wikipedia article on diesel engine.
2012 Golf TDI 4dr Blue Graphite DSG Sunroof & Nav
2009 Jetta TDI 6M Reflex Silver (Replacement Vehicle on 7/1/2009, sold 10/27/11), 2009 Jetta TDI 6M Reflex Silver (Lemon! Turbo failure on 5/7/2009), 2006.5 Jetta TDI Pkg1 5M 17s Reflex Silver (sold 5/6/2009), 2005 Jetta TDI GLS Leather 5M Reflex Silver (collision, sold 2006), 2003 Jetta GLI VR6 6M Platinum Grey (sold 2004), 1996 Jetta GLX VR6 5M Candy White (sold 2003)
emdeeaitch is offline   Reply With Quote
Old November 2nd, 2011, 09:42   #9
UFO
UFO's Avatar
TDI(s): 2001 Beetle
Fuel Economy: 50mpg on B100
I've found, and verified, you will save more fuel by coasting in neutral in spots where you do not need to slow down, and using the engine braking to cut fuel where you do need to control your speed.
Engine "braking" is still braking, and you are wasting your momentum.
Also, I'm curious as I do not have a DSG, how does coasting in neutral increase wear in that transmission? I've been coasting in neutral for a while now with my O1M with no noticeable degradation, and significantly improved fuel mileage.
2001 Beetle - EGR delete, 01M-ectomy, Atlas skidplate, vented, Frostheater.
I'm not coasting, I'm shifting slowly.
UFO is offline   Reply With Quote
Old November 2nd, 2011, 09:46   #10
MikeMars
Well, I'd agree with the other people in the thread - since the car is new, you should be focussing on running in your engine rather than MPG initially. Be gentle while the engine is still cold, but once it is hot then work your way through the rev range, including visits to 3500 rpm. The intention of this is to get the piston rings sealing properly, so that the car does not drink oil later in it's life.
Once the engine has freed up (10k - 20k), then that's the point you can think about MPG.
Audi A2 TDi 1.4*, 6M/0.588, mild aero mods, 103hp remap (* 3 pot version of 1.9PD)
Y2000 Passat TDi 115 PD RETIRED, M5, Best 75MPGuk, usually 60-70. 900m clubx7. 1000 mile clubx3.
VW Fuel saving tips
MikeMars is offline   Reply With Quote
Old November 2nd, 2011, 09:48   #11
emdeeaitch
I'm obviously talking about situations in which you need to regulate speed or do wish to slow down. The OP said "steep hill." That means either riding the brake (which is bad) or choosing an appropriate gear. Going into neutral and riding the brake is a pretty awful choice, especially if the hill is long.
Old November 2nd, 2011, 10:22   #12
UFO
UFO's Avatar
TDI(s): 2001 Beetle
Quite right.
Old November 2nd, 2011, 10:41   #13
JettaTDiPA
Most of us with new engine, etc. are lucky to get 31-34 mpg on the first tank or two. I'm am just starting to get 38mpg at 5k miles. Mine is also a DSG. Right out of the box they are not going to even get the EPA estimate.
I am not a transmission expert, I would suggest avoid putting the car in and out of neutral while in motion. Does some research on this site- you will find "coasting" in gear burns precious little fuel.
JettaTDiPA is offline   Reply With Quote
Old November 2nd, 2011, 13:16   #14
mohawk69
Is funny. Isn't rude. Some are just WAY WAY WAY to thin skinned. BTW, this is true everywhere except CA. Maybe even WA now. I hope it's not spreading because someone has to be in charge.
mohawk69 is offline   Reply With Quote
Old November 2nd, 2011, 13:50   #15
DPM
Fuel Economy: 38.5- 47 Forester, Citroen 55- 63
Yup. Is funny, and true...
DPM is online now   Reply With Quote
Dynoing a 2012 Jetta TDI w/DSG? GodStang TDI Motorsports 2 November 6th, 2011 15:08
New 2012 Passat DSG in the driveway. bardie Ontario 3 October 12th, 2011 09:16
2011-2012 dsg thesearcherman VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 34 August 5th, 2011 10:33
What are the tricks for 50+mpg Danowano TDI Fuel Economy 24 October 21st, 2002 11:57
What are the tricks for 50+mpg Danowano TDI 101 12 October 16th, 2002 00:45
Page generated in 0.17762 seconds with 10 queries
[Output: 133.71 Kb. compressed to 111.93 Kb. by saving 21.77 Kb. (16.29%)]
