Old October 31st, 2011, 13:40   #1
neljoshua
Fuel Economy: 47 mpg hwy
Question Camshaft Sprocket Bolt Re-Torque?
About one month ago I did a TB change with tools and parts from metalmanparts.com (thanks a ton, btw!). I used the .pdf file here in the How-To section and torqued the bolt on the cam sprocket to 33 ft-lbs.
After reading an old posting today, however, I am starting to wonder if I should go in and re-torque it for peace of mind. I am not at all concerned that my timing is off or that anything else is wrong, but I do not want that sprocket to slip!!!
Here is the thread I was reading:
http://forums.tdiclub.com/showthread...et+bolt+torque
I will be more than happy to re-torque the bolt if it needs it, but I do not want to over-torque it, either.
Josh
neljoshua is offline   Reply With Quote
Old October 31st, 2011, 15:01   #2
dogdots
dogdots's Avatar
I torque alh cam pulleys to 40 ft lbs.
2 2002 Jetta TDI's - one is stock and one is not
04 Jetta BEW
05 Passat BHW
www.kansascitytdi.com
dogdots is offline   Reply With Quote
Old October 31st, 2011, 15:40   #3
eb2143
eb2143's Avatar
Fuel Economy: Lifetime average ~ 50 mpg
The gist I got from stories of spun sprockets was that if it was going to slip it would do it sooner than later; this is one reason why the PDF has you bump the motor over and then check that everything remains in time at the end of the job. If the surfaces were cleaned I wouldn't worry about it. Although it's easy to get worried, on the other side of the coin is that Drivbiwire has successfully changed thousands of them at 33 ft lbs. I *think* Herm Pasker uses 33 ft-lbs if I remember correctly from the check sheet he included with an early TB change. And hey, even I've changed one and successfully used 33 ft-lbs.
2001 Jetta TDI 5mt 234,000mi, 46/50/58 mpg
Bosio Sprint 520s, Koni FSDs, VW HD Springs, 10mm spacer, Audi TT LCA bushings, 034 motorsports strut mounts, E-code lights, Audi TT "short"-shifter, IDparts rear sway bar, DG Panzer plate, Caterpillar 2µm fuel filter, Frostheater, GLI Recaros, GTI 3-spoke steering wheel, Audi S3 shifter, R-line stainless pedals
eb2143 is offline   Reply With Quote
Old November 1st, 2011, 14:40   #4
runonbeer
Maintenance EnthusiastVendor
Fuel Economy: good/good/bad
I set my torque wrench to 35ft-lbs
The thread in that link is loaded with fail.
runonbeer is offline   Reply With Quote
Old November 2nd, 2011, 10:04   #5
neljoshua
Thanks for the info! I may torque it a little more during my next oil change, but I am not worried. I did not want to be in a situation where it is *supposed* to be 40 ft-lbs and I only did 33 ft-lbs.
Josh
Old November 2nd, 2011, 13:41   #6
Powder Hound
Powder Hound's Avatar
I think if you ensure that the inside of the cam sprocket is as clean as you can reasonably get it, and the nose of the camshaft equally as clean, the surfaces will mate well and not slip at the stated torque. Bare steel on bare steel pressed together - they get a little sticky.
In an online forum such as this, it is nearly impossible to tell if someone had one that slipped and it was not at all from dirt, grease, and/or oil on the mating surfaces, torque wrenches that are out of spec, or who knows what other detail the story teller didn't notice or couldn't determine.
'00 4dr 5-sp white over black Golf: Sprint 520 nozzles, ABS+ASR, Koni FSD enhanced suspension, vented hood; '00 2dr 5-sp silver over black Golf. DG 5-sp short shifter. Nuthin' special yet.
VW does not build or sell cars. VW builds and sells mobile DIY kits disguised as cars.
Old November 2nd, 2011, 20:03   #7
AndyBees
AndyBees's Avatar
Fuel Economy: life time average above 50 MPG
Here is some additional reading for those who are scratching their heads on this one. As Powder Hound said, being clean is important and is stressed in the two links below.
http://forums.tdiclub.com/showthread...=218960&page=2 scroll down to post #23 by Franko6.
Also, this link has a good write-up with reference to the above link.
http://www.myturbodiesel.com/forum/f...que-spec-1048/
The link in the initial post to this Thread is to a Post I made back over two years ago. I've since torqued several Camshafts at 40 lbs with no problems.
2000 Jetta TDI, 50+ overall average (no tune)
300k mile mark on 12/28/11
427 fill-ups, in Excel spreadsheet, 323k miles...
'84 Vanagon ALH TDI engine (32 mpg), Polaris Diesel ATV, Allegro Bay RV 5.9 cummins
VWs 40 years, VW diesels 33 years, ALH TDIs 11 years
AndyBees is online now   Reply With Quote
No key on camshaft drive sprocket? Chubber VW MKIII-A3/B4 TDIs 4 April 13th, 2009 09:47
Camshaft sprocket woodruff key? haybayian TDI 101 7 May 26th, 2008 12:10
Injection Pump Sprocket New Bolt Torque? PDJetta VW MKIV-A4 TDIs (VE and PD) 4 July 13th, 2007 04:55
Non-stretch Camshaft sprocket bolt torque specs? joefahy TDI 101 5 January 15th, 2004 23:25
Camshaft sprocket puller saintex VW MKIV-A4 TDIs (VE and PD) 13 April 13th, 2003 12:55
Page generated in 0.14676 seconds with 10 queries
[Output: 82.85 Kb. compressed to 71.97 Kb. by saving 10.88 Kb. (13.13%)]
