Old October 30th, 2011, 17:59   #1
FirstOrbit84
FirstOrbit84's Avatar
Default The <$100 Lower IC pipe (pancake pipe) upgrade
Hey folks! I just wanted to share how I upgraded my pancake pipe today with an OEM one from a 1.8T... Basically, I'm trying to do all of the supporting mods before I spring for a turbo (or if I don't buy the turbo, I'll end up as the fastest VNT-15 ). So, I'll be doing IC piping, intake piping, upgraded SMIC, race pipe, EGT gauge, downpipe... and then 17/22...
I started by looking at the piping set from ID parts, but at $155, I felt I could do better.
Then I found a couple articles on UK-MkIVs that got me inspired:
http://uk-mkivs.net/forums/p/193681/1302951.aspx
http://uk-mkivs.net/forums/p/194729/1263970.aspx
So, I picked up a used 1.8T pancake pipe from VWVortex for $35 shipped, and I bought about $60 of supporting hardware from http://www.frozenboost.com/ NAPA, and Advance Auto Parts:
UPDATE: This mod can be done much cheaper and easier by simply getting a 2" diameter hump hose connector; trim about 1/4" of length from each side, and attach one end to the pancake pipe, and the other end to the metal connector of the stock turbo outlet hose.
The parts I needed from FrozenBoost were:
2" to 1.375" silicone reducer
2" stainless steel joiner
1.375" stainless joiner
2" T-bolt clamps
(I also bought a 90 degree 2" section but did not need it, so I will use it on my custom air intake.)
Then, I got a 2" section of hose from NAPA that had several bends that looked useful, and two worm hose clamps from Advance Auto for the smaller piping. Plus, I was given an extra stock early style turbo outlet hose from a local friend/TDI guru.
First I jacked the car up, put it on jack stands, removed the skid-plate, front passenger wheel, fender liner, and passenger side engine skirt:
Then, I took out the old pancake pipe and compared the two:
Then, I chopped the 90 degree elbow off the stock turbo outlet hose, and attached it to the 1.375" stainless joiner with a worm hose clamp (not shown):
Then I put that section back on the turbo outlet on the car because it was easier to work with like that.
Then I cut into the rubber hose from NAPA to get the angle that I needed, and attached that to the 1.8T pancake pipe with a worm clamp, and then to the 2" stainless joiner and then to the 2" to 1.375" reducer with t-bolt clamps. I tried to match the angles of the stock piping as best as I could:
Then I fit the whole thing on the car, and tightened all the clamps, and took her for a test drive!
Once I was sure that the boost was holding well, I came back to button everything up by putting the engine skirt on, fender liner, and skid plate.
In situ:
I definitely noticed a good amount less turbo lag, and there should be a bit more top end power in theory, but I couldn't really tell much of a difference in overall power.
Next will be race pipe, custom intake piping, and then, ebay SMIC!
Check out my car blog
FirstOrbit84 is offline   Reply With Quote
Old October 30th, 2011, 19:13   #2
shizzler
TDI(s): 05 BEW Wagon
Fuel Economy: mid 40s
Nice. Thanks for sharing!
'05 Jetta Wagon: For Sale
shizzler is offline   Reply With Quote
Old October 30th, 2011, 19:19   #3
CT TDI
CT TDI's Avatar
TDI(s): 1999.5 Jetta
Did the IC to pancake pipe have to be changed or can that stay the same. I may end up doing this mod next weekend as I already have a 1.8t pancake pipe set aside for it.
CT TDI is offline   Reply With Quote
Old October 30th, 2011, 19:22   #4
davebugs
I'm curous as well.
I have a 1.8t stock pancake pipe (around here somewhere) and am wondering what it will take, then the next issue will be possibly clearing my DG metal sideskirts.
davebugs is offline   Reply With Quote
Old October 30th, 2011, 21:15   #5
FL/COtdi
FL/COtdi's Avatar
Thanks so much for the how-to, subscribed.
Mal2egr, DG skid/side skirts/oil filter, Nick ff, froheat, Koni FSD, Shine springs/rsb, fsb delete, 11mm, BPP 764, wavetrac 3.19/.917/.658, sbc2daily, 108mm, 256k miles, 3" fat cat
FL/COtdi is offline   Reply With Quote
Old October 31st, 2011, 03:38   #6
FirstOrbit84
Nope, the other end of the pancake pipe fits right into the stock intercooler connection, they are both 60mm IIRC. I believe our stock IC is the same as the 1.8T IC.
also wanted to mention:
the elbow from the inlet end of the pancake pipe to the reducer should be approximately 30 degrees to 45 degrees. the bend at the end of the stock turbo outlet hose is 35 degrees, but i found out that the inlet end of the 1.8t pancake pipe is at a slightly different angle.... that's why i ended up going with the 2-ply rubber hose from NAPA as opposed to a 30 degree or 45 degree 4-ply coupler: because it was more flexible, and had the right sort of a bend and twist that i was looking for...
another method would have been to weld a reducer on the 1.8t pancake pipe, but the quotes i got were in the same ballpark as the cost of all the couplers, and now if i do upgade the turbo later, i can just change the reducer size to match the new turbo outlet.
also, you want to remember to transfer the rubber insert at the hanger from the old pancake pipe to the new one, if yours does not have one already.
Old October 31st, 2011, 04:16   #7
cog
did this a while back but because my turbo was reclocked to fit the stock piping it made it a bit more of a pain. but if your using stock turbo this isnt a bad how to . you deffinatly notice an increase in response not sure about anything else but definatly seems to respond instantly now
Now BMW 123d @ 272bhp
Formerly GT-TDI 110 AHF VNT 17VB[/B],@24psi ,,R520s,ported head,11mm pump,arp,headstuds,eurojet smic,id parts upgraded pipes,SBC[B] stage 3, pd150 manifold, custom silicone t.i.p 2.5"downpipe and cat delete,racepipe,,pd lift pump
cog is offline   Reply With Quote
Old October 31st, 2011, 06:10   #8
n1das
n1das's Avatar
Fuel Economy: Who cares? It's a DIESEL! Great fuel economy comes as a bonus!
Cool
Do you have an EGT gauge? Any noticeable drop in EGTs? Even if the mod doesn't give any power gain(s), it may help lower EGTs, important for future mods you have planned.
Good luck.
Why DIESEL is better: (Courtesy TDIclub forum member wxman)
PM - https://sites.google.com/view/lmarzccm/home
Air Toxics - https://sites.google.com/view/loren-marz-ccm/home
Ozone Precursors - https://sites.google.com/view/lorenmarz-ccm/home
General - https://sites.google.com/view/emissions-general/home
n1das is offline   Reply With Quote
Old October 31st, 2011, 06:35   #9
bhodgkiss
how does this mod actually help please? it looks to be larger volume, so how does this reduce lag? This is an intake pipe from the intercooler or into it? (I have a Passat, not Golf, just curious)
AFN Wagon | Fjord Blue | BV43 | 11mm IP | R520 | PD Lift Pump | Ported head | 3bar MAP | SRE Clutch | FHN G'box | Forge FMIC | PD130 intake | EGR delete | Decat | Custom Remap | Porsche 4-pot 312mm Brakes | KW V1 | Carbon Upper Strut Brace, RS4 Lower | H&R 32mm Front ARB | Whiteline Rear ARB | OZ Ultraleg 18" Satin Black | OEM Xenons | Bucket seats | Battery & washer bottle in boot | 100kg removed |
bhodgkiss is offline   Reply With Quote
Old October 31st, 2011, 07:08   #10
CalvinM
TDI(s): 2003 Golf
This is the inlet side of the intercooler from the turbo on our cars.
I am also wondering how this would reduce lag. I can definitely see the top end gains from more flow, but it does seem to me that a restriction there would help spool up a little bit faster.
2003 Golf 4 Door, Oz Super Leggeras, Mods TBD
2001 Jetta, 1019 injectors, FMJ, BBS RCs, DG Shifter, for sale this fall
SOLD 2003 Golf, 2 Door, RC3, T4 Injectors, Full Metal Jacket, GTI Suspension, 337 Interior
CalvinM is offline   Reply With Quote
Old October 31st, 2011, 08:58   #11
FirstOrbit84
No EGT gauge. I do have a scan gauge so I can see intake temps at the IC, and they didn't look too much different, if at all.
This pipe goes from the turbo to the intercooler.
I'm not sure if I'm correct on the theory behind why there would be less lag, but I believe the spool up is a function of boost requested by the ecu (which is a function of throttle input and tuning) and engine speed (and therefore exhaust flow available to spool). By opening up the path from turbo to intercooler your boost gets to the intake quicker and more efficiently, producing less lag and overboost. Someone please correct me if I'm wrong.
Old October 31st, 2011, 13:48   #12
VWBeamer
Fuel Economy: 42.79 mpg Woot!
I have the 1.8t pancake pipe with the lower intercooler hose from idparts.
Hooked right up to the 17/22 I'm running. but I had to weld a 2.5 inch inlet on the pancake pipe.
Got my 1.8t pipe off ebay for under 20 buck IIRC. Still under 100 bucks total.
Pictures in this thread
http://forums.tdiclub.com/showthread.php?t=300211
800 club. 828.5 miles, 16.33 gallons, 50.79 mpg.
2004 Jetta GLS Wagon TDi-17/22, 2.5 DP.2.5 Exhaust, Stage 5 Malone Tune.3 bar MAP, pd150 Injectors, Ebay FMIC, 1.8T Pancake pipe. Gutted PD100 intake.
VWBeamer is offline   Reply With Quote
Old October 31st, 2011, 13:55   #13
JFettig
JFettig's Avatar
If Isonic ever gets me some of the pics he took I'll post them up. I turned a custom reducing coupler for him, he put a 1.75" elbow off of his 17/22, through my coupler to 2" either 30 or 45 elbow right into the pancake pipe.
Boost definitely comes on sooner. If people thought a 17/22 sounds funny, a 17/22 with a 1.8T pancake pipe sounds like rape.
JFettig is offline   Reply With Quote
Old October 31st, 2011, 18:03   #14
isonic
Yeah the 17/22 has a distinct sound. Then when a 1.8T pancake pipe is added it does sound pretty cool. Here are the pictures Jon was talking about:
Every thing is 2" except for the 1.75" 90 degree elbow that connects to the 17/22 outlet. It is a tight fit but it doesn't rub on the block and it sounds way better than the stock piping. Plus, being from a 1.8T, it can NeVaR lose ;-)
SBC Stg II Endurance, EGR Delete, R520, VNT17/22, 2.5" DP, 3 Bar MAP, Malone Stg 5, 1.8T Pancake Pipe, 2.5" TIP, EuroJet SMIC, Stg 2 Cam, 11mm IP, lift pump, BFI Motor Mounts, Panzer Skid Plate, 288mm brakes, Koni Coils, boost/EGT/Oil pressure gauges.
isonic is offline   Reply With Quote
Old October 31st, 2011, 18:14   #15
FirstOrbit84
cool, ya you have a couple less connections compared to mine...
in the last pic, it looks like it was rubbing on your axle a bit...
VNT 17 upgrade on BEW with stock SMIC - Pancake pipe upgrade? TdiTaff TDI Power Enhancements 23 May 17th, 2011 19:53
Pancake pipe upgrade? davebugs VW MKIV-A4 TDIs (VE and PD) 15 April 17th, 2011 05:00
Pancake pipe + Inlet pipe $50 free shipping Embs Private TDI Items for Sale/Wanted 0 September 3rd, 2009 10:44
PD Pancake Pipe to IC connection Occams_Razor TDI Power Enhancements 1 June 10th, 2009 04:36
WANTED: Lower IC pipe Wingnut Private TDI Items for Sale/Wanted 3 December 15th, 2004 00:32
Page generated in 0.18207 seconds with 10 queries
[Output: 136.36 Kb. compressed to 114.53 Kb. by saving 21.83 Kb. (16.01%)]
