Old October 25th, 2011, 22:03   #1
bowelder
Default thermostat replacement ALH
after looking through the TDI 101 how to's, I need to ask a question. What are some of your tips about changing the thermostat and housing on a 2000 Golf TDI?
thanks
bowelder is offline   Reply With Quote
Old October 25th, 2011, 22:04   #2
greengeeker
greengeeker's Avatar
Fuel Economy: 42.2/50.0/58.1
A4 thermostat change How-To
- Nick -
02 Jetta TDI 308k (42.2/50.3/59.4 MPG) // 01 Eurovan 24V (18 MPG) // 00 TDI Ranger (39MPG)
How to Post Pics - How to Search
TDIclub trusted mechanic in Minnesota - PM me
greengeeker is offline   Reply With Quote
Old October 26th, 2011, 04:01   #3
oldpoopie
oldpoopie's Avatar
Biggest tip is to only use an OEM thermostat. Most of the aftermarket ones won't clip into the thermostat housing. Boraparts carries the oem thermostat. Makes the job so much easier.
Pacific Northwest TRUSTED TDIClub mechanic
Email me, justgrow@gmail.com
Old October 26th, 2011, 05:27   #4
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
Yeah, only use OEM from Volkswagen (or whomever can get you one) and a new housing. Clip the new stat on to the housing after installing the o-ring. Super easy job, just 2 screws.
Also, only use the spring-type hose clamp (you can reuse them), as these not only provide constant uniform tension on the hose, but cannot crush the plastic nipple. The hoses themselves generally last forever unless they get contaminated with fuel or oil from a leak or something.
oilhammer
www.cardocautomotive.com
Old October 26th, 2011, 05:53   #5
chromeBuddha
chromeBuddha's Avatar
Fuel Economy: 47 mpg @ 75 mph
For the relative cost of the new housing, I agree with others on getting a new one. If you want to preserve the integrity of the original, use or make a hook about 8 inches long to hook the loop on the thermostat and pull that as you rock the housing free. Then you will have a good spare with the pins intact for next time...
2002 Golf TDI, 5-speed, 2-door
White w/ Tan interior (get the Scotchguard!!!)
47 mpg @ 75 mph
"El Bonbon" - The Marshmallow
chromeBuddha is offline   Reply With Quote
Old October 26th, 2011, 07:09   #6
Wksg
Fuel Economy: 64/56/45mpg
Twice I dropped the lower bolt that holds the housing in place and it fell down into a hard-to-get-to place. The second time I had to go buy one of those magnetic fish things to get it out. So, hang on to that one!
'03 GLS TDI Wagon, 403K miles, .658 5th gear, RC2, ventectomy, T4 nozzles, Stant 195F Thermostat
Wksg is offline   Reply With Quote
Old October 26th, 2011, 18:48   #7
boertje
boertje's Avatar
Boy do I know that one! I had to use a camera tube to see the bolt to fish it out. I had to remove the A/C and one alternator bolt to nudge the alternator forward to get to it. I did not want to take the chance that the bolt would possibly touch the alternator windings and cause problems down the road. Took 3 hours for a 20 minute job. This was on my bug. My golf was easier.
'01 and a 2nd '01 and a '03 NB TDI with 6 spd manual. '06 NB GLS TDI DSG.
All with Malone tuning of course.
Auto to 5/6 spd manual swap with wiring instructions for MKIV. Click here.
boertje is offline   Reply With Quote
Old October 27th, 2011, 07:40   #8
Victor Huge
Victor Huge's Avatar
TDI(s): 2001 Jetta
Yeah, i think i dropped that bolt as well, very frustrating. Plan for that and the mess.
If you plan, to change to coolant, keep in mind you'll have a hard time draining it if the thermostat is cold so you might as well remove it and then drain
Victor Huge is offline   Reply With Quote
Old October 27th, 2011, 16:10   #9
rackaracka
I take a small scrap of paper and wrap it around the bolt head and then shove the bolt into the 10MM socket. Then I use a small extension and get the bolt started. When you pull out the socket the paper falls or sometimes stays in the socket. You can blow it away with compressed air.
A small magnet in your socket also works really well.
2002 Jetta Wagon TDI Auto- Reflex Silver/Leather/Monsoon
95 Dodge 2500 w/Cummins TD - Straight piped 4 "
98 Beetle TDI 5spd - Herbie/11MM/VNT17/pp520/RC3/Mcnally Gauges/SBC2 Endurance/Bilstein HD's/Dieselgeek Panzer FMJ/3" Kerma turbo back
rackaracka is offline   Reply With Quote
Old October 27th, 2011, 16:28   #10
ymz
Fuel Economy: 5.3 l/100 km (at 115 km/h)
A magnet on an extendable stick should be one of the first tools one ever gets... (also good for finding plastered-over drywall screws when hunting for studs in the wall...)
Good idea... I've used that magnet-on-a-stick mentioned above to get the bolts started... it holds the bolt through enough turns to get the threads meshing...
bowelder: make sure to clean the sealing surface on the block really well with a plastic Brillo-type pad... if there are too many surface irregularities, the new thermostat and "O" ring will leak...
Yuri
Pereat mundus, fiat musica!
ymz is offline   Reply With Quote
Old October 27th, 2011, 16:42   #11
JC_1992
JC_1992's Avatar
I replaced my thermostat on my 02 jetta this spring and was able to save the old thermostat housing clips. None of them broke when removing the old thermostat, but since I had already purchased the new housing I put that in for good measure.
If you're careful and dont just yank the thermostat out I dont see why the clips would break.
2002 Jetta TDI GLS 190,000miles, 5-Speed
Mods/Upgrades: Snow Screen Delete, FrostHeater, 1.8t Pancake Pipe, RC Stage 3, Titan 520 nozzles, 17" Goal Wheels, Koni STR.T's, TT LCA's, SBC Stage 2 Endurance
In the process: Upgraded Upper IC Pipping, OMI, Exhaust
JC_1992 is offline   Reply With Quote
Old October 28th, 2011, 05:42   #12
oilhammer
oilhammer's Avatar
Because the o-ring sticks to the iron block, holding the thermostat behind it, that's why. I never even bother to try and save the plastic housing anyways, as once they have been tightened, heat cycled many times, and loosened, the likelihood of a leak is just too great.
I have assembled thermostat "assemblies" all ready to go for all the more popular VAG engines sitting in baggies on the shelf here.
oilhammer
Old February 14th, 2013, 08:21   #13
GeorgeZ
GeorgeZ's Avatar
TDI(s): 2000 Jetta
Fuel Economy: Usually 5.4 L/100 km
Default Thermostat change observations
Just changed the stat last night, here are my observations:
1. Difficult to get a wire to hook onto the thermostat since you can't see it
2. My bolts also had 5mm allen heads so with the proper allen key it's a tight fit & may help preventing losing the bolts
3. Despite the inaccuracy of the temp gauge, before the change it only went up 1/4-1/3 of the way, & after it goes to 1/2 & stays there.
2000 Jetta TDI GLS 5-speed...bone stock
2000 Honda Odyssey...banged up
GeorgeZ is offline   Reply With Quote
Old February 14th, 2013, 09:19   #14
DieselZappa
DieselZappa's Avatar
TDI(s): 2001 Golf
Fuel Economy: Avg. 52 mpg so far
Yup, get a long ball-head allen key/socket & new bolts to go with your new housing. Overall, it's not a bad job.
funkengruven
DieselZappa is offline   Reply With Quote
Old February 14th, 2013, 09:20   #15
oilhammer
oilhammer's Avatar
Yeah, ALH is cake... wait until all the CBEA/CJAA engines need them.
oilhammer
Thermostat replacement how-to dgoldsmith VW B5 Passat TDIs 32 November 19th, 2013 10:07
thermostat replacement? dljtruck TDI 101 3 January 8th, 2010 09:03
Help on thermostat replacement wilharper2000 TDI 101 3 January 15th, 2009 08:38
Thermostat Replacement irbk TDI 101 12 October 6th, 2008 15:16
Thermostat replacement Jamesmbolan TDI 101 4 February 12th, 2007 12:45
Page generated in 0.18941 seconds with 10 queries
[Output: 130.28 Kb. compressed to 108.49 Kb. by saving 21.79 Kb. (16.72%)]
