Old October 31st, 2011, 16:35   #1
CrayZRyde's Avatar
Fuel Economy: 45-50
Default I Have a Question for You! Tuning Module and Bigger injectors ok???
I just installed a ECS Tuning lightweight flywheel stage 1 clutch kit at 160,000mi
I had put a Diesel Power Digi Z little tuning box on my car and literally laid my clutch to rest withing 5,000 miles. But yes, i knew it was going to happen, i was waiting to order a heavier clutch and needed a reason to do it anyway.
My question now is.. Is it safe with this Digi Z tuning box to upgrade to bigger injectors now that my clutch can hold the extra power? From what i understand this tuning box dosnt advance the timing or anything, just adds more fuel, no overboost change either. I have a EGT and Boost gauge.
Can anyone give me some helpful insight in my next step foreward with my power quest?
I have a 2003 1.9 with the Digi Z tuning box,ECS tuning Stage 1 clutch kit, lightweight flywheel (claims good for up to 275hp) no cat/ and a thrush turbo exhaust glasspack in place of the muffler. K&N air filter in place of paper.
I'm thinking injectors.. But dont want to do any harm to my engine. Can anyone give me advice
Run It
CrayZRyde is offline   Reply With Quote
Old October 31st, 2011, 17:01   #2
Not familiar with the tuning box, a lot of folks around here "chip tune" (ECU reflash) their cars instead of using tuning boxes. Typically a reflash changes more parementers than a box, resulting in better performance.
Adding larger injector nozzles should be fine, but since you may not know how much fuel your tuning box is requesting, you may want to get an EGT gauge to monitor exhaust gas temps. And a boost gauge wouldn't hurt, either. If you have a stock turbo 18 PSI is about the limit, and they're prone to spike to higher PSI when you add fuel. A boost valve can help if that's the case.
Regarding damage and wear, I've had remarkably good luck with my wagon. I've been running 26 PSI for the last 100K, 18 for 120K before that. So far, so good.
2002 Jetta wagon, 358K, RC3+; 1993 Mercedes-Benz 300D 2.5, 197K; 1997 Passat, 285K; '99.5 Golf, 255K; 2011 335d, 55K; 2015 Golf Sportwagen, 5K. Principal, http://www.idparts.com
Old November 1st, 2011, 14:57   #3
memphis tdi
I have run pp520s and a Van Aaken and a Bullydog box with the pp520s at different times, both combos worked fine. I just switched to a stg 3 custom tune, it is very smooth and runs well, but makes less power than the pp520/box combo, it also smokes less.
memphis tdi is offline   Reply With Quote
Old November 1st, 2011, 16:11   #4
glitdi's Avatar
Your tuning box works by disrupting the signal to the injectors to open then for longer.
The settings on the side of the box dictate how long they remain open for, the more fuel the more boost, the more power etc.. The key is adjusting the box or boxes correctly too much fuel and the car will over boost and cause limp mode etc. This is the big drawback to a disruptor box, if you continue to hit limp mode from over-boosting you can buy another expensive box that fools the boost reading and then you get to play with the settings on that one as well.
Or perhaps a tune?
OCD Member #4
glitdi is offline   Reply With Quote
Old November 1st, 2011, 16:58   #5
memphis tdi
I never had a problem with overboost or limp in mode with either box and I ran each box over 50,000mi.
Just stating my personal experience, not saying either a box or tunning is better thats up to the buyer.
Bigger Nozzles Or Bigger injectors? Jasonhebb TDI Power Enhancements 2 March 28th, 2011 16:06
Diesel Power Tuning box + Bigger Injectors michael.berta TDI Power Enhancements 13 December 21st, 2007 22:09
Bigger injectors (5speed tranny) + chip tuning, how to avoid smoke? genericMK TDI Power Enhancements 18 November 26th, 2007 03:21
WTB: tuning box or bigger injectors devanwon Private TDI Items for Sale/Wanted 16 December 11th, 2003 05:14
tuning box or bigger injectors? michael. TDI Power Enhancements 29 February 3rd, 2002 22:16
Page generated in 0.14757 seconds with 10 queries
[Output: 71.51 Kb. compressed to 63.38 Kb. by saving 8.13 Kb. (11.37%)]
