Old October 25th, 2011, 10:49   #1
DasTeknoViking
Default Clicking/loose steering B4
When I turn the steering wheel I hear clicking noises and feels as if something is binding up. Has anyone had issues with the universal joints or the column itself ? I replaced the lower arms, ball joints, tie rods, steering rack, control arm bushings, upper mounts and bearings and the noise is still there... Most of the items I replaced where in need of replacing anyways so it was like preventative maintenance and the rack was leaking. But I thought the noise and play in the wheel would go away but it steel feels sloppy.
Any ideas ? I'm bout to tear the covers off the column n have a looksie
Mike
1996 Passat TDi Stage 3+ TDT VNT 26psi
2008 GTi 4D DSG moded wifey mobile
2002 BMW K1200RS Ohlins suspended
DasTeknoViking is offline   Reply With Quote
Old October 25th, 2011, 11:19   #2
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
It is not something higher up, like the clockspring, is it?
The upper bearing is in the ignition lock cylinder housing, and can make some funky sounds too.
oilhammer
www.cardocautomotive.com
Old October 25th, 2011, 11:28   #3
DasTeknoViking
It's deff not a clock spring, the clunking loose steering feels like a bad u joint or something.
Searched Google etc and nothing came up.
Car has over 400k on it and most gasser B4s probably would have never made that far to experience the clunking/loose steering
Mike
Old October 25th, 2011, 11:30   #4
oilhammer
oilhammer's Avatar
Well there is an upper and lower drive shaft in the steering, each having its own U-joint, and they slide together with one another.
oilhammer
Old October 25th, 2011, 12:06   #5
DasTeknoViking
Thanks Hammer ! I will dissect it next time I have some time... Maybe just get a tilt and telescoping column out of a diff VW in there.
Mike
Old October 25th, 2011, 12:43   #6
Chris Bell
The housing that holds the steering shaft upper bearing is clamped to the column with a security shear bolt that usually stretches and loosens. The effect is usually just a "rocking" steering wheel, but if loose enough maybe it can cause other symptoms. Doubtful, but worth a check if you're in there anyway.
'15 GSW SE 6MT
'01 Golf 5MT
'97 Passat sedan
'96 Passat variant
'99 BMW M3 Cabrio
Chris Bell is offline   Reply With Quote
Old October 26th, 2011, 05:47   #7
50harleyrider
I have the same issue on one of my B4s. My steering even trys to bind up sometimes turning hard at low speeds in a parking lot. I replaced my ps pump but no help. Mine only has 268k too so it's hardly broke in
50harleyrider is offline   Reply With Quote
Old October 26th, 2011, 08:05   #8
DasTeknoViking
Had a pump go bad on mine last winter... So everything was replaced ! I'm gonna take it apart n figure out the issue.
Mike
Old October 26th, 2011, 09:05   #9
Chris Bell
And you can duplicate clicking and binding when articulating the rack through its range of motion by turning @ the tire(s)? Engine on & engine off? With steering coupling disconnected?
'15 GSW SE 6MT
'01 Golf 5MT
'97 Passat sedan
'96 Passat variant
'99 BMW M3 Cabrio
Old October 26th, 2011, 09:14   #10
DasTeknoViking
Noise/clicking isnt there with the column disconnected. I know for a fact cause I bleed the rack out when I installed it.
Gonna try to document whatever I find with pics, seems like somewhat of a common issue on these older B4s now.
Mike
Old October 26th, 2011, 15:33   #11
Campbellonh
Campbellonh's Avatar
I would be interested in what you find out. I'm getting a similar sound and feel (intermittent - can't always repeat it) which just started on mine (the one with over 400 as well). When I had it up on jacks this weekend I couldn't find culprit.
96 Passat TDI, white, 500K+ miles! SOLD
2010 JettaTDI, white gold, 90,000, Gone back to VW.
2014 Chevy Cruze TD, Red, 42K, Trifecta tune.
2014 Honda Crosstour (I know, a gasser, pretty nice though)
Campbellonh is offline   Reply With Quote
Old November 5th, 2011, 06:56   #12
DasTeknoViking
Alright yesterday I did some looking under the dash and it appears there is a bearing/bushing of some sort inside the column that wear out. Just as the steering shaft comes out of the column and meets with the U joint right by the firewall: there is a bearing/bushing in there that falls apart. I have approx 1/8" movement there and if I try to steer the wheel left n right I can see the shaft moving around in the column. Need to look up parts in ETKA to see if the parts are serviceable. Also the tamper proof bolts appear to be a bit on the loose side and need a tighten up.
Mike
Old November 8th, 2011, 11:08   #13
DasTeknoViking
Here is what you need to fix your loose wheel.
http://www.germanautoparts.com/Volks...sat/Body/126/1 and you get to keep your original ignition lock cylinder.
Also there is a bearing on the bottom of the column too.
http://golfgtiguides.co.uk/guides/fi...heel-mk2-golf/
Gonna see if the MK2 bearing is the same, I wouldn't be surprised if it was. Both bearings can be done w/o removing the steering column out of the car. I just had my steering wheel off last night and found my play to be up top and on the bottoms.
Mike
Old November 8th, 2011, 16:34   #14
TonyJetta
Fuel Economy: A5: 36mpg Avg / A6: 39
I have a similar issue...although on mine, it's the pivot bolt, near the bottom end of the column. I'm researching the fix, but could use some input.
Tony
Diesel fleet: 2015 Jetta TDI SE DSG; 2006 Jetta, TDI, DSG-5sp Conversion; 2006 DC Cummins, CC/LB/DRW; 1996 Passat TDI, 5sp, Project car! Troubleshooting Links: Trusted TDI Mechanics IP Timing Timing Belt FAQ A3/B4 Low Power Cyl Head Repair Fault Codes What you have just read is an opinion...take it as you see fit!
TonyJetta is offline   Reply With Quote
Old December 1st, 2011, 18:41   #15
Campbellonh
With Rich Tremblay's help, I found out what my problem was. There is a rubber grommet in a strap that holds the steering rack to the car frame. The grommet is a little worn, so the bolts were loose. He tightened them up and the noise is gone, and steering is nice and tight again.
Still loose steering.... (groan) QuottroA4 TDI Power Enhancements 1 January 23rd, 2011 06:30
Steering Wheel Loose karlkcfi TDI 101 7 December 23rd, 2008 11:28
06 Jetta Steering seems loose Tfoster100 VW MKV-A5 Golf/Jettas 53 January 9th, 2008 14:56
Loose Steering Wheel Hintertux VW MKIII-A3/B4 TDIs 21 August 27th, 2003 09:46
Loose Steering Wheel Hintertux VW MKIV-A4 TDIs (VE and PD) 7 December 11th, 2002 19:15
Page generated in 0.15393 seconds with 10 queries
[Output: 124.97 Kb. compressed to 103.77 Kb. by saving 21.19 Kb. (16.96%)]
