Old November 1st, 2011, 12:24   #1
LustForTDi
Default Resetting airbag light cheaply
Ok guys. I've been on this board long enough to head a lot of you off at the pass : )
I've searched and got nothing.
2002 Golf TDI manual
I need a cheap way to reset my airbag light. I called my local auto parts stores, and the mechanics they recommended, and no one will reset the airbag light for legal reasons. VW wants $50 to reset it. Besides changing glow plugs, oil, bulbs, and fuses all other work will be done by a mechanic. So, I don't want to spend $200+ for Vag-com.
I found this VW/Audi specific scanner that says it can reset the airbag light - u281 code reader
on amazon: http://www.amazon.com/U281-Trouble-S...0175254&sr=8-2
Here is a video showing a guy resetting his airbag light: http://www.youtube.com/watch?v=JRE43rFoiG4
Before I spend the money, I was wondering if anyone has tried it?
LustForTDi is offline   Reply With Quote
Old November 1st, 2011, 16:53   #2
JSWTDI09
JSWTDI09's Avatar
If an intermittent problem has caused your airbag light to light, VCDS can clear it. If you have actually had an airbag deployment, it cannot be reset (legally) - the airbag controller must be replaced. Therefore, the real issue is why is your airbag light on? A VCDS scan would help, but has any of your airbags actually deployed?
Have Fun!
Don
JSWTDI09 is online now   Reply With Quote
Old November 1st, 2011, 18:16   #3
LustForTDi
Oops! I forgot to mention, I already had the code scanned. Driver side belt buckle receptacle. This means it could be the buckle or it could simply be a bad connection on the bottom of the seat. Either way, I need to be able to attempt a fix and reset the code to see if the light comes back on.
The bluedriver looks to be a simple code reader. It can reset a check engine light, but not an airbag light.
Old November 1st, 2011, 21:56   #4
LustForTDi
Ok guys! I know everyone is as excited as me! After googling for hours and joining a UK audi forum, I finally have my answer!
The U281 reader from Memoscan (memoscan.cn is the website) will reset the airbag light! Unfortunately, for the few posts where it worked, there was an equal amount where it gave an error code when trying to read the airbag system. But, when the company was contacted, they were told to update the software from the website.
I just don't understand how you update from the website, if it only has the car cable...
I just emailed the vendor on amazon to see if I can return it if it doesn't reset my airbag light.
If I order it, I'll definitely come back and let you guys know if it worked.
Old November 2nd, 2011, 03:42   #5
DanG144
VCDS will reset it.
But quite often the driver's side buckle (rather the switches built into it) are at fault, and it must be replaced or the code will come right back in.
VCDS will also let you test the buckle's switches.
Old November 2nd, 2011, 04:17   #6
PeterV
HO5G Doyen & Zen Master
PeterV's Avatar
Find a local GURU or VCDS owner many of them will scan or reset for free or beer.
PeterV 'BUG*pwr award 2005'
'00 Jetta TDI, RC, Shine, DG RPipe, 520PP, DG/SS LED Boost ASR. Home of HO5G ('96 Cummins CTD 3/4 ton now at 274 HP 670 ft Lbs TQ riprust) Ram 1500 hemi
Trusted TDI Mechanics Map || VCDS Locator ||
PeterV is offline   Reply With Quote
Old November 4th, 2011, 09:46   #7
LustForTDi
Unfortunately, I live 2 hours away from the nearest metro area...
How much is VCDS?
Old November 4th, 2011, 10:16   #8
JSWTDI09
JSWTDI09's Avatar
Originally Posted by LustForTDi View Post
How much is VCDS?
For your car only (not newer ones) is would be $249. You want this one. (unless you can find a used one)
http://store.ross-tech.com/shop/VCKII.html
Have Fun!
Don
Old August 31st, 2012, 09:52   #9
TDproduction
I am having the same problem, where is the airbag controller located? I have a parts car that I can swap the controllers from.
TDproduction is offline   Reply With Quote
Old September 10th, 2012, 19:39   #10
robtechno
Default Airbag light on
Pages and pages are written about AC malfunction but on this fault code I think it's M 199, no one has a clear answer.
Can some one tell me what code M199 or N199 is.
Thank you.
reg.
Rob
First owner from 12 miles on the Odo.
2006, Jetta TDI-BRM, 165k miles and counting.
My other car is 2006, F350 with 126k miles and 34 Ft enclosed car trailer.
robtechno is offline   Reply With Quote
Old September 11th, 2012, 02:19   #11
DanG144
N199 is a device, an air bag igniter. This is a device that has an active electrical signal to it, that takes power - current flow- to ignite. If the computer sees a problem with the circuit it will throw a code.
It is not an error code, but is the subject of several error codes.
Go to http://wiki.ross-tech.com/wiki/index.php/01217 for some amplifying information.
You are best served by providing detailed information- all the info displayed by the error code. Not some vague guess.
Old September 17th, 2012, 06:26   #12
MacBuckeye
MacBuckeye's Avatar
TDI(s): 2009 Jetta
Fuel Economy: 40 avrg, 46.5 best
Default Airbag light / wiring harness
VAGCOM gave me the below codes.... Quick question- Is the wiring harness for the door locks also the same or inlcude the wiring for the air bags? I'm having it looked at next week. Appreciate any info you guys can share.
01578 - Airbag Deactivation Warning Lamp; Passenger Side (K145)
009 - Open or Short to Ground - Intermittent - MIL ON
I also have two fault codes for the door locks....
01552 - Motor for Central Locking; Drivers Door (V56); Lock
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 3
Fault Frequency: 40
Reset counter: 221
Mileage: 0 km
Time Indication: 0
00928 - Locking Module for Central Locking; Front Driver Side (F220)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00111000
Fault Priority: 3
Fault Frequency: 14
Reset counter: 221
Mileage: 0 km
Time Indication: 0
2009 Jetta TDi, 191,800 miles later.... off to the crusher!
Enjoying my 2017 Honda Accord Sport SE....
MacBuckeye is offline   Reply With Quote
Old August 19th, 2014, 20:48   #13
Binoo
Fuel Economy: not sure yet!
revive!! bwahahha
ok so I had a common issue of the "clicking" sound in the dash board on my vw so I had to take out the airbag to remove the steering wheel. I now have an airbag light on my dash (I connected the airbag connector i'm 100% positive on that) that I can't even remove with my $800 Innova scanner . I guess VW's require a certain type of scanner to clear codes and ABS/SRS diagnostics ?
cheers
Binoo is offline   Reply With Quote
Old August 20th, 2014, 04:03   #14
bhtooefr
ToofTek Inventor
bhtooefr's Avatar
TDI(s): None
If you're going to work on VWs, get VCDS.
http://store.ross-tech.com/shop/VCKII.html will work on your car for $249
http://store.ross-tech.com/shop/VCHUC.html will work on everything for $349
The really cool ToofTek made "Emperor's Clothes" injector fork risers only worked until someone pointed out that there wasn't any thing there.
bhtooefr is offline   Reply With Quote
Old August 20th, 2014, 05:09   #15
Tdijarhead
Originally Posted by Binoo View Post
revive!! bwahahha
cheers
Just removing the air bag should not have set a code. However if you turned the ignition on while it was disconnected, then yes a code would be set. You will need a VCDS to read and clear any air bag code.
Tdijarhead is offline   Reply With Quote
Resetting the Maintenance Light ExtremeMachine476 VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 6 November 6th, 2010 17:38
Resetting the ABS Warning Light macdub VW MKIV-A4 TDIs (VE and PD) 3 October 28th, 2010 09:31
resetting brake light switch? pastvast TDI 101 2 November 7th, 2005 22:26
Resetting "check engine" light? willwin2day VW MKIII-A3/B4 TDIs 5 January 26th, 2004 08:06
Resetting Check Engine Light tommy37 VW MKIV-A4 TDIs (VE and PD) 4 January 31st, 2002 00:05
Page generated in 0.15052 seconds with 10 queries
[Output: 125.97 Kb. compressed to 105.24 Kb. by saving 20.73 Kb. (16.45%)]
