Go Back   TDIClub Forums > Meetings/ GTG/ Regional Discussions > Ontario
Ontario Local discussions for those in the Ontario, Canada area.
Old October 31st, 2011, 08:30   #1
MerelyKarma
Fuel Economy: 5.3L/100km
Default Turbo vs Supercharger
So talking to some car guys over halloween, there was a lot of talk about how these guys loved the super chargers over turbos (a couple of them have cars that run high 8's). There was more hp in the driveway then on the rest of the block (3 x 600+hp diesel trucks for towing the drag cars. 1200ft-lbs in the one in front of me... needless to say i felt small).
I have read a bunch on them, but the only comparisons I could find were on websites for people who like superchargers/make them so they were always biased.
I was wondering, purely from an interest point of view, why do I never see any TDI's (SDI?) with a Supercharger? Would it be possible? Would the drag on the engine be too much of a power loss to over come with the supercharger?
Any thoughts? This is more of me trying to learn more, and pick the brains of the smart people that are on here. That and I think having a golf with a legitimate working hood scoop would make certain people on Vortex's heads explode
MerelyKarma is offline   Reply With Quote
Old October 31st, 2011, 08:49   #2
Ski in NC
Fuel Economy: 48-52 typical
Superchargers are good for generating maximum hp, and have zero lag when launching off the line. Good for drag racing.
Why you don't see them often on cars: The hp required to drive the supercharger comes from the crankshaft. And it is alot of hp. Not great if you are wanting efficiency (as in mileage).
Turbos use waste energy from the exhaust and have very little downside on efficiency, in fact may actually increase efficiency in some applications. Most modern engines where fuel efficiency is important use turbos.
Supercharger: Instant hp off the line. Not good for fuel economy.
Turbo: A little lag in hp (bad for drag race). Good for fuel economy.
2001 Jetta TDI 5sp Stock 201k mi
1981 Rabbit IDI 4sp Sold at 339k mi
1990 S-10 4.3 4wd 5sp 154k mi
1986 VW Pathfinder 1.6 45hp Marine 4700 Hrs
2001 Cummins 8.3 420hp Marine 1660Hrs..REFIT DONE!!
Ski in NC is offline   Reply With Quote
Old October 31st, 2011, 10:31   #3
GoFaster
Moderator at Large
There are plenty of turbo engines involved in drag-racing, too. Some of them have some rather unorthodox launch techniques to overcome the lag of the invariably very large and, strictly speaking, oversized turbochargers. In other cases, a little bit of lag can actually help, by not blowing the tires away right at the line.
Main reason you don't see more of them are (A) the rules for many classes don't allow turbochargers, and (B) it's not "traditional" and "old skool" - looks out of place on a '69 Chevelle.
Otherwise ... diesel engines are ordinarily designed for maximum efficiency, and turbochargers are a far better match than superchargers, for all the reasons described in the post above.
Brian P.
formerly ... 2006 Jetta TDI 5-sp, Spice Red, Unitronics stage 1, 0.681 5th gear.
and before that ... 1996 Passat TDI, Silk Blue
Old October 31st, 2011, 12:19   #4
imo000
imo000's Avatar
Supercharger are also a lot easier to install. Fuel efficiency with the turbos is rescent. Materials came a long way in the last few years. In the past, turbo engines had to run rich to keep the impeller from melting. Exotic materials made this a non issue and now there are some gasoline turbo engines that are in the TDI teritory.
imo000 is offline   Reply With Quote
Old October 31st, 2011, 16:32   #5
craig01b
craig01b's Avatar
TDI(s): None
Superchargers work in engines that need lots of power, with very little lag...or otherwise, things that run consistantly...cars do not fit that category.
Turbos cost little to run on the fuel side, since they extract their power from the exhaust side. Limitations...yes, but if you can control it, its wonderful. Much like out little cars.
I am happy to say, I have 2 turbos...nil super, and another that could go either way..depending on mom...
Night, and best of luck to you all!!!
Craig Bremner
All retired, bought a Subaru.... all wheel drive, and a little bigger than the high line. Time will tell!
craig01b is offline   Reply With Quote
Old October 31st, 2011, 17:27   #6
MerelyKarma
Awesome, thanks for clearing that up for me.
Soon, I will be able to answer questions instead of just asking.
Old November 1st, 2011, 11:45   #7
mo_focus
mo_focus's Avatar
TDI(s): 84 944
the new Audi 3.0T is actually a supercharged engine! no idea why they call it 3.0T! it should have been 3.0S!
1984 Porsche 944- New Toy
2009 Acura RDX Turbo
mo_focus is offline   Reply With Quote
Old November 1st, 2011, 11:57   #8
WVU TDI
WVU TDI's Avatar
Marketing.
1997 Passat TDI (sold)
2001 Golf TDI (sold)
2010 4dr Golf TDI, 6M (sold)
2013 Passat TDI SE, 6M -- turbo failed at 9500 miles.
WVU TDI is offline   Reply With Quote
Old November 1st, 2011, 13:05   #9
Toronto_Vento
Toronto_Vento's Avatar
Fuel Economy: 50/48/44
Mercedes had the Kompressor engines which were supercharged, but are switching to turbo slowly.
I thought I remember something about VW coming up with a combo unit. Small engine with a supercharger for lower the lower RPM zone (where turbo lag is of greater concern) and a turbo for the higher RPMs. Fuel economy was supposed to be nearing that of diesels.
-- John K
Wingnut's HOW TO's thread
"The commuting system is so badly broken that it will take decades just to bring it up to a level where it is merely malfunctioning." - Globe Drive
Toronto_Vento is offline   Reply With Quote
Old November 1st, 2011, 13:10   #10
diffas
diffas's Avatar
vw used those on 1.4tsi engines. 1.4tsi up to 180hp output in Polo GTI.
diffas is online now   Reply With Quote
Old November 1st, 2011, 15:14   #11
Silver02TDI
Silver02TDI's Avatar
I guess you don't see them here because our cars already have turbos, so it's easier to just put on a bigger turbo. Removing the turbo and adding a supercharger probably isn't feasible. Outside of diesels, the VR6 crowd use to love to supercharge because it was cheaper than turbo-ing their VR6's. But, a VR6T was everyone's dream (fuel efficiency aside)
2015 Highlander Hybrid Limited
2015 Passat TDI Comfortline / Sport Pkg
2012 Golf Wagon TDI 6spd Highline /w Nav (Bought Back)
2002 Jetta TDI (Traded)
Silver02TDI is offline   Reply With Quote
Old November 1st, 2011, 16:43   #12
imo000
imo000's Avatar
I have two turbos and a supercharged one. The SC is a homebuilt setup.
Old November 1st, 2011, 17:02   #13
Ski in NC
Superchargers can work in a normal (not race) car with clever plumbing and or clutching. So sc only comes on line when it is needed. Sure don't want any valve overlap, though!! Especially on a gasser with normal fuel injection.
Some marine engines (volvo KAMD series) use a sc with an electric clutch to force feed the turbo until the turbo takes over. Then clutch disengages and a bypass valve diverts turbo suction from compressor to air filter. Works well to get torque down low. Dang hard on the belts, though.
I like the old mad max cars with the clutched blowers. Fun!!
Old November 2nd, 2011, 17:20   #14
imo000
imo000's Avatar
Originally Posted by Ski in NC View Post
.......I like the old mad max cars with the clutched blowers. Fun!!
You do realize that was all special effects, right? The SC clutch wasn't real, only movie magic.
There isn't strong enough of an electro magentic clutch, running on 12V, that can do that to a sueprcharger and last. Once you spin one by hand, you'll understnad why.
The first gen MR2 had one but their SC was very small.
Old November 2nd, 2011, 21:43   #15
Ski in NC
I know those were a prop. Well, actually I figured it out years later. Buzz kill, that!!!
It is doable, there are electro-mag clutches that can carry alot of torque. maybe not enough though. Heck, a clutch pack from a autobox would work, but that's alot of machining...
One can dream..
And they spin easy by hand, just hard when there is a delta p.
Electric supercharger? 4Gman TDI Power Enhancements 4 April 5th, 2008 09:52
VW's Gas Turbo/Supercharger 1.4L to replace diesels? NHTDI General VW Discussion 27 February 11th, 2007 18:45
Why not use a supercharger? Keiller TDI 101 33 February 4th, 2005 17:06
Supercharger? BIGJOHNO TDI Power Enhancements 8 February 11th, 2001 19:33
Supercharger? BIGJOHNO VW MKIV-A4 TDIs (VE and PD) 6 February 9th, 2001 15:02
Page generated in 0.13076 seconds with 10 queries
[Output: 129.01 Kb. compressed to 107.69 Kb. by saving 21.32 Kb. (16.53%)]
