Go Back   TDIClub Forums > Meetings/ GTG/ Regional Discussions > Eastern USA
Eastern USA Local discussions for those in the Eastern USA. (Vermont, New Hampshire, Massachusetts, Maine, Washington, DC. New York, New Jersey, Connecticut, Rhode Island, Delaware, Maryland, Pennsylvania, Virginia, West Virginia)
Old November 3rd, 2011, 19:30   #16
TDIJetta99
TDIJetta99's Avatar
Fuel Economy: low 38, high 61, avg 48
Also, the vast majority of torque wrenches only measure in one direction.. I have one that goes both ways (no pun intended) for a few reverse threaded applications but that's about all I use it for.. I also use it for checking breaking torque when loosening cylinder head bolts on problem engines..
Trusted northeast TDI guru (They tell me I can fix these things)
TDIJetta99 is offline   Reply With Quote
Old November 3rd, 2011, 20:03   #17
migbro
TDI(s): 2003 Golf GL
Originally Posted by btcost View Post
you never need a torque wrench to get things loose.
those are called "breaker bars"
torque wrenches are ONLY for re-assembly. when putting nice, clean parts back together.
Dude, in this case, you couldn't be more wrong. It's VERY important to use a torque wrench to remove the glow plugs. The maximum torque for removing 10mm glow plugs is 25 ft. lbs. Any more and the glow plug will break.
2003 Golf GL TDI 5-speed 128,000 miles
migbro is offline   Reply With Quote
Old November 3rd, 2011, 20:22   #18
maxwellp
maxwellp's Avatar
Fuel Economy: 47.25
Originally Posted by Digital4n6 View Post
the main reason for not using a torque wrench instead of a breaker bar is that it could very likely throw off the torque wrench's calibration.
Then how would you torque left handed nut and bolts, all my torque wrench's will go both ways.
The reason for using a torque wrench for removing the glow plugs is not to break them off. Don't use more than 25 foot pounds for removing them.
BUT you could still break one!!
1998 Beetle TDI Malone Tuning Stage 2
2001 Dodge Cummins 5.9 2005 Dodge Cummins 5.9
2006 Jeep Liberty 2.8 CRD
ASE, OBDII / VAG-CAN scaner / Service Manual
maxwellp is offline   Reply With Quote
Old November 4th, 2011, 03:08   #19
PeterV
HO5G Doyen & Zen Master
PeterV's Avatar
WE need it too for the '65 Barracuda YEP LH threads on the drivers side..
PeterV 'BUG*pwr award 2005'
'00 Jetta TDI, RC, Shine, DG RPipe, 520PP, DG/SS LED Boost ASR. Home of HO5G '96 Cummins CTD 3/4 ton now at 274 HP 670 ft Lbs TQ
Trusted TDI Mechanics Map || VCDS Locator ||
PeterV is offline   Reply With Quote
Old November 4th, 2011, 05:41   #20
TDIJetta99
TDIJetta99's Avatar
What brand of glowplug breaks at 25 ft-lbs? I will avoid purchasing them..
So far I've never used a torque wrench to remove a glow plug... I've probably changed the glowplugs on 3000 engines LOL... I can understand the need for someone who doesn't turn a wrench every day to use one when loosening them since they probably have no idea what 25 ft-lbs feels like until it breaks...
The best advice I can give is to use a 1/4" drive short ratchet and an 8-12" extension.. 25 ft-lbs is pretty hard to achieve with a 4" long ratchet...
Old November 4th, 2011, 09:28   #21
btcost
btcost's Avatar
Fuel Economy: using Fuelly. . 33ish for now
Well seeing how my 1/2 torque wrench cost $350 and my 3/8 cost $250. I never never never use them to take things apart.
Don't want destroy expensive wrenches. Carefully use regular wrenches or a breaker when needed.
Never broken off a GP. In fact my worst broken bolt was thee turbo return on my alh. I was useing a 1/4 ratchet. And not even torquing it hard.
2012 JSW platinum grey, Euro mirrors, euro switch, front & rear fogs, DG Panzer plate, euro hitch & Parktronic waiting for install
1987 300DT: Blistein HD's, 16" CLK wheels, euro headlights w/levelers
URL=http://www.fuelly.com/driver/Btcost/jetta][/URL]
btcost is offline   Reply With Quote
Old November 4th, 2011, 09:45   #22
ymz
Fuel Economy: 5.3 l/100 km (at 115 km/h)
Beru used to have a document on their website that stated:
"Do not exceed the maximum release torque – 8mm GP-20Nm, 10mm GP-35Nm, 12mm GP-45Nm."
They no longer have the document (TI04_e.pdf) on their website... (If anyone has saved a copy, it would be nice to have access to it...
Yuri
PS:
Wimp...
Pereat mundus, fiat musica!
ymz is offline   Reply With Quote
97 passat $1000 western mass GotEuroCorrado TDI Cars for Sale/Wanted 1 April 20th, 2011 21:18
Any Tuners in western Mass area ? maxdog Eastern USA 6 March 4th, 2011 16:33
Need good TDI mechanic in Western Mass. dyvyd Eastern USA 7 June 23rd, 2009 03:05
Western Mass/Berkshire/Albany mechanic? bcw1969 Eastern USA 8 August 19th, 2008 08:05
Good TDI mechanic in western Mass? Digeridoo TDI 101 8 October 1st, 2006 10:41
Page generated in 0.12302 seconds with 10 queries
[Output: 87.17 Kb. compressed to 75.77 Kb. by saving 11.39 Kb. (13.07%)]
