Old October 30th, 2011, 16:58   #1
n9lhm
Default door switch location
2002 Jetta, dome light only comes on intermittently when driver's door is opened, and never when passenger door is opened, and door ajar warning does not illuminate. When either back door is opened, dome light comes on and door ajar is displayed on the dash. Where is the door open sense switch for the front doors located? Any suggestions on how to access it easiest? Or does anyone have any experience with this symptom being something else? (I did see the thread about broken wires in the flex boot in the door jamb)
Brian
n9lhm is offline   Reply With Quote
Old October 30th, 2011, 18:56   #2
Vince Waldon
Vince Waldon's Avatar
Search yea the "$3 door fix" thread... it's about a hundred pages long and has great pictures, discussion, etc.
Vince Waldon Edmonton AB Canada
Note: The above is to the best of my knowledge- but at the end of the day simply interweb opinion, worth EXACTLY what you paid for it, and if used done so at your own risk.
Vince Waldon is offline   Reply With Quote
Old October 31st, 2011, 11:01   #3
Powder Hound
Powder Hound's Avatar
Originally Posted by n9lhm View Post
... Where is the door open sense switch for the front doors located? Any suggestions on how to access it easiest? ...
The referenced thread is very good. It should point you to a couple of threads on this problem (on vwvortex, no less), with lots of discussion on different sets of symptoms and what to do to fix them.
In short, the switches you need are in a latch mechanism buried inside the door. There's 4 switches, but the upside is that most of the time, it is bad solder joints rather than switches going bad, that cause most of the problems encountered.
Good luck, and hopefully you won't have to buy anything unless you don't already have a soldering iron.
Cheers,
PH
Old October 31st, 2011, 13:18   #4
eb2143
eb2143's Avatar
TDI(s): None
I dunno Eric, I'm pretty sure the vast majority of failures are the switch itself. The little plastic nub that the door cam rotates against is basically a miniature version of the Whac-A-Mole game and it just can't hold up in the long term.
But you're right there is a solder joint problem on the circuit board in the lock module, but I only hear it being an issue infrequently compared to the switch.
If the OP doesn't feel like reading a mountain, here's a printable HOW_TO I put together, mostly with existing information:
http://forums.tdiclub.com/showpost.p...&postcount=379
PS: Salisbury! Good to see the wheel bearing tools moving closer for the next time one goes!!
SOLD MY BABY: 2001 Jetta TDI 5mt, Bosio Sprint 520s, Koni FSDs, VW HD Springs, 10mm spacer, Audi TT LCA bushings, 034 motorsports strut mounts, E-code lights, Audi TT "short"-shifter, IDparts rear sway bar, DG Panzer plate, Caterpillar 2m fuel filter, Frostheater, GLI Recaros, GTI 3-spoke steering wheel, Audi S3 shifter, R-line stainless pedals[/URL]
eb2143 is offline   Reply With Quote
Old November 1st, 2011, 13:06   #5
Powder Hound
True that the switch itself can fail. I am not going to claim I know about all the failures and how many are due to switch failures or just solder joints. There are 4 switches inside the module, and hopefully visual examination will tell whether a switch is dead or that intermittent problem is a flaky solder fracture. Mine so far have all been solder fractures.
Yeah, I'm probably 10 miles closer to New London than previously. But while I can work where the cars are parked now, I still don't have a garage, so ...
Good thing coming from that direction (north) is that a GPS will work. They don't have my address correctly mapped, so if you are coming from the south, you will be led onto a virtually impassable road. Sometimes new technology isn't quite everything it is supposed to be!
Old November 2nd, 2011, 09:47   #6
n9lhm
Thanks for the replies, I do electronic repair for a living so replacing the switch is not a problem. Just curious -- what actuates the switch mechanically? Something has to sense whether the door is touching the door jamb or not -- it's not a door lock sensor, per se..........
Old November 2nd, 2011, 10:14   #7
Powder Hound
There's levers and other moving parts in the latch/lock mechanism that actuate the switches. You are correct in that the switch itself isn't hitting the door jamb. Some engineer had to think about that mechanism for a while.
Old September 2nd, 2015, 04:41   #8
wetskier2000
Default Quality of these parts??
2005 Wagon. Some years ago I had the flaky lock issue and replaced the mega door switch thing to solve it. Now I have the "car doesn't know the driver's door is open issue"... It's the same module, right? Any replacements better quality than others? I've seen the information about replacing just the switch, but would prefer to put something in there that might last...
Rick
Sold but will be missed: '05 Jetta Wagon - RC1+, G60/VR6
New Ride: 2015 Golf Sportwagen SEL. Only cosmetic changes so far(door sill and edge protection, body side molding, wind/rain deflectors).
wetskier2000 is offline   Reply With Quote
Old September 2nd, 2015, 05:21   #9
UhOh
UhOh's Avatar
Yeah, same part.
What did you go with the first time?
I got my modules, new OEM, for $125 ea from GermanAutoSupply.com
Old September 2nd, 2015, 06:25   #10
wetskier2000
Thanks for the confirmation. I don't recall where I got the part the last time. I do know it was 2012.
Rick
Old September 2nd, 2015, 06:33   #11
UhOh
UhOh's Avatar
Do you recall whether it was OEM? Price paid would kind of point to that if that's the case.
Old September 2nd, 2015, 13:03   #12
wetskier2000
I don't recall either.. With all the vehicles and project vehicles in my garage, if I don't happen to write it down in the maintenance log, it usually doesn't get remembered..
I see talk about the harness instead of the switch/module... Something about the 05/06 door harness is too short and pulls apart... True? Where does it pull apart?
Rick
Hood micro switch location kbrenny TDI 101 1 January 3rd, 2009 12:46
Location of Clutch Switch? 9PasCollinsat6 VW MKIII-A3/B4 TDIs 2 July 31st, 2008 08:24
Brake Switch Location Marks04 TDI 101 2 April 17th, 2008 09:40
Location of door switch Hamman VW MKIV-A4 TDIs (VE and PD) 3 August 24th, 2004 21:13
Trunk switch location? BigAl VW MKIV-A4 TDIs (VE and PD) 2 February 8th, 2002 11:19
Page generated in 0.15410 seconds with 10 queries
[Output: 112.96 Kb. compressed to 95.58 Kb. by saving 17.38 Kb. (15.39%)]
