Old October 28th, 2011, 12:07   #1
SoaceMunky
SoaceMunky's Avatar
Default contamplating heating coolant.
specifically, can someone please clarify the difference between the different coolant heaters available: Zerostart and Frostheater. I'm assuming Frostheater is a lot easier to install, and comes with a complete kit.
also, whats the story with these plug-in heating elements from Phillips and Temro? Is there a solution for the TDI, or is there drilling required? Can I run it off my battery for some quick heat while in the store or when away from electrical outlet?
For clarification, I'm planning on installing the Frostheater because I do a lot of short trips to the gym, but there is no outlet there, so I would like to combine it with a heating plug.
What do you guys think?
2006 MkIV Anthracite Blue LC7V Golf 5spd BEW + tint, stubbie antenna, ventectomy, bike rack, >⅛Mmi;
SoaceMunky is offline   Reply With Quote
Old October 28th, 2011, 13:16   #2
purediesel
Well last night was the first nigt it got below freezing and even before this happened I was thinking about installing one of these. Did a bit of research on the two companys that you listed and the Zerostart is only a 750 watt heater while the Frostheater is 1000 watt. Just a lil info. I think I'll be going with the Frostheater since thats what is installed on a friends car already, and he hasn't had any issues for the few years its been installed.
purediesel is offline   Reply With Quote
Old October 28th, 2011, 13:21   #3
SoaceMunky
SoaceMunky's Avatar
good point, i think i will get the one from Kerma. please excuse me while i drool over Webasto[pdf]
Old October 28th, 2011, 13:52   #4
Or Turbo Diesel
Zerostart makes 1000 and 1500 watt heaters also, I have a 1500 but haven't installed it yet.
Here is a link I found:http:
//www.jcwhitney.com/tank-type-engine-heaters/p2000837.jcwx#prodDetailTabPanel
1995 Passat GLX Tdi Wagon- Full conversion
Or Turbo Diesel is offline   Reply With Quote
Old October 29th, 2011, 08:35   #5
mech644
The Frostheater brand is a line of complete kits designed specifically for tdi's that utilizes a tank/heating element sourced from Zerostart; kit also includes hoses, clamps, etc. For the price they are a bargain.
Installing a coolant heater on a MKIV tdi is not the same as installing one on most other cars. Installing a generic heater, even a Zerostart, is going to be a PITA as compared to the Frostheater, and it may not perform nearly as well.
2012 Platinum S-line A3 DSG- bought back by VW
2000 Golf 5spd, 301k, the usual mods, sits forlornly in the backyard.
2006 Jetta DSG- gone
2015 GHB SEL 1.8 tsi
2014 Touareg
mech644 is offline   Reply With Quote
Old October 29th, 2011, 16:45   #6
SoaceMunky
SoaceMunky's Avatar
thank you for completely true and useful information! i bet it gets mighty cold in Maine, and these come in very useful. do you use one of these kits yourself? what do you think about the power draw on one of these units, and could it be possible to run it on the car battery, provided some discharge guard was installed...
Old October 30th, 2011, 10:06   #7
NB_TDi
NB_TDi's Avatar
Fuel Economy: Best 56MPG
Impossible to run on the battery. The physical limitation of the battery storage device could not sustain a consistent flow of current to heat the engine and then start the car.
The ONLY way to operate a coolant heater is with a 120V 15A outlet.
1994 Jetta 1.8 2000 Jetta TDI, 2005 Jetta 2.0, 2010 Tiguan 2.0 TFSI 4Motion, 2014 Jetta 2.0
Everytime you post a picture with PhotoBucket, a TDI gets below 30MPG.
NB_TDi is offline   Reply With Quote
Old October 30th, 2011, 18:30   #8
mech644
I don't have one, yet. I've lived off the grid since I purchased the Golf in '06 till now. Running a coolant heater is way down the list of priorities on what my amp/hours of power get allocated to. I'm going to install one this fall though. I can plug in at work and am spending about .5 the week at a location on the grid.
I wouldn't think twice about what to buy however for a MKIV, Frostheater wins hands down.
2014 Touareg
Old October 31st, 2011, 08:48   #9
coalminer16
coalminer16's Avatar
TDI(s): Golf 2004
Fuel Economy: as good as 58 (over 700 miles) and as low as 30 over the same route
Not 100% true "Webasto Heater" is ran off of the diesel and uses a little bit of battery to keep it running. Truckers use it and there is a few TDI's out there with them as well. But other then that your are correct. The Frost heater is more cost effective then the Webasto heater for buying unless you have no plug-ins anywhere.
Shade Tree Mechanic "I'm too shady to know anything"
1981 Rabbit car 1.9aaz, 5 spd, 1981 Caddy VW truck diesel, 2004 Golf-2 inch lift, -fixing, 2005 Golf-2 inch lift - totaled twice and fixed twice, 2005 Jetta Wagon - 2 inch lift
Originally Posted by rmchambers
I really had no idea that VW dealerships were so awful to go to, they sound like undertakers cos everything that goes in there winds up dead.
coalminer16 is offline   Reply With Quote
Old October 31st, 2011, 09:19   #10
mech644
Espar makes similiar heaters as well, higher quality in fact (with a price to match). Both Webasto and Espar make various types and sizes of heaters heaters that we install in boats for central heat. Good stuff but spendy.
2014 Touareg
Old October 31st, 2011, 16:41   #11
dandywriter
Default Mk V in Canada
I have a TDIHeater (by Frostheater) 1000W kit (part # HTR7 (2005.5-2006 TDI 5 spd only)). I've used it down to -40 (C or F, take your pick) when I'm a bit further north (North Bay or thereabouts). I don't need any more heat - 90C from startup, usually clear windows too. I have a timer, I turn it on 3 hrs (metric ) before I plan to leave.
If you want to avoid "cord dangle" and having to clean the plug of snow/mud, there is a classy looking addition you can do - the "Coolant Heater Lower Grill Outlet". See http://forums.tdiclub.com/showthread...ht=frostheater for details. I finally got around to finishing mine - the epoxy is now curing on it. Not so easy on a Mk V as some earlier models, but still doable by an "all thumbs" workman.
Dan
2006 Jetta TDI 5-sp, Bosal hitch, frostheater, evo skidplate, upgraded rear springs and front spring dist kit (1" lift), GIAC Stg 1 tune, USA Spec iPod adapter, SMF clutch, Coolant Heater Grill Outlet, winter front, LED backup and lic lights, VCDS
Last edited by dandywriter; October 31st, 2011 at 16:54. Reason: added detail on plug-in cosmetic mod; grammar
dandywriter is offline   Reply With Quote
Old October 31st, 2011, 20:45   #12
NB_TDi
NB_TDi's Avatar
Well yes, but the OP is talking about the resistive type.
Old November 1st, 2011, 07:50   #13
coalminer16
TDI(s): Golf 2004
I know, had to give you are hard time and let others know there is another option. But expensive and it can hurt the MPG as it is using fuel.
Old November 1st, 2011, 13:56   #14
Tim$2
Tim$2's Avatar
TDI(s): 2009 JSW
Dan
There is also a replacement grill piece that accepts a regular 3 prong plug as well if you don't want that fancy style of
connector.
Edit: Just noticed that DIY one is for MKIV, I'm talking MKV.
Cup holder iPod dock, Frostheater
Tim$2 is offline   Reply With Quote
Old November 1st, 2011, 14:06   #15
compu_85
Gadget Guy
compu_85's Avatar
The frost heater is a zerostart heater with all the oddments needed to attach it to your car.
-J
Present:
2013 Fiat 500e. 22,000 miles.
Past:
zerostart not heating the coolant? bungy42 TDI 101 12 December 4th, 2014 11:37
Over heating while full of coolant garrettp TDI 101 10 August 2nd, 2011 15:28
coolant / heating issues Vik F TDI 101 7 February 4th, 2007 09:14
Glow plugs; coolant heating awmw TDI 101 0 October 30th, 2006 16:44
glow plug for coolant heating Mark_J TDI 101 13 September 19th, 2005 20:49
Page generated in 0.16869 seconds with 10 queries
[Output: 136.90 Kb. compressed to 114.71 Kb. by saving 22.20 Kb. (16.21%)]
